本人作為單片機(jī)新手,利用led點(diǎn)陣設(shè)計(jì)了一份貪吃蛇的程序,話(huà)不多說(shuō),直接上程序。
#include<reg51.h>
#include<intrins.h>
#include<stdlib.h>
typedef unsigned int u16;
typedef unsigned char u8;
sbit SER=P3^4;
sbit RCLK=P3^5;
sbit SRCLK=P3^6;
sbit up=P3^1;
sbit down=P3^0;
sbit lt=P3^2;
sbit rt=P3^3;
u8 code Hc595_Coordx[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
u8 code Hc595_Coordy[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
u8 foodx;
u8 foody;
u8 snake_x[20]={0};
u8 snake_y[20]={0};
u8 length;
u8 direction;
void initSnake();
void delay(u16 i);
void Hc595SendByte(u8 dat);
void move();
void Keypros();
void creatFood();
void snake_Grow(void);
void drawsnake();
void initSnake()
snake_x[0]=0;
snake_y[0]=0;
length=1;
direction=2;
void delay(u16 i)
while(i--);
u8 a;
SRCLK=0;
RCLK=0;
for(a=0;a<8;a++)
SER=dat>>7;
dat<<=1;
SRCLK=1;
_nop_();
_nop_();
SRCLK=0;
RCLK=1;
_nop_();
_nop_();
RCLK=0;
void move()
u8 len = length- 1;
for(len; len > 0; len--)
snake_x[len] = snake_x[len - 1];
snake_y[len] = snake_y[len - 1]; //一直到蛇頭
switch(direction)
case 1:
snake_y[0]--;
break;
case 2:
snake_y[0]++; //再利用蛇頭轉(zhuǎn)變方向
break;
case 3:
snake_x[0]--;
break;
case 4:
snake_x[0]++;
break;
default:
break;
//貪吃蛇的上下左右行動(dòng)控制
void Keypros()
if(up==0)
delay(1000); //消抖處理
if(up==0)
if(direction==3|direction==4)
direction=1; //在地址1內(nèi)寫(xiě)入數(shù)據(jù)num
while(!up);
if(down==0)
delay(1000); //消抖處理
if(down==0)
{ if(direction==3|direction==4)
direction=2;
while(!down);
if(lt==0)
delay(100); //消抖處理
if(lt==0)
if(direction==1|direction==2)
direction=3;
while(!lt);
if(rt==0)
delay(1000); //消抖處理
if(rt==0)
direction=4;
while(!rt);
void creatFood() //隨機(jī)創(chuàng)造食物
u8 i;
foodx=rand()%8;
foody=rand()%8;
for(i=0; i<length; i++)
if((foodx==snake_x[i])&&(foody==snake_y[i])) //如果食物與蛇的身體重疊,要重新創(chuàng)建
creatFood();
if(snake_x[0] == foodx && snake_y[0] == foody)
creatFood();
snake_x[length] = snake_x[length - 1];
snake_y[length] = snake_y[length - 1];
length++;
void drawsnake() //點(diǎn)亮蛇和食物
u8 i;
for(i=0;i<length;i++)
Hc595SendByte(Hc595_Coordy[snake_y[i]]);
P0=Hc595_Coordx[snake_x[i]];
delay(20);
P0=0xff;
Hc595SendByte(Hc595_Coordy[foody]);
P0=Hc595_Coordx[foodx];
delay(20);
P0=0xff;
void JudgeDeath(void)
u8 i;
// 判斷蛇撞墻死亡
if((snake_x[0]>7)||(snake_y[0]>7))
Hc595SendByte(0x00);
while(1);
// 判斷蛇撞到自己身體死亡
for(i=4; i<length; i++)
if((snake_x[0]==snake_x[i])&&(snake_y[0]==snake_y[i]))
P0=0xFF;
while(1);
void Timer0Init()
TMOD|=0X01;//選擇為定時(shí)器0模式,工作方式1,僅用TR0打開(kāi)啟動(dòng)。
TH0=0XD8; //給定時(shí)器賦初值,定時(shí)10ms
TL0=0XF0;
ET0=1;//打開(kāi)定時(shí)器0中斷允許
EA=1;//打開(kāi)總中斷
TR0=1;//打開(kāi)定時(shí)器
Timer0Init();
initSnake();
drawsnake();
JudgeDeath();
snake_Grow();
Keypros();
void Timer0() interrupt 1
static u16 i;
TL0=0XF0;
i++;
if(i==50)
i=0;
move();
