只需一步,快速開(kāi)始
查看: 4435|回復(fù): 2
16X16點(diǎn)陣輪換顯示多個(gè)漢字程序
本程序通過(guò)時(shí)間定時(shí)器產(chǎn)生中斷,每10ms刷新一次字符,每2S更新一個(gè)漢字。
單片機(jī)源程序如下:
  1. #include<reg51.h>
  3. #define unit unsigned int
  4. sbit DS=P2^0;                                                //595第14腳 串行數(shù)據(jù)輸入端
  5. sbit SH_CP=P2^1;                                        //595第11腳 移位脈沖
  6. sbit ST_CP=P2^2;                                        //595第12腳 并出脈沖
  7. sbit EN_154=P2^3;
  8. unsigned int i;
  9. unsigned char code tab[][32]=
  10. {
  11. {0xDF,0xDB,0xDB,0xDB,0x01,0xDC,0xDD,0xDF,0xDF,0x00,0xDF,0xDD,0xD3,0x5F,0xDF,0xFF,
  12. 0xFF,0xF7,0xB7,0x7B,0x80,0xFD,0xBE,0xBF,0xDF,0xEC,0xF3,0xEB,0xDD,0xBE,0x07,0xFF},
  13. {0x7F,0x9B,0xD3,0xCB,0xDB,0xDB,0x13,0xCD,0xDD,0xDD,0xCD,0xD1,0xDC,0x5D,0x9F,0xFF,
  14. 0xFF,0xBE,0xDE,0x6E,0x76,0x78,0xB2,0xAA,0xDA,0xDA,0xAA,0xB2,0x7E,0x7F,0x7F,0xFF},
  15. {0xFD,0x1D,0xDD,0xDD,0xC1,0x7F,0x7F,0x00,0x7F,0x5F,0x6F,0x77,0x79,0x7F,0x7F,0xFF,
  16. 0xFF,0xBC,0x7D,0xBD,0xC1,0xFF,0xFF,0x00,0xBF,0xDE,0xF9,0xF7,0xEF,0xDF,0xBF,0xFF},
  17. {0xF7,0x77,0x77,0x00,0x77,0x57,0xEF,0x17,0xD8,0xDB,0x1B,0xCB,0xD3,0x1F,0xFF,0xFF,
  18. 0xF7,0xF7,0xF7,0x00,0xF7,0xF7,0xFF,0xC0,0xBD,0xBD,0xBC,0xBD,0xBD,0xBC,0x8F,0xFF}
  19. };
  20. void delay_ms(unsigned int ms)
  21. {
  22.         unsigned int j;
  23.         while(ms--);
  24.         for(j=0;j<10;j++);
  25. }
  26. void WriteByte(unsigned char dat)
  27. {
  28. unsigned int k;
  29. for(k=0;k<8;k++)                //按照低位到高位的順序傳遞數(shù)據(jù)
  30.         {
  31.         dat=dat>>1;                        //數(shù)據(jù)右移,低位先出
  32.         DS=CY;
  33.         SH_CP=0;
  34.         SH_CP=1;
  35.         SH_CP=0;
  36.         }
  37. }
  38.
  39. void main()
  40. {
  41.         EA=1;                                //使能總中斷
  42.         TMOD=0x01;                        //設(shè)置T0為模式1
  43.         TH0=0xFC;                        //為T(mén)0賦初值,12M晶振下,定時(shí)1ms
  44.         TL0=0x18;
  45.         ET0=1;                                //使能T0中斷
  46.         TR0=1;                                //啟動(dòng)T0
  47.         while(1);
  48. }
  49. //定時(shí)器0中斷服務(wù)函數(shù)
  50. void InterruptTimer0() interrupt 1
  51. {
  52.         static unsigned int i=0;                        //動(dòng)態(tài)掃描的索引
  53.         static unsigned int index=0;                //文字更新索引,等于要顯示的字?jǐn)?shù)
  54.         static unsigned int tmr=0;                        //2s軟件定時(shí)器
  55.
  56.         //重新加載初值。本程序定時(shí)時(shí)間的想法是:每1ms刷新一次字符,每2S更新一個(gè)漢字
  57.     TH0 = 0x0FC;
  58.     TL0 = 0x18;
  59.                 if(i<16)
  60.                          {
  61.                                 EN_154=1;
  62.                                 WriteByte(tab[index][i]);
  63.                                 WriteByte(tab[index][i+16]);
  64.                                 ST_CP=0;
  65.                                 ST_CP=1;
  66.                                 delay_ms(1);
  67.                                 ST_CP=0;
  68.                                 P1=i;
  69.                                 EN_154=0;
  70.                                 i++;
  71.                          }
  72.                          else
  73.                          {
  74.                                  i=0;
  75.                          }
  76.         tmr++;        //下面代碼完成2s改變一個(gè)文字
  77.         if(tmr>=2000)
  78.         {
  79.                 tmr=0;
  80.                 index++;
  81.                 if(index>3)
  82.                 {
  83.                         index=0;
  84.                 }
  85.         }
  86. }
16X16點(diǎn)陣輪換顯示多個(gè)漢字程序.rar (203.21 KB, 下載次數(shù): 22)
ID:1 發(fā)表于 2019-8-15 01:21 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:568756 發(fā)表于 2019-8-17 09:22 | 只看該作者
謝謝管理員提醒,本人初次共享內(nèi)容。
現(xiàn)把電路圖和程序中涉及到的取模設(shè)置等文件附上,希望對(duì)那些有需要的朋友有幫助。基本上本程序沒(méi)有其他需要的內(nèi)容了。
電路搭建
電路搭建
取模設(shè)置
取模設(shè)置
