查看: 19267|回復: 3
基于51單片機蜂鳴器的兩只老虎音樂代碼
ID:598181 發表于 2019-8-10 01:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit BUZZ = P1^6;  //蜂鳴器控制引腳
unsigned int code NoteFrequ[] = {  //中音1-7和高音1-7對應頻率列表
    523,  587,  659,  698,  784,  880,  988,  //中音1-7
    1047, 1175, 1319, 1397, 1568, 1760, 1976  //高音1-7
unsigned int code NoteReload[] = { //中音1-7和高音1-7對應的定時器重載值
    65536 - (11059200/12) / (523*2),  //中音1
    65536 - (11059200/12) / (587*2),  //2
    65536 - (11059200/12) / (659*2),  //3
    65536 - (11059200/12) / (698*2),  //4
    65536 - (11059200/12) / (784*2),  //5
    65536 - (11059200/12) / (880*2),  //6
    65536 - (11059200/12) / (988*2),  //7
    65536 - (11059200/12) / (1047*2), //高音1
    65536 - (11059200/12) / (1175*2), //2
    65536 - (11059200/12) / (1319*2), //3
    65536 - (11059200/12) / (1397*2), //4
    65536 - (11059200/12) / (1568*2), //5
    65536 - (11059200/12) / (1760*2), //6
    65536 - (11059200/12) / (1976*2), //7
bit enable = 1;   //蜂鳴器發聲使能標志
bit tmrflag = 0;  //定時器中斷完成標志
unsigned char T0RH = 0xFF;  //T0重載值的高字節
unsigned char T0RL = 0x00;  //T0重載值的低字節
void PlayTwoTiger();
    unsigned int i;
    EA = 1;       //使能全局中斷
    TMOD = 0x01;  //配置T0工作在模式1
    TH0 = T0RH;
    TL0 = T0RL;
    ET0 = 1;      //使能T0中斷
    TR0 = 1;      //啟動T0
    while (1)
        PlayTwoTiger();  //播放樂曲--兩支老虎
        for (i=0; i<40000; i++);  //停止一段時間
/* 兩只老虎樂曲播放函數 */
void PlayTwoTiger()
    unsigned char beat;   //當前節拍索引
    unsigned char note;   //當前節拍對應的音符
    unsigned int time = 0;      //當前節拍計時
    unsigned int beatTime = 0;  //當前節拍總時間
    unsigned int soundTime = 0; //當前節拍需發聲時間
    //兩只老虎音符表
    unsigned char code TwoTigerNote[] = {
        1,   2,   3, 1,    1,   2,   3, 1,   3, 4, 5,   3, 4, 5,
        5,6, 5,4, 3, 1,    5,6, 5,4, 3, 1,   1, 5, 1,   1, 5, 1,
    //兩只老虎節拍表,4表示一拍,1就是1/4拍,8就是2拍
    unsigned char code TwoTigerBeat[] = {
        4,   4,   4, 4,    4,   4,   4, 4,   4, 4, 8,   4, 4, 8,
        3,1, 3,1, 4, 4,    3,1, 3,1, 4, 4,   4, 4, 8,   4, 4, 8,
    for (beat=0; beat<sizeof(TwoTigerNote); )  //用節拍索引作為循環變量
        while (!tmrflag);  //每次定時器中斷完成后,檢測并處理節拍
        tmrflag = 0;
        if (time == 0)  //當前節拍播完則啟動一個新節拍
            note = TwoTigerNote[beat] - 1;
            T0RH = NoteReload[note] >> 8;
            T0RL = NoteReload[note];
            //計算節拍總時間,右移2位相當于除4,移位代替除法可以加快執行速度
            beatTime = (TwoTigerBeat[beat] * NoteFrequ[note]) >> 2;
            //計算發聲時間,為總時間的0.75,移位原理同上
            soundTime = beatTime - (beatTime >> 2);
            enable = 1;  //指示蜂鳴器開始發聲
            time++;
        else  //當前節拍未播完則處理當前節拍
            if (time >= beatTime)  //當前持續時間到達節拍總時間時歸零,
            {                      //并遞增節拍索引,以準備啟動新節拍
                time = 0;
                beat++;
            else  //當前持續時間未達到總時間時,
                time++;   //累加時間計數
                if (time == soundTime)  //到達發聲時間后,指示關閉蜂鳴器,
                {                       //插入0.25*總時間的靜音間隔,
                    enable = 0;         //用以區分連續的兩個節拍
/* T0中斷服務函數,用于控制蜂鳴器發聲 */
void InterruptTimer0() interrupt 1
    TH0 = T0RH;   //重新加載重載值
    TL0 = T0RL;
    tmrflag = 1;
    if (enable)   //使能時反轉蜂鳴器控制電平
        BUZZ = ~BUZZ;
    else          //未使能時關閉蜂鳴器
        BUZZ = 1;
收藏收藏4 分享淘帖 頂1 踩
ID:886364 發表于 2021-3-1 12:38 | 只看該作者
可以的, 寫得不錯
ID:284226 發表于 2023-3-4 15:43 | 只看該作者
請問為什么是除以4.上面兩個
ID:1086387 發表于 2023-8-2 14:12 | 只看該作者
怎么讓他停下來
