大家一起學(xué)習(xí)探討
單片機(jī)源程序如下:
- * @file 24c32.c
- * @author Wang
- * @version V1.0.0
- * @date 6-August-2019
- * @brief This file contains all the functions for the read or write 24c32
- /* Includes ------------------------------------------------------------------*/
- #include "24c32.h"
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- /* Public functions ----------------------------------------------------------*/
- * @brief Write data to 24c32 device
- * @param addr : slaver address
- * @param reg_addr : register address
- * @param send_data : send data
- * @retval None
- void Write_24c32(uint8_t addr , uint8_t reg_addr , uint8_t send_data )
- Soft_iic_Start();
- Soft_iic_Write_Byte(addr);
- Soft_iic_Write_Byte(reg_addr>>8); /*High address */
- Soft_iic_Write_Byte(reg_addr%256); /*Low address */
- Soft_iic_Write_Byte(send_data);
- Soft_iic_Stop();
- * @brief Read data from 24c32 device
- * @retval return read data from DS1307 device
- uint8_t Read_24c32(uint8_t addr , uint8_t reg_addr)
- uint8_t data = 0;
- Soft_iic_Start();
- Soft_iic_Start();
- Soft_iic_Write_Byte(addr | 0x01);
- data = Soft_iic_Read_Byte(0);
- Soft_iic_Stop();
- return data;
- * @brief Test the 24c32 about read and write
- * @param None
- * @retval None
- void Test_24c32(void)
- uint8_t recv_data;
- Write_24c32(0xA0,0,10);
- Soft_delay_10us(500); /* need to add delay */
- recv_data = Read_24c32(0xA0,0);
- if(recv_data == 10)
- LED_On();
- Timer1_Delay_1ms(100);
- LED_Off();
- /****************************END OF FILE**************************************/
Project_2.7z
(3.8 MB, 下載次數(shù): 52)
2019-8-9 17:55 上傳
點(diǎn)擊文件名下載附件
