查看: 3523|回復: 3
基于ST7565的LCD12864測試程序+視頻
據說ST756很坑,最近做項目正好遇到,果然被坑的不輕總結而言,不能求快,尤其是質量不太好的屏幕模塊,快了就罷工
直接貼完整驅動函數(單片機是STC15LE5A32S2,指令按照使用手冊重新排寫的,可直接移植,基本不會出問題)
/************************底層驅動函數************************/
void ms_Delay_12864(unsigned int ms)//STC12, 11.0592M
    unsigned char j;
    while(ms --)
    for(j = 0; j < 30; j ++); //20us=0.02ms//
void Delay_Buff( )/*數據緩沖,根據具體實物改動(下載后不顯示可適當加長延時)*/
        unsigned char i;
        for(i = 0; i < 35; i ++)//16
                _nop_( );
void LCD_Write_Reg(unsigned char Command)
        unsigned char i, j;
        CS = 0;
        RS = 0;
        SCL = 0;
        for(i = 0; i < 8; i ++)
                j = Command;
                SCL = 0;
                SI = Command & 0x80;
                SCL = 1;
                Command = j << 1;
                Delay_Buff( );/*根據具體硬件改寫,某些硬件需要緩沖,有硬件緩沖時可取消延時*/
        CS = 1;
        RS = 1;
void LCD_Write_Byte(unsigned char byte)
        unsigned char i, j;
        CS = 0;
        RS = 1;
        SCL = 0;
                j = byte;
                SCL = 0;
                SI = byte & 0x80;
                SCL = 1;
                byte = j << 1;
        CS = 1;
        RS = 0;
void LCD_Clear( )
        unsigned char i, j;
                LCD_Write_Reg(0xb0 + i);               // (Page = 0xB0)//設置位置
                LCD_Write_Reg(0x10);
                LCD_Write_Reg(0x00);
                for(j = 0; j < 132; j ++)            //發送數據
                        LCD_Write_Byte(0);
void LCD_ALL( )
        unsigned char i, j;
                        LCD_Write_Byte(0xff);
void LCD_Init( )//有效命令基本已羅列
        RST = 0;
        ms_Delay_12864(50);
        RST = 1;
        ms_Delay_12864(20);
        LCD_Write_Reg(0xe2);//軟件復位
        ms_Delay_12864(5);
        LCD_Write_Reg(0x2c);//電源控制0x28 ~ 0xf
        ms_Delay_12864(5);
        LCD_Write_Reg(0x2e);
        ms_Delay_12864(5);
        LCD_Write_Reg(0x2f);
        ms_Delay_12864(5);
        LCD_Write_Reg(0xa3);//偏壓比: 0xa2 >> 1/9, 0xa3 >> 1/7
        LCD_Write_Reg(0x23);//內部電阻比例: 0x20 ~ 0x27
        LCD_Write_Reg(0x81);//設置內部液晶電壓模式
        LCD_Write_Reg(0x1d);//L: 0x00 ~ 0x3f
        LCD_Write_Reg(0x24);//H: 0x21 ~ 0x27
        LCD_Write_Reg(0xf8);//設置升壓倍數
        LCD_Write_Reg(0x01);//0x00 >> 2 ~ 4倍, 0x01 >> 5倍, 0x03 >> 6倍
        LCD_Write_Reg(0x40);//從首行開始顯示
        LCD_Write_Reg(0xa6);//0xa6 >> 正顯, 0xa7 >> 反顯
        LCD_Write_Reg(0xc8);//0xc8 >> 反向掃描, 0xc0 >> 順序掃描
        LCD_Write_Reg(0xa0);//0xa0 >> 正常顯示, 0xa1 >> 左右鏡像
        LCD_Write_Reg(0xa4);//0xa4 >> 顯示全部點陣, 0xa5 >>不顯示全部點陣
        LCD_Write_Reg(0xac);//0xac >> 靜態圖標顯示, 0xad >> 無靜態圖標
        LCD_Write_Reg(0xaf);//0xaf >> 顯示開, 0xae >> 顯示關
        LCD_Clear( );
附件里有視頻、模塊說明書和ST7565操作指令表:
LCD12864-ST7565.zip (18.82 MB, 下載次數: 102)
收藏收藏2 分享淘帖 頂 踩
ID:584814 發表于 2020-3-4 15:54 | 只看該作者
重復下載會累加扣分,網站源碼應該調整。
ID:224782 發表于 2020-3-18 10:51 | 只看該作者
man1234567 發表于 2020-3-4 15:54
重復下載會累加扣分,網站源碼應該調整。
下自己的也要扣分
ID:138343 發表于 2020-5-10 17:28 | 只看該作者
看樣子是spi驅動的,下載來看看
