查看: 2205|回復: 0
LCD1602液晶顯示屏控制
ID:255587 發表于 2019-8-8 10:18 | 顯示全部樓層 |閱讀模式
程序如下
#include<reg51.h>
typedef unsigned int  u16;
typedef unsigned char u8;
#define DATA P0
sbit rs = P2^1;
sbit rw = P1^5;
sbit en = P1^6;
void delay(u16 num)
        u16 x,y;
        for (x=num; x>0; x--)
                for(y=110; y>0; y--);
void write_cmd (u8 cmd)
        rs = 0;
        rw = 0;
        DATA = cmd;
        delay(5);
        en = 1;
        delay(5);
        en = 0;
void write_data (u8 dat)
        rs = 1;
        rw = 0;
        DATA = dat;
        delay(5);
        en = 1;
        delay(5);
        en = 0;
void lcd_init (void)
        write_cmd(0x01);
        write_cmd(0x06);
        write_cmd(0x0f);
        write_cmd(0x38);
        write_cmd(0x01);
int main (void)
        rw = 0;
        rs = 0;
        en = 0;
        lcd_init();
        write_cmd(0xc0);
        write_data('L');
        write_data('O');
        write_data('V');
        write_data('E');
        write_data(' ');
        write_data('Y');
        write_data('O');
        write_data('U');
        while(1);
運行結果
運行結果
