查看: 3568|回復: 2
STM8用模擬IIC讀寫DS1307源程序 實測有效
ID:125378 發表于 2019-8-6 09:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一起探討學習
  1. #include "bsp.h"
  2. #include "stdio.h"
  3. #include "string.h"
  4. #include "ds1307.h"
  5. #include "soft_iic.h"
  6. #define led_1()                   GPIO_WriteHigh(GPIOD, GPIO_PIN_0)
  7. #define led_0()                   GPIO_WriteLow(GPIOD, GPIO_PIN_0)
  8. u8 sendData[] = "iic_test";
  9. u8 revData[10];
  10. u8 DeviceData[10];
  11. void main(void)
  12. {
  13.         uint8_t rev_dat=0;
  14.   uint8_t i=0;
  15.         uint8_t t_data=0x11;
  16.         uint8_t t_data1=0x00;
  17.
  18.         uint8_t temp;
  19.   BSP_Initializes();
  20.   soft_IIC_init();
  21.   IIC_Init();
  22.   led_0();
  23.   timer_delay_s(1);
  24.   led_1();
  25.
  26.         //IIC_Write(0xD0 , 0x07 , &t_data , 1);         //用片內IIC寫數據
  27.         //IIC_Write(0xD0 , 0x03 , &t_data1 , 1);
  28.
  29.         iic_write_ds1307(0xD0,0x07,0x13);//control SQ_pin  ouuput square wave address 0x07
  30.         //        0x10 <--> 1Hz        0x11 <--> 4096Hz 0x12 <--> 8192Hz 0x13 <--> 32.768kHz
  31.
  32.         //iic_write_ds1307(0xD0,0x02,0xd);
  33.         rev_dat = iic_read_ds1307(0xD0,0x01);  //read mimutes
  34.   while(1)
  35.   {
  36.
  37.     if(rev_dat==35)
  38.     {
  39.       led_0();
  40.       timer_delay_s(1);
  41.       led_1();
  42.                         timer_delay_s(1);
  43.     }
  44.
  45.   }
  46. }
  47. #ifdef USE_FULL_ASSERT
  48. void assert_failed(u8* file, u32 line)
  49. {
  50.   /* User can add his own implementation to report the file name and line number,
  51.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  52.   /* Infinite loop */
  53.   while (1)
  54.   {
  55.   }
  56. }
  57. #endif
GPIO_IIC -1.7z (3.83 MB, 下載次數: 64)
ID:321981 發表于 2020-3-7 21:37 | 只看該作者
垃圾,這個是硬件的
ID:1009545 發表于 2022-3-10 22:15 | 只看該作者
可以用
