利用紅外對管測數,之后把數據通過lcd1602顯示出來
- SMC1602A(16*2)模擬口線接線方式
- 連接線圖:
- |LCM-----51 | LCM-----51 | LCM------51 |
- |DB0-----P1.0 | DB4-----P1.4 | RW-------P3.4 |
- |DB1-----P1.1 | DB5-----P1.5 | RS-------P3.3 |
- |DB2-----P1.2 | DB6-----P1.6 | E--------P3.5 |
- |DB3-----P1.3 | DB7-----P1.7 | VLCD接1K電阻到GND|
- 接線:模塊TRIG接 P2.6 ECH0 接P2.7
- #include <AT89x51.H> //器件配置文件
- #include <intrins.h>
- #define Rin P3_7
- #define LCM_RW P1_1 //定義LCD引腳
- #define LCM_RS P1_0
- #define LCM_E P1_5
- #define LCM_Data P0
- #define Key_Data P2_0 //定義Keyboard引腳
- #define Key_CLK P3_2
- #define Busy 0x80 //用于檢測LCM狀態字中的Busy標識
- void LCMInit(void);
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
- void Delay5Ms(void);
- void Delay400Ms(void);
- void Decode(unsigned char ScanCode);
- void WriteDataLCM(unsigned char WDLCM);
- void WriteCommandLCM(unsigned char WCLCM,BuysC);
- void Conut(void);
- unsigned char ReadDataLCM(void);
- unsigned char ReadStatusLCM(void);
- unsigned char code mcustudio[] ={"number:"};
- unsigned char code Cls[] = {" "};
- unsigned char code ASCII[10] = {'0','1','2','3','4','5','6','7','8','9'};
- static unsigned char DisNum = 0; //顯示用指針
- unsigned int time=0;
- bit flag =0;
- unsigned char disbuff[4]={ 0,0,0,0,};
- unsigned long S = 0;
- volatile bit FlagSucceed=0; //測量成功標志
- sbit Beep=P2^0; //報警蜂鳴器
- sbit LedAlarm = P2^1;
- ReadStatusLCM(); //檢測忙
- LCM_Data = WDLCM;
- LCM_RS = 1;
- LCM_RW = 0;
- LCM_E = 0; //若晶振速度太高可以在這后加小的延時
- LCM_E = 0; //延時
- LCM_E = 1;
- //寫指令
- void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
- if (BuysC) ReadStatusLCM(); //根據需要檢測忙
- LCM_Data = WCLCM;
- LCM_RS = 0;
- LCM_RW = 0;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- //讀數據
- LCM_RS = 1;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- return(LCM_Data);
- //讀狀態
- LCM_Data = 0xFF;
- LCM_RS = 0;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- while (LCM_Data & Busy); //檢測忙信號
- return(LCM_Data);
- void LCMInit(void) //LCM初始化
- LCM_Data = 0;
- WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
- Delay5Ms();
- Delay5Ms();
- Delay5Ms();
- WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
- WriteCommandLCM(0x08,1); //關閉顯示
- WriteCommandLCM(0x01,1); //顯示清屏
- WriteCommandLCM(0x06,1); // 顯示光標移動設置
- WriteCommandLCM(0x0F,1); // 顯示開及光標設置
- //按指定位置顯示一個字符
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
- X |= 0x80; //算出指令碼
- WriteCommandLCM(X, 1); //發命令字
- WriteDataLCM(DData); //發數據
- //按指定位置顯示一串字符
- unsigned char ListLength;
- ListLength = 0;
- Y &= 0xFE;
- X &= 0xFF; //限制X不能大于15,Y不能大于1
- while (DData[ListLength]>0x19) //若到達字串尾則退出
- if (X <= 0xF) //X坐標應小于0xF
- DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
- ListLength++;
- X++;
- //5ms延時
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //400ms延時
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- void Conut(void)
- time=TH0*256+TL0;
- TH0=0;
- TL0=0;
- S+=1; //算出來是
- Beep = 0;
- if((S>=1000)||flag==1) //超出測量范圍顯示“-”
- flag=0;
- DisplayOneChar(0, 1, ASCII[0]);
- DisplayOneChar(1, 1, ASCII[1]);
- DisplayOneChar(2, 1, ASCII[2]);
- else
- disbuff[0]=S/100%10;
- disbuff[1]=S/10%10;
- disbuff[2]=S%10;
- DisplayOneChar(0, 1, ASCII[disbuff[0]]);
- DisplayOneChar(1, 1, ASCII[disbuff[1]]);
- DisplayOneChar(2, 1, ASCII[disbuff[2]]);
- void zd0() interrupt 1 //T0中斷用來計數器溢出,超過測距范圍
- flag=1; //中斷溢出標志
- void StartModule() //啟動模塊
- Rin=0; //啟動一次模塊
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- Rin=1;
- void delayms(unsigned int ms)
- unsigned char i=100,j;
- for(;ms;ms--)
- while(--i)
- j=10;
- while(--j);
- void main(void)
- unsigned char TempCyc;
- LedAlarm = 1;
- Delay400Ms(); //啟動等待,等LCM講入工作狀態
- LCMInit(); //LCM初始化
- Delay5Ms(); //延時片刻(可不要)
- DisplayListChar(0, 0, mcustudio);
- ReadDataLCM();//測試用句無意義
- for (TempCyc=0; TempCyc<10; TempCyc++)
- Delay400Ms(); //延時
- while(1)
- StartModule();
- while(!Rin); //當RX為零時等待
- TR0=0; //關閉計數
- Conut(); //計算
- Beep = 1;
- delayms(80); //80MS
- while(Rin); //當RX為1計數并等待
- EA=0;
- //以下為一次檢測過程;先發出Trin電平,打開外部中斷,清零T1
- //最后在外部中斷下降沿觸發時取出T1當前值,計算出Trig脈沖寬度
- TR0=1; //開啟計數
- Beep = 0;
所有程序51hei提供下載:
調試.zip
(173.52 KB, 下載次數: 18)
2019-8-5 20:35 上傳
下載積分: 黑幣 -5
