查看: 3529|回復: 1
STC12單片機做平衡車程序 mpu6050+L298N+直流減速電機
ID:580450 發表于 2019-7-31 16:21 | 顯示全部樓層 |閱讀模式
大家參考參考。
  1. #include <stc12c5a.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #include <math.h>
  5. #include "kalman.h"
  6. #include "lcd1602.h"
  7. #include "mpu6050.h"
  8. #include "pid_own.h"
  9. #include "pwm_motor.h"
  10. #include "spe_pos.h"
  11. int INT_PWM;
  12. unsigned int Init_Time=0,Start_Flag=0;
  13. void main()
  14. {
  15.         lcd_init();
  16.         InitMPU6050();
  17.         PWM_Motor_Init();
  18.         INT_Init();
  19.
  20.         P1M0=1;
  21.         P1M1=0;
  22.
  23.         while(1)
  24.         {
  25.                 if(GYRO_X<0)
  26.                 {
  27.                         write_com(0x80);
  28.                         write_dat('-');
  29.                         write_dat('0'+(uchar)abs(GYRO_X)/100);
  30.                         write_dat('0'+(uchar)abs(GYRO_X)%100/10);
  31.                         write_dat('0'+(uchar)abs(GYRO_X)%10);
  32.                 }
  33.                 else
  34.                 {
  35.                         write_com(0x80);
  36.                         write_dat('+');
  37.                         write_dat('0'+(uchar)GYRO_X/100);
  38.                         write_dat('0'+(uchar)GYRO_X%100/10);
  39.                         write_dat('0'+(uchar)GYRO_X%10);
  40.                 }
  41.                 if(Angle_End<0)
  42.                 {
  43.                         write_com(0x80+0x40);
  44.                         write_dat('-');
  45.                         write_dat('0'+(uchar)abs(Angle_End)/100);
  46.                         write_dat('0'+(uchar)abs(Angle_End)%100/10);
  47.                         write_dat('0'+(uchar)abs(Angle_End)%10);
  48.                 }
  49.                 else
  50.                 {
  51.                         write_com(0x80+0x40);
  52.                         write_dat('+');
  53.                         write_dat('0'+(uchar)Angle_End/100);
  54.                         write_dat('0'+(uchar)Angle_End%100/10);
  55.                         write_dat('0'+(uchar)Angle_End%10);
  56.                 }
  57.
  58.                 if(speed<0)
  59.                 {
  60.                         write_com(0x80+9);
  61.                         write_dat('-');
  62.                         write_dat('0'+(uchar)abs(speed)/100);
  63.                         write_dat('0'+(uchar)abs(speed)%100/10);
  64.                         write_dat('0'+(uchar)abs(speed)%10);
  65.                 }
  66.                 else
  67.                 {
  68.                         write_com(0x80+9);
  69.                         write_dat('+');
  70.                         write_dat('0'+(uchar)speed/100);
  71.                         write_dat('0'+(uchar)speed%100/10);
  72.                         write_dat('0'+(uchar)speed%10);
  73.                 }
  74.
  75.                 if(position<0)
  76.                 {
  77.                         write_com(0x80+0x40+9);
  78.                         write_dat('-');
  79.                         write_dat('0'+(uint)abs(position)/10000);
  80.                         write_dat('0'+(uint)abs(position)%10000/1000);
  81.                         write_dat('0'+(uint)abs(position)%1000/100);
  82.                         write_dat('0'+(uint)abs(position)%100/10);
  83.                         write_dat('0'+(uint)abs(position)%10);
  84.                 }
  85.                 else
  86.                 {
  87.                         write_com(0x80+0x40+9);
  88.                         write_dat('+');
  89.                         write_dat('0'+(uint)abs(position)/10000);
  90.                         write_dat('0'+(uint)abs(position)%10000/1000);
  91.                         write_dat('0'+(uint)position%1000/100);
  92.                         write_dat('0'+(uint)position%100/10);
  93.                         write_dat('0'+(uint)position%10);
  94.                 }
  95.
  96.                 if(Start_Flag)
  97.                 {
  98.                         INT_PWM = pid_proc(Angle_End,Gyro_End,speed,position);
  99.
  100.                         Motor_Con(-INT_PWM,-INT_PWM);
  101.
  102.                 }
  103.         }
  104.
  105. }
  106. void timer1() interrupt 3
  107. {
  108.         TL1 = 0x00;                    //定時10MS
  109.         TH1 = 0xB8;
  110.
  111.         if(!Start_Flag)                //啟動前的延時
  112.         {
  113.                 Init_Time++;
  114.                 if(Init_Time>=100) Start_Flag=1;
  115.         }
  116.
  117.         if(Start_Flag)
  118.         {
  119.                 Get_Date();
  120.                 Kalman_Filter(Angel_accY,GYRO_X);
  121.                 Speed_Position_Get();
  122.                 speed_mr = speed_ml = 0;
  123.         }
  124. }
所有程序51hei提供下載:
小車平衡STC穩定.zip (196.23 KB, 下載次數: 114)
ID:1 發表于 2019-7-31 22:52 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
