想做滾球控制系統(tǒng),先寫(xiě)了個(gè)MPU6050驅(qū)動(dòng)看看,程序啥的在附件
2019-7-29 17:03 上傳
單片機(jī)源程序如下:
- #include <REG52.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- typedef unsigned char uchar;
- typedef unsigned short ushort;
- typedef unsigned int uint;
- // 定義51單片機(jī)端口
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^1; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^0; //IIC數(shù)據(jù)引腳定義
- sbit LCM_RS=P3^5; //LCD1602命令端口
- sbit LCM_RW=P3^6; //LCD1602命令端口
- sbit LCM_EN=P3^4; //LCD1602命令端口
- // 定義MPU6050內(nèi)部地址
- #define SMPLRT_DIV 0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
- #define CONFIG 0x1A //低通濾波頻率,典型值:0x06(5Hz)
- #define GYRO_CONFIG 0x1B //陀螺儀自檢及測(cè)量范圍,典型值:0x18(不自檢,2000deg/s)
- #define ACCEL_CONFIG 0x1C //加速計(jì)自檢、測(cè)量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
- #define ACCEL_XOUT_H 0x3B
- #define ACCEL_XOUT_L 0x3C
- #define ACCEL_YOUT_H 0x3D
- #define ACCEL_YOUT_L 0x3E
- #define ACCEL_ZOUT_H 0x3F
- #define ACCEL_ZOUT_L 0x40
- #define TEMP_OUT_H 0x41
- #define TEMP_OUT_L 0x42
- #define GYRO_XOUT_H 0x43
- #define GYRO_XOUT_L 0x44
- #define GYRO_YOUT_H 0x45
- #define GYRO_YOUT_L 0x46
- #define GYRO_ZOUT_H 0x47
- #define GYRO_ZOUT_L 0x48
- #define PWR_MGMT_1 0x6B //電源管理,典型值:0x00(正常啟用)
- #define WHO_AM_I 0x75 //IIC地址寄存器(默認(rèn)數(shù)值0x68,只讀)
- #define SlaveAddress 0xD0 //IIC寫(xiě)入時(shí)的地址字節(jié)數(shù)據(jù),+1為讀取
- //定義類(lèi)型及變量
- uchar dis[4]; //顯示數(shù)字(-511至512)的字符數(shù)組
- int dis_data; //變量
- //int Temperature,Temp_h,Temp_l; //溫度及高低位數(shù)據(jù)
- //函數(shù)聲明
- void delay(unsigned int k); //延時(shí)
- //LCD相關(guān)函數(shù)
- void InitLcd(); //初始化lcd1602
- void lcd_printf(uchar *s,int temp_data);
- void WriteDataLCM(uchar dataW); //LCD數(shù)據(jù)
- void WriteCommandLCM(uchar CMD,uchar Attribc); //LCD指令
- void DisplayOneChar(uchar X,uchar Y,uchar DData); //顯示一個(gè)字符
- void DisplayListChar(uchar X,uchar Y,uchar *DData,L); //顯示字符串
- //MPU6050操作函數(shù)
- void InitMPU6050(); //初始化MPU6050
- void Delay5us();
- void I2C_Start();
- void I2C_Stop();
- void I2C_SendACK(bit ack);
- bit I2C_RecvACK();
- void I2C_SendByte(uchar dat);
- uchar I2C_RecvByte();
- void I2C_ReadPage();
- void I2C_WritePage();
- void display_ACCEL_x();
- void display_ACCEL_y();
- void display_ACCEL_z();
- uchar Single_ReadI2C(uchar REG_Address); //讀取I2C數(shù)據(jù)
- void Single_WriteI2C(uchar REG_Address,uchar REG_data); //向I2C寫(xiě)入數(shù)據(jù)
- //整數(shù)轉(zhuǎn)字符串
- if(temp_data<0)
- temp_data=-temp_data;
- *s='-';
- else *s=' ';
- *++s =temp_data/100+0x30;
- temp_data=temp_data%100; //取余運(yùn)算
- *++s =temp_data/10+0x30;
- temp_data=temp_data%10; //取余運(yùn)算
- *++s =temp_data+0x30;
- //延時(shí)
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++);
- //LCD1602初始化
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- DisplayOneChar(0,0,'A');
- DisplayOneChar(0,1,'G');
- //LCD1602寫(xiě)允許
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- //LCD1602寫(xiě)入命令
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- //LCD1602寫(xiě)入數(shù)據(jù)
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- //LCD1602寫(xiě)入一個(gè)字符
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- //LCD1602顯示字符串
- uchar ListLength=0;
- Y&=0x1;
- X&=0xF;
- while(L--)
- DisplayOneChar(X,Y,DData[ListLength]);
- ListLength++;
- X++;
- //延時(shí)5微秒(STC90C52RC@12M)
- //不同的工作環(huán)境,需要調(diào)整此函數(shù)
- //當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- //I2C起始信號(hào)
- void I2C_Start()
- SDA = 1; //拉高數(shù)據(jù)線(xiàn)
- SCL = 1; //拉高時(shí)鐘線(xiàn)
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線(xiàn)
- //I2C停止信號(hào)
- void I2C_Stop()
- SDA = 0; //拉低數(shù)據(jù)線(xiàn)
- SDA = 1; //產(chǎn)生上升沿
- //I2C發(fā)送應(yīng)答信號(hào)
- //入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫(xiě)應(yīng)答信號(hào)
- //I2C接收應(yīng)答信號(hào)
- bit I2C_RecvACK()
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- //向I2C總線(xiàn)發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- uchar i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- I2C_RecvACK();
- //從I2C總線(xiàn)接收一個(gè)字節(jié)數(shù)據(jù)
- uchar i;
- uchar dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //向I2C設(shè)備寫(xiě)入一個(gè)字節(jié)數(shù)據(jù)
- I2C_Start(); //起始信號(hào)
- I2C_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
- I2C_SendByte(REG_Address); //內(nèi)部寄存器地址,
- I2C_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),
- I2C_Stop(); //發(fā)送停止信號(hào)
- //從I2C設(shè)備讀取一個(gè)字節(jié)數(shù)據(jù)
- uchar REG_data;
- I2C_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
- I2C_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=I2C_RecvByte(); //讀出寄存器數(shù)據(jù)
- I2C_SendACK(1); //接收應(yīng)答信號(hào)
- I2C_Stop(); //停止信號(hào)
- return REG_data;
- //初始化MPU6050
- Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠狀態(tài)
- Single_WriteI2C(SMPLRT_DIV, 0x07);
- Single_WriteI2C(CONFIG, 0x06);
- Single_WriteI2C(GYRO_CONFIG, 0x18);
- Single_WriteI2C(ACCEL_CONFIG, 0x01);
- //合成數(shù)據(jù)
- int GetData(uchar REG_Address)
- char H,L;
- H=Single_ReadI2C(REG_Address);
- L=Single_ReadI2C(REG_Address+1);
- return (H<<8)+L; //合成數(shù)據(jù)
- //在1602上顯示10位數(shù)據(jù)
- void Display10BitData(int value,uchar x,uchar y)
- value/=64; //轉(zhuǎn)換為10位數(shù)據(jù)
- lcd_printf(dis, value); //轉(zhuǎn)換數(shù)據(jù)顯示
- DisplayListChar(x,y,dis,4); //啟始列,行,顯示數(shù)組,顯示長(zhǎng)度
- //顯示溫度
- //void display_temp()
- // Temp_h=Single_ReadI2C(TEMP_OUT_H); //讀取溫度
- // Temp_l=Single_ReadI2C(TEMP_OUT_L); //讀取溫度
- // Temperature=Temp_h<<8|Temp_l; //合成溫度
- // Temperature = 35+ ((double) (Temperature + 13200)) / 280; // 計(jì)算出溫度
- // lcd_printf(dis,Temperature); //轉(zhuǎn)換數(shù)據(jù)顯示
- // DisplayListChar(11,1,dis,4); //啟始列,行,顯示數(shù)組,顯示位數(shù)
- //主程序
- void main()
- delay(500); //上電延時(shí)
- InitLcd(); //液晶初始化
- InitMPU6050(); //初始化MPU6050
- delay(150);
- while(1)
- Display10BitData(GetData(ACCEL_XOUT_H),2,0); //顯示X軸加速度
- Display10BitData(GetData(ACCEL_YOUT_H),7,0); //顯示Y軸加速度
- Display10BitData(GetData(ACCEL_ZOUT_H),12,0); //顯示Z軸加速度
- Display10BitData(GetData(GYRO_XOUT_H),2,1); //顯示X軸角速度
- Display10BitData(GetData(GYRO_YOUT_H),7,1); //顯示Y軸角速度
- Display10BitData(GetData(GYRO_ZOUT_H),12,1); //顯示Z軸角速度
- delay(500);
陀螺儀MPU6050.7z
(1.22 MB, 下載次數(shù): 191)
2019-7-29 18:17 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
