查看: 2498|回復: 1
RC522 RFID 串口輸出ID單片機源程序
STC單片機讀取RFID卡號,通過串口打印出來
  1. /**********************RC522實驗開發板例程************************
  2. *  CPU:STC89C52RC
  3. *  晶振:11.0592MHZ
  4. ------------------------------------------------*/
  5. #include "STC8X.h"
  6. #include  <STDIO.H>
  7. #include <string.h>
  8. #include "main.h"
  9. #include "mfrc522.h"
  10. typedef unsigned char uchar;
  11. typedef unsigned int  uint;
  12. #define FOSC 11059200L          //系統頻率
  13. #define BAUD 115200             //串口波特率
  14. #define S1_S0 0x40              //P_SW1.6
  15. #define S1_S1 0x80              //P_SW1.7
  16. bit busytx;
  17. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  18. //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收命令
  19. //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
  20. unsigned char code data2[4]  = {0,0,0,0x01};
  21. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  22. unsigned char g_ucTempbuf[20];
  23. void delay1(unsigned int z)
  24. {
  25.         unsigned int x,y;
  26.         for(x=z;x>0;x--)
  27.         for(y=110;y>0;y--);
  28. }
  29. void Uart() interrupt 4
  30. {
  31.     if (RI)
  32.     {
  33.         RI = 0;                 //清除RI位
  34.         P0 = SBUF;              //P0顯示串口數據
  35.     //    P22 = RB8;              //P2.2顯示校驗位
  36.     }
  37. //    if (TI)
  38. //    {
  39. //        TI = 0;                 //清除TI位
  40. //        busytx = 0;               //清忙標志
  41. //    }
  42. }
  43. //void SendData(uchar UartDat)
  44. //{
  45. //    while (busytx);               //等待前面的數據發送完成
  46. //    busytx=1;
  47. //    SBUF=UartDat;                 //寫數據到UART數據寄存器
  48. //}
  49. //void SendString(char *s)
  50. //{
  51. //    while (*s)                  //檢測字符串結束標志
  52. //    {
  53. //        SendData(*s++);         //發送當前字符
  54. //    }
  55. //}
  56. /////////////////////////////////////////////////////////////////////
  57. //系統初始化
  58. /////////////////////////////////////////////////////////////////////
  59. void InitializeSystem()
  60. {
  61.     P0M0 = 0x00;
  62.     P0M1 = 0x00;
  63.     P1M0 = 0x00;
  64.     P1M1 = 0x00;
  65.     P2M0 = 0x00;
  66.     P2M1 = 0x00;
  67.     P3M0 = 0x00;
  68.     P3M1 = 0x00;
  69.     P4M0 = 0x00;
  70.     P4M1 = 0x00;
  71.     P5M0 = 0x00;
  72.     P5M1 = 0x00;
  73.     P6M0 = 0x00;
  74.     P6M1 = 0x00;
  75.     P7M0 = 0x00;
  76.     P7M1 = 0x00;
  77.           P3=0xff;
  78.     ACC = P_SW1;
  79.     ACC &= ~(S1_S0 | S1_S1);    //S1_S0=0 S1_S1=0
  80.     P_SW1 = ACC;                //(P3.0/RxD, P3.1/TxD)
  81.     SCON = 0x50;                //8位可變波特率
  82.     AUXR = 0x40;                //定時器1為1T模式
  83.     TMOD = 0x00;                //定時器1為模式0(16位自動重載)
  84.     TL1 = (65536 - (FOSC/4/BAUD));   //設置波特率重裝值
  85.     TH1 = (65536 - (FOSC/4/BAUD))>>8;
  86.     TR1 = 1;                    //定時器1開始啟動
  87.                 TI = 1;
  88.     ES = 1;                     //使能串口中斷
  89.     EA = 1;
  90. }
  91. void Delay500ms()                //@11.0592MHz
  92. {
  93.         unsigned char i, j, k;
  94.         i = 5;
  95.         j = 3;
  96.         k = 227;
  97.         do
  98.         {
  99.                 do
  100.                 {
  101.                         while (--k);
  102.                 } while (--j);
  103.         } while (--i);
  104. }
  105. void main( )
  106. {
  107.      unsigned char status,i,j;
  108.                  unsigned int temp;
  109.      InitializeSystem( );
  110.            printf("RFID Testing!\n");
  111.      PcdReset();
  112.      PcdAntennaOff();
  113.      PcdAntennaOn();
  114.      while ( 1 )
  115.      {
  116.         //                                         Delay500ms();
  117.
  118.                                  {
  119.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  120.          if (status != MI_OK)
  121.          {
  122.                                                  Delay500ms();
  123.                                            LED_GREEN=!LED_GREEN;
  124.                                         //         printf("RFID reading\n");
  125.                                                  PcdReset();
  126.                                                  PcdAntennaOff();
  127.                                                  PcdAntennaOn();
  128.                                                  continue;
  129.          }
  130. //                                 printf("card nub=");
  131. //         for(i=0;i<4;i++)
  132. //                                        {
  133. //                                                 temp=g_ucTempbuf[i];
  134. //                                                 printf("%x",temp);
  135. //                                        }
  136.                                  printf("\n");
  137.                                  Delay500ms();
  138.          status = PcdAnticoll(g_ucTempbuf);//防沖撞
  139.          if (status != MI_OK)
  140.           {
  141.                                                  continue;
  142.                                         }
  143.
  144.                                         ////////以下為超級終端打印出的內容////////////////////////
  145.
  146.                                         printf("card serial-1:");        //超級終端顯示,
  147.                                         for(i=0;i<4;i++)
  148.                                         {
  149.                                                 temp=g_ucTempbuf[i];
  150.                                                 printf("%x",temp);
  151.
  152.                                         }
  153.                                         printf("\n");
  154.
  155.          status = PcdSelect(g_ucTempbuf);//選定卡片
  156.          if (status != MI_OK)
  157.                                                 {
  158.                                                         continue;
  159.                                                 }
  160. //                                        ////////以下為超級終端打印出的內容////////////////////////
  161. //
  162. //                                        printf("card serial-2:");        //超級終端顯示,
  163. //                                        for(i=0;i<4;i++)
  164. //                                        {
  165. //                                                temp=g_ucTempbuf[i];
  166. //                                                printf("%x",temp);
  167. //
  168. //                                        }
  169. //                                        printf("\n");
  170.
  171.                                         ///////////////////////////////////////////////////////////
  172.                                 }
  173.                         }
  174. }
  175.
  176. /*
  177.          status = PcdSelect(g_ucTempbuf);//選定卡片
  178.          if (status != MI_OK)
  179.                                                 {
  180.                                                         continue;
  181.                                                 }
  182.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  183.          if (status != MI_OK)
  184.                                                 {
  185.                                                         continue;
  186.                                                 }
  187.
  188.          status = PcdWrite(1, data1);//寫塊
  189.          if (status != MI_OK)
  190.                                                 {
  191.                                                         continue;
  192.                                                 }
  193.                                  while(1)
  194.                                         {
  195.                                                         status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  196.                                                         if (status != MI_OK)
  197.        {
  198.        PcdReset();
  199.        PcdAntennaOff();
  200.        PcdAntennaOn();
  201.        continue;
  202.        }
  203.                                                         status = PcdAnticoll(g_ucTempbuf);//防沖撞
  204.                                                         if (status != MI_OK)
  205.        {
  206.        continue;
  207.        }
  208.                                                         status = PcdSelect(g_ucTempbuf);//選定卡片
  209.                                                         if (status != MI_OK)
  210.        {
  211.        continue;
  212.        }
  213.                                                         status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  214.                                                         if (status != MI_OK)
  215.        {
  216.        continue;
  217.        }
  218.                                                         status = PcdValue(PICC_DECREMENT,1,data2);//扣
  219.                                                         if (status != MI_OK)
  220.        {
  221.        continue;
  222.        }
  223.                                                         status = PcdBakValue(1, 2);//塊備份
  224.                                                         if (status != MI_OK)
  225.        {
  226.        continue;
  227.        }
  228.                                                         status = PcdRead(2, g_ucTempbuf);//讀塊
  229.                                                         if (status != MI_OK)
  230.        {
  231.        continue;
  232.        }
  233.                                                         printf("read block:");        //超級終端顯示,
  234.                                                         for(i=0;i<16;i++)
  235.        {
  236.        temp=g_ucTempbuf[i];
  237.        printf("%x",temp);
  238.        }
  239.                                                         LED_GREEN = 0;
  240.                                                         for(i=0;i<250;i++)//先輸出一種頻率的聲音
  241.        {
  242.        for(j=0;j<80;j++);
  243.         // Speaker=~Speaker;
  244.        }
  245.                                                         delay1(100);
  246.                                                         LED_GREEN = 1;
  247.                                                         delay1(100);
  248.                                                         LED_GREEN = 0;
  249.                                                         delay1(200);
  250.                                                         LED_GREEN = 1;
  251.                                                         PcdHalt();
  252.                                                         }
  253.     }
  254.
  255. }*/
MFRC522_STC.rar (78.65 KB, 下載次數: 38)
ID:316061 發表于 2020-3-17 14:06 | 只看該作者
很好的資料,不錯,學習一下。
