【注】德州儀器的官網(wǎng)上的msp430fr6989單片機(jī)上有一塊lcd,其有40個引腳,分別兩邊各有20個引腳排布。學(xué)過stm32的能很快掌握lcd的寄存器模式下寫成的代碼,但是新手最好入門庫函數(shù)一類,如果時(shí)間很緊迫的情況下。板上是0-7的行,分為上半屏和下半屏。列有LCDM1-LCDM20,總共有8*20=160個segment。在前面的帖子中,對引腳的定義是通過寄存器進(jìn)行定義的,而如果我要讓流水燈亮起來就可以把寄存器及地址寫在一個函數(shù)內(nèi),包裝起來,直接在官網(wǎng)上找的代碼,很豐富,學(xué)這個很快。比如以下:
- <p>//定義輸出引腳
- void GPIO_setAsOutputPin(uint8_t selectedPort,
- uint16_t selectedPins) {
- uint16_t baseAddress = GPIO_PORT_TO_BASE[selectedPort];</p><p> #ifndef NDEBUG
- if(baseAddress == 0xFFFF)
- return;
- #endif</p><p> // Shift by 8 if port is even (upper 8-bits)
- if((selectedPort & 1) ^ 1)
- selectedPins <<= 8;
- }</p><p> HWREG16(baseAddress + OFS_PASEL0) &= ~selectedPins;
- HWREG16(baseAddress + OFS_PASEL1) &= ~selectedPins;
- HWREG16(baseAddress + OFS_PADIR) |= selectedPins;</p><p> return;
- }</p><p>
- </p><p>
- </p><p>Init_GPIO();
- GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN1);
- GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN2);</p><font size="5"><p>void Init_GPIO(void)
- // Set all GPIO pins to output low to prevent floating input and reduce power consumption
- GPIO_setOutputLowOnPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P5, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P6, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P7, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P8, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setOutputLowOnPin(GPIO_PORT_P9, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P5, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P6, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P7, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P8, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsOutputPin(GPIO_PORT_P9, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
- GPIO_setAsInputPin(GPIO_PORT_P3, GPIO_PIN5);
- // Configure button S1 (P1.1) interrupt
- GPIO_selectInterruptEdge(GPIO_PORT_P1, GPIO_PIN1, GPIO_HIGH_TO_LOW_TRANSITION);
- GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN1);
- GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN1);
- // Configure button S2 (P1.2) interrupt
- GPIO_selectInterruptEdge(GPIO_PORT_P1, GPIO_PIN2, GPIO_HIGH_TO_LOW_TRANSITION);
- GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN2);
- GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN2);
- // Set P4.1 and P4.2 as Secondary Module Function Input, LFXT.
- GPIO_setAsPeripheralModuleFunctionInputPin(
- GPIO_PORT_PJ,
- GPIO_PIN4 + GPIO_PIN5,
- GPIO_PRIMARY_MODULE_FUNCTION
- // Disable the GPIO power-on default high-impedance mode
- // to activate previously configured port settings
- PMM_unlockLPM5();</p><p>}</p></font><p>
- </p>
復(fù)制代碼 下面有開箱的源代碼。【禁止商業(yè)用途】
(14.12 KB, 下載次數(shù): 201)
2019-7-28 23:46 上傳
(50.97 KB, 下載次數(shù): 187)
2019-7-28 23:46 上傳
(24.09 KB, 下載次數(shù): 204)
2019-7-28 23:46 上傳
(49.66 KB, 下載次數(shù): 198)
2019-7-28 23:46 上傳
(61.78 KB, 下載次數(shù): 202)
2019-7-28 23:46 上傳
(100.81 KB, 下載次數(shù): 189)
2019-7-28 23:46 上傳
(104.65 KB, 下載次數(shù): 192)
2019-7-28 23:46 上傳
(106.71 KB, 下載次數(shù): 179)
2019-7-28 23:46 上傳
(97.66 KB, 下載次數(shù): 176)
2019-7-28 23:46 上傳
(57.39 KB, 下載次數(shù): 171)
2019-7-28 23:46 上傳
(68.78 KB, 下載次數(shù): 196)
2019-7-28 23:46 上傳
(63.87 KB, 下載次數(shù): 221)
2019-7-28 23:46 上傳
(57.19 KB, 下載次數(shù): 178)
2019-7-28 23:46 上傳
(57.56 KB, 下載次數(shù): 207)
2019-7-28 23:46 上傳
(49.11 KB, 下載次數(shù): 177)
2019-7-28 23:46 上傳
(44.47 KB, 下載次數(shù): 257)
2019-7-28 23:46 上傳
(54.74 KB, 下載次數(shù): 185)
2019-7-28 23:46 上傳
(57.35 KB, 下載次數(shù): 175)
2019-7-28 23:46 上傳
(93.68 KB, 下載次數(shù): 165)
2019-7-28 23:46 上傳
(53.3 KB, 下載次數(shù): 179)
2019-7-28 23:46 上傳
(36.26 KB, 下載次數(shù): 179)
2019-7-28 23:46 上傳
(30.67 KB, 下載次數(shù): 189)
2019-7-28 23:46 上傳
(44.98 KB, 下載次數(shù): 185)
2019-7-28 23:46 上傳
OutOfBox_MSP430FR6989.7z
2019-7-29 00:50 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
1.49 MB, 下載次數(shù): 38, 下載積分: 黑幣 -5
