麻煩大家看看 我寫(xiě)的這個(gè)程序 測(cè)量方波頻率沒(méi)什么問(wèn)題可是測(cè)量其他波形頻率的時(shí)候 誤差很大
順便想問(wèn)問(wèn)測(cè)量脈寬的思路是什么?
- #include <reg52.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit DU = P2^6;//數(shù)碼管段選
- sbit WE = P2^7;//數(shù)碼管段選
- sbit LED1 = P1^0;//LED1
- //共陰數(shù)碼管段選表0-9
- uchar code tabel[]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F,};
- long uint mSec;//毫秒和秒儲(chǔ)存變量
- long uint freq;
- 函數(shù) : delay(uint z)
- 參數(shù) :z 延時(shí)毫秒設(shè)定,取值范圍0-65535
- 返回值 :無(wú)
- 描述 :12T/Fosc11.0592M毫秒級(jí)延時(shí)
- void delay(uint z)
- uint x,y;
- for(x = z; x > 0; x--)
- for(y = 114; y > 0 ; y--);
- 函數(shù) :display(uchar i)
- 參數(shù) :i 顯示數(shù)值,取值范圍0-255
- 返回值 :無(wú)
- 描述 :三位共陰數(shù)碼管動(dòng)態(tài)顯示
- void display(uchar i)
- uchar A,B,C,D,E,F,G,H;
- A = i % 100000000 / 1000000;
- B = i % 10000000 / 1000000;
- C = i % 1000000 / 100000;
- D = i % 100000 / 10000;
- E = i % 10000 / 1000;
- F = i % 1000 / 100; //236 / 100 = 2
- G = i % 100 / 10; //236 % 100 / 10 = 3
- H = i % 10;//236 % 10 =6
- //第一位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- WE = 1;//打開(kāi)位選鎖存器
- P0 = 0XFE; //1111 1110
- WE = 0;//鎖存位選數(shù)據(jù)
- DU = 1;//打開(kāi)段選鎖存器
- P0 = tabel[A];//
- DU = 0;//鎖存段選數(shù)據(jù)
- delay(1);
- //第二位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0XFD; //1111 1101
- P0 = tabel[B];//
- delay(1);
- //第三位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0XFB; //1111 1011
- P0 = tabel[C];//
- delay(1);
- //第四位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0XF7; //1111 1101
- P0 = tabel[D];//
- delay(1);
- //第五位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0XEF; //1111 1101
- P0 = tabel[E];//
- delay(1);
- //第六位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0XDF; //1111 1101
- P0 = tabel[F];//
- delay(1);
- //第七位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0XBF; //1111 1101
- DU = 1;
- P0 = tabel[G];
- delay(1);
- //第八位數(shù)碼管
- P0 = 0XFF;//清除斷碼
- P0 = 0X7F; //1111 1101
- DU = 1;
- P0 = tabel[H];//打開(kāi)段選鎖存器
- delay(1);
- void Timer_Config()
- //--定時(shí)器T1做計(jì)數(shù)器,工作方式1(16位定時(shí)器),只由TRx打開(kāi)計(jì)數(shù)器--//
- //--定時(shí)器T0做定時(shí)器,工作方式1(16位定時(shí)器),只由TRx打開(kāi)定時(shí)器--//
- TMOD=0x51;
- //--設(shè)置定時(shí)器晶振為12MHZ時(shí)定時(shí)50ms--//
- TH0=0x4b;//高八位 定時(shí)器
- TL0=0xfd;//低八位
- // TH1=0XFF;//計(jì)數(shù)器
- //TL1=0XFF;//計(jì)數(shù)器
- //--打開(kāi)中斷-//
- ET0=1;
- ET1=1;
- EA=1;
- //--打開(kāi)定時(shí)器*/
- TR0=1;
- TR1=1;
- void main()//main函數(shù)自身會(huì)循環(huán)
- unsigned long z;//設(shè)置一個(gè)局部變量z
- Timer_Config();//進(jìn)入中斷
- while(1)
- if(TR1 == 0) //當(dāng)計(jì)數(shù)器停下的時(shí)候,表明計(jì)數(shù)完畢 判斷是否到達(dá)一秒到達(dá)后讀取TL TH的值
- freq = freq + TL1; //讀取TL的值
- freq = freq + (TH1 * 256); //讀取TH的值 高八位
- z=freq;
- //--顯示完,重新計(jì)算下一次頻率。--//
- freq = 0;//將計(jì)算的頻率清零
- TH1 = 0; //將計(jì)數(shù)器的值清零
- TL1 = 0;
- TR0 = 1; //開(kāi)啟定時(shí)器 TR運(yùn)行寄存器
- TR1 = 1; //開(kāi)啟計(jì)數(shù)器
- display(z); //數(shù)碼管顯示函數(shù)
- *函數(shù)名 :Timer0
- *功 能 :定時(shí)器0的中斷函數(shù)
- *輸 入 :無(wú)
- *輸 出 :無(wú)
- void Timer0() interrupt 1
- //--12MHZ設(shè)置定時(shí)50ms的初值--//
- TH0=0x4b;
- TL0=0xfd;
- LED1=~LED1;
- mSec++;
- if(mSec == 20) //定時(shí)1秒到 20個(gè)50ms等于1秒 1000ms=1s
- TR0=0; //關(guān)閉定時(shí)器
- TR1=0; //關(guān)閉計(jì)數(shù)器
- mSec = 0; //秒數(shù)清零
- *函數(shù)名 :Timer1
- *功 能 :定時(shí)器1的中斷函數(shù)
- *輸 入 :無(wú)
- *輸 出 :無(wú)
- void Timer1() interrupt 3
- //--進(jìn)入一次中斷,表明計(jì)數(shù)到了65536--//
- freq=freq+65536;
- // TH1=0XFF;
- // TL0=0XFF;
