查看: 1822|回復(fù): 1
stc15f2k60s2單片機(jī) pwm程序 可調(diào)占空比
ID:583118 發(fā)表于 2019-7-24 15:51 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <STC15F2K60S2.h>
#define u8 unsigned char
#define u16 unsigned int
sbit PWM = P1^0;
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y,unsigned char *str, unsigned char len);
u8 Trg,Cont;                   //獨(dú)立按鍵
#define KEYPROUT P3
void key_read(void)
u8 ReadData = KEYPROUT^0xff;
Trg = ReadData&(ReadData^Cont);
Cont = ReadData;
void Timer0_Init(void) //1ms   定時(shí)器0初始化
  AUXR |= 0x80; //1T timer
  TMOD &= 0xF0; // 16bit
  TL0 = 0xCD;
  TH0 = 0xD4;
  TF0 = 0;
  TR0 = 1;
  ET0 = 1;
  EA=1;
void Timer1Init(void)  //100微秒@11.0592MHz
AUXR |= 0x40;  //定時(shí)器時(shí)鐘1T模式
TMOD &= 0x0F;  //設(shè)置定時(shí)器模式
TL1 = 0xAE;  //設(shè)置定時(shí)初值
TH1 = 0xFB;  //設(shè)置定時(shí)初值
TF1 = 0;  //清除TF1標(biāo)志
TR1 = 1;  //定時(shí)器1開始計(jì)時(shí)
ET1 = 1;
bit key_flag,timer_500ms_flag;
u8 pwm_set=5;
u8 str[15];
void main(void)
  P2=0xa0;P0=0x00;P2=0x00;    // 關(guān)閉蜂鳴器
  Timer0_Init();              //1ms   定時(shí)器0初始化
  Timer1Init();
  InitLcd1602();
  if(timer_500ms_flag)
   timer_500ms_flag=0;
   LcdShowStr(0,0,str,1);
  str[0] = pwm_set + '0';
  if(key_flag)     // 按鍵掃描
    key_flag=0;
    key_read();
    if(Trg&0x08)//s4
      pwm_set++;
    if(Trg&0x04)//s5
     pwm_set--;
    if(Trg&0x02)//s6
    if(Trg&0x01)//s7
    if(Cont)     //按鍵按下
    if(Trg==0&Cont==0) //按鍵放開
void timer0() interrupt 1  using 1
static int key_count=0,timer_500ms=0;
key_count++;timer_500ms++;
if(key_count==10)   //10ms 按鍵掃描
  key_count=0;
  key_flag=1;
if(timer_500ms==500)
  timer_500ms=0;
  timer_500ms_flag=1;
void timer1() interrupt 3
static u8 pwm_count=0;
pwm_count++;
if(pwm_count==pwm_set)
  PWM=0;
if(pwm_count==10)
  pwm_count=0;
  PWM=1;
#include <reg52.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P2^0;
sbit LCD1602_RW = P2^1;
sbit LCD1602_E  = P1^2;
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測(cè)直到其等于0為止
/* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標(biāo)位置,(x,y)-對(duì)應(yīng)屏幕上的字符坐標(biāo) */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標(biāo)計(jì)算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對(duì)應(yīng)屏幕上的起始坐標(biāo),
   str-字符串指針,len-需顯示的字符長度 */
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (len--)         //連續(xù)寫入len個(gè)字符數(shù)據(jù)
        LcdWriteDat(*str++);  //先取str指向的數(shù)據(jù),然后str自加1
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標(biāo)關(guān)閉
    LcdWriteCmd(0x06);  //文字不動(dòng),地址自動(dòng)+1
    LcdWriteCmd(0x01);  //清屏
ID:1 發(fā)表于 2019-7-24 16:51 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
