查看: 2539|回復: 0
關于電子秤ADC0832模塊程序在proteus8.6中無法運行 求幫助
ID:588465 發表于 2019-7-24 15:24 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#include <string.h>
#include "main.h"
#include "eeprom52.h"
#define uint  unsigned int
unsigned char ad_data,k,n,m,e,num,s;
sbit ADCS =P1^4;
sbit ADDI =P1^2;
sbit ADDO =P1^2;
sbit ADCLK =P1^3;
unsigned long Weight_Maopi = 0;
unsigned long Weight_Maopi_0 = 0;
long Weight_Shiwu = 0;
unsigned int qupi=0;
//鍵盤處理變量
unsigned char keycode;
unsigned char key_press_num=0;
uint GapValue,GapValue1;
#define LCD1602_PORT P0
sbit LCD1602_RS = P2^5;
sbit LCD1602_RW = P2^6;
sbit LCD1602_EN = P2^7;
//定義標識
volatile bit FlagTest = 0;                //定時測試標志,每0.5秒置位,測完清0
volatile bit FlagKeyPress = 0;  //有鍵按下標志,處理完畢清0
//校準參數
//因為不同的傳感器特性曲線不是很一致,因此,每一個傳感器需要矯正這里這個參數才能使測量值很準確。
//當發現測試出來的重量偏大時,增加該數值。
//如果測試出來的重量偏小時,減小改數值。
//該值可以為小數
//#define GapValue 349
sbit LED=P1^1;
sbit ROW1=P3^0;
sbit ROW2=P3^1;
sbit ROW3=P3^2;
sbit ROW4=P3^3;
volatile bit ClearWeighFlag = 0; //傳感器調零標志位,清除0漂
void LCD1602_delay_ms(unsigned int n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
//寫指令
void LCD1602_write_com(unsigned char com)
        LCD1602_RS = 0;
        LCD1602_delay_ms(1);
        LCD1602_EN = 1;
        LCD1602_PORT = com;
        LCD1602_EN = 0;
//寫數據
void LCD1602_write_data(unsigned char dat)
        LCD1602_RS = 1;
        LCD1602_PORT = dat;
        LCD1602_EN = 1;
        LCD1602_EN = 0;
//連續寫字符
void LCD1602_write_word(unsigned char *s)
        while(*s>0)
                LCD1602_write_data(*s);
                s++;
void Init_LCD1602()
        LCD1602_EN = 0;
        LCD1602_RW = 0;                                                //設置為寫狀態
        LCD1602_write_com(0x38);                        //顯示模式設定
        LCD1602_write_com(0x0c);                        //開關顯示、光標有無設置、光標閃爍設置
        LCD1602_write_com(0x06);                        //寫一個字符后指針加一
        LCD1602_write_com(0x01);                        //清屏指令
/******************把數據保存到單片機內部eeprom中******************/
void write_eeprom()
        SectorErase(0x2000);
        GapValue1=GapValue&0x00ff;
        byte_write(0x2000, GapValue1);
        GapValue1=(GapValue&0xff00)>>8;
        byte_write(0x2001, GapValue1);
        byte_write(0x2060, a_a);
/******************把數據從單片機內部eeprom中讀出來*****************/
void read_eeprom()
        GapValue   = byte_read(0x2001);
        GapValue   = (GapValue<<8)|byte_read(0x2000);
        a_a      = byte_read(0x2060);
/**************開機自檢eeprom初始化*****************/
void init_eeprom()
        read_eeprom();                //先讀
        if(a_a != 1)                //新的單片機初始單片機內問eeprom
                GapValue  = 3500;
                a_a = 1;
                write_eeprom();           //保存數據
//顯示重量,單位kg,兩位整數,三位小數
void Display_Weight()
        LCD1602_write_com(0x80+0x40+8);
        if(Weight_Shiwu/10000==0)
        LCD1602_write_data(' ');
        LCD1602_write_data(Weight_Shiwu/10000 + 0x30);
        LCD1602_write_data(Weight_Shiwu%10000/1000 + 0x30);
        LCD1602_write_data('.');
        LCD1602_write_data(Weight_Shiwu%1000/100 + 0x30);
        LCD1602_write_data(Weight_Shiwu%100/10 + 0x30);
        LCD1602_write_data(Weight_Shiwu%10 + 0x30);
//定時器0初始化
void Timer0_Init()
        ET0 = 1;        //允許定時器0中斷
        TMOD = 1;       //定時器工作方式選擇
        TL0 = 0xb0;
        TH0 = 0x3c;     //定時器賦予初值
        TR0 = 1;        //啟動定時器
//定時器0中斷
void Timer0_ISR (void) interrupt 1 using 0
        uchar Counter;
        TL0 = 0xb0;
        //每0.5秒鐘刷新重量
    Counter ++;
    if (Counter >= 10)
       FlagTest = 1;
           Counter = 0;
//按鍵響應程序,參數是鍵值
//返回鍵值:
//         7          8    9      10(清0)
//         4          5    6      11(刪除)
//         1          2    3      12(未定義)
//         14(未定義) 0    15(.)  13(確定價格)
void KeyPress()
        if(ROW1==0)   //去皮鍵
                Delay_ms(5);
                if(ROW1==0)
//                        Get_Maopi();
                        if(qupi==0)
                        qupi=Weight_Shiwu;
                        qupi=0;
                        Buzzer=0;
                        Delay_ms(50);
                        Buzzer=1;
                        while(ROW1==0);
        if(ROW2==0)           //加
                Delay_ms(5);
                if(ROW2==0)
                        while(!ROW2)
                                key_press_num++;
                                if(key_press_num>=100)
                                        key_press_num=0;
                                        while(!ROW2)
                                                if(GapValue<10000)
                                                GapValue+=10;
                                                Buzzer=0;
                                                Delay_ms(10);
                                                Buzzer=1;
                                                Delay_ms(10);
                                                Get_Weight();
                                Delay_ms(10);
                        if(key_press_num!=0)
                                key_press_num=0;
                                if(GapValue<10000)
                                GapValue++;
                                Buzzer=0;
                                Delay_ms(50);
                                Buzzer=1;
                        write_eeprom();
        if(ROW3==0)  //減
                Delay_ms(5);
                if(ROW3==0)
                        while(!ROW3)
                                key_press_num++;
                                        key_press_num=0;
                                        while(!ROW3)
                                                if(GapValue>1)
                                                GapValue-=10;
                                                Buzzer=0;
                                                Delay_ms(10);
                                                Buzzer=1;
                                                Delay_ms(10);
                                                Get_Weight();
                                Delay_ms(10);
                                key_press_num=0;
                                if(GapValue>1)
                                GapValue--;
                                Buzzer=0;
                                Delay_ms(50);
                                Buzzer=1;
                        write_eeprom();                           //保存數?
uchar Adc0832(unsigned char channel)     //AD轉換,返回結果
     uchar i=0;
    uchar j;
    uint dat=0;
    uchar ndat=0;
    if(channel==0)channel=2;
    if(channel==1)channel=3;
    ADDI=1;
    _nop_();
    _nop_();
    ADCS=0;//拉低CS端
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿1
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=channel&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿2
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=(channel>>1)&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿3
    ADDI=1;//控制命令結束
    _nop_();
    _nop_();
    dat=0;
    for(i=0;i<8;i++)
        dat|=ADDO;//收數據
        ADCLK=1;
        _nop_();
        _nop_();
        ADCLK=0;//形成一次時鐘脈沖
        _nop_();
        _nop_();
        dat<<=1;
        if(i==7)dat|=ADDO;
    for(i=0;i<8;i++)
        j=0;
        j=j|ADDO;//收數據
        ADCLK=1;
        _nop_();
        _nop_();
        ADCLK=0;//形成一次時鐘脈沖
        _nop_();
        _nop_();
        j=j<<7;
        ndat=ndat|j;
        if(i<7)ndat>>=1;
    ADCS=1;//拉低CS端
    ADCLK=0;//拉低CLK端
    ADDO=1;//拉高數據端,回到初始狀態
    dat<<=8;
    dat|=ndat;
    return(dat);            //return ad k
//主函數
        init_eeprom();  //開始初始化保存的數據
        Init_LCD1602();        //初始化LCD1602
   EA = 0;
   Timer0_Init();
   //初中始化完成,開斷
   EA = 1;
//        Get_Maopi();
   LCD1602_write_com(0x80);                                                //指針設置
   LCD1602_write_word(" Welcome To Use ");        //
   LCD1602_write_com(0x80+0x40);                                                //指針設置
   LCD1602_write_word("Electronic Scale");
//   Delay_ms(2000);
   Get_Maopi();
   LCD1602_write_word("The Weight:     ");
   LCD1602_write_word("         0.000kg");
//        Get_Maopi();                                //稱毛皮重量
//每0.5秒稱重一次
                if (FlagTest==1)
                        Get_Weight();
                        FlagTest = 0;
                KeyPress();
//稱重
void Get_Weight()
        Weight_Shiwu = Adc0832(0);
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                //獲取凈重
        Weight_Shiwu = (unsigned int)((float)(Weight_Shiwu*10)/GapValue)-qupi;         //計算實物的實際重量
        if(Weight_Shiwu >= 10000)                //超重報警
                Buzzer = !Buzzer;
                LED=!LED;
           LCD1602_write_word("--.---");
                if(Weight_Shiwu==0)
                LED=0;
                else if(Weight_Shiwu>0)
                LED=1;
                Buzzer = 1;
                Display_Weight();
//獲取毛皮重量
void Get_Maopi()
        unsigned char clear;
mm:        Weight_Maopi_0 = Adc0832(0);
        for(clear=0;clear<10;clear++)
                Buzzer=1;
                LED=0;
                Delay_ms(100);
                LED=1;
                Delay_ms(100);
        Weight_Maopi = Adc0832(0);
        if(Weight_Maopi/GapValue!=Weight_Maopi_0/GapValue)
        goto mm;
        Buzzer=0;
        Delay_ms(500);
        Buzzer=1;
//MS延時函數(12M晶振下測試)
void Delay_ms(unsigned int n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<121;j++);
