#include<reg52.h> #include<intrins.h> #define uint unsigned int #define uchar unsigned char sbit leds=P1^4; sbit dula=P2^6; sbit wela=P2^7; uchar temp,aa,num; uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6b,0x7d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; //表格的定義 void delay(uint z); void main() { leds=0; num=0; aa=0;//初始化 TMOD=0x01; TH0=(65535-50000)/256; TL0=(65535-50000)%256; EA=1;//開總中斷 ET0=1;//開定時器中斷 TR0=1;//起動定時器 temp=0xfe; P0=temp;// dula=1; P0=table[0]; dula=0; wela=1; P0=0xc0; wela=0;
while(1) { delay(1000); temp=_crol_(temp,1); P0=temp; } } void delay(uint z)//延時 { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void timer0() interrupt 1 { TH0=(65535-50000)/256; TL0=(65535-50000)%256; aa++; if(aa==40) { aa=0; num++; if(num==16) num=0; dula=1; P0=table[num]; dula=0;//以上3, }
