//包含頭文件
#include <REG51.h>
#include<intrins.h>
//宏定義
#define LCM_Data P0 //將P0口定義為L(zhǎng)CM_Data
//1602的控制腳
sbit lcd1602_rs=P2^6;
sbit lcd1602_rw=P2^5;
sbit lcd1602_en=P2^7;
sbit Scl=P2^1; //24C02串行時(shí)鐘
sbit Sda=P2^0; //24C02串行數(shù)據(jù)
sbit IRIN=P3^2; //紅外
sbit ALAM = P3^7; //報(bào)警
sbit LOC = P3^6; //開鎖
bit pass=0; //密碼正確標(biāo)志
bit ReInputEn=0; //重置輸入允許標(biāo)志
bit s3_keydown=0; //3秒按鍵標(biāo)志位
bit key_disable=0; //鎖定鍵盤標(biāo)志
unsigned char code CDIS1[13]={" Red Control "};
unsigned char code CDIS2[13]={" IR-CODE:--H "};
unsigned char IrValue[6];
unsigned char Time;
unsigned char kky;
unsigned char countt0,second; //t0中斷計(jì)數(shù)器,秒計(jì)數(shù)器
unsigned char Time;
void Delay5Ms(void); //聲明延時(shí)函數(shù)
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
//液晶顯示數(shù)據(jù)數(shù)組
unsigned char code start_line[] = {"password: "};
unsigned char code name[] = {"===Coded Lock==="}; //顯示名稱
unsigned char code Correct[] = {" correct "}; //輸入正確
unsigned char code Error[] = {" error "}; //輸入錯(cuò)誤
unsigned char code codepass[] = {" pass "};
unsigned char code LockOpen[] = {" open "}; //OPEN
unsigned char code SetNew[] = {"SetNewWordEnable"};
unsigned char code Input[] = {"input: "}; //INPUT
unsigned char code ResetOK[] = {"ResetPasswordOK "};
unsigned char code initword[] = {"Init password..."};
unsigned char code Er_try[] = {"error,try again!"};
unsigned char code again[] = {"input again "};
unsigned char InputData[6]; //輸入密碼暫存區(qū)
unsigned char CurrentPassword[6]={0,0,0,0,0,0}; //讀取EEPROM密碼暫存數(shù)組
unsigned char TempPassword[6];
unsigned char N=0; //密碼輸入位數(shù)記數(shù)
unsigned char ErrorCont; //錯(cuò)誤次數(shù)計(jì)數(shù)
unsigned char CorrectCont; //正確輸入計(jì)數(shù)
unsigned char ReInputCont; //重新輸入計(jì)數(shù)
unsigned char code initpassword[6]={0,0,0,0,0,0}; //輸入管理員密碼后將密碼初始為000000
unsigned char code adminpassword[6]={1,3,1,4,2,0}; //輸入管理員密碼后將密碼初始為000000
* 函數(shù)名 : DelayMs()
* 函數(shù)功能 : 延時(shí)
* 輸入 : x
* 輸出 : 無(wú)
void DelayMs(unsigned int x) //0.14ms誤差 0us
unsigned char i;
while(x--)
for (i = 0; i<13; i++)
//=====================5ms延時(shí)==============================
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//===================400ms延時(shí)==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延時(shí)
uchar i;
while(t--)
for(i=0;i<125;i++)
void Nop(void) //空操作
_nop_(); //僅作延時(shí)用一條語(yǔ)句大約1us
_nop_();
_nop_();
_nop_();
/*****24c02程序參照24c02時(shí)序圖*****/
/*起始條件*/
void Start(void)
Sda=1;
Scl=1;
Nop();
Sda=0;
Nop();
/*停止條件*/
void Stop(void)
Sda=0;
Scl=1;
Nop();
Sda=1;
Nop();
/*應(yīng)答位*/
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
/*反向應(yīng)答位*/
void NoAck(void)
Sda=1;
Nop();
Scl=1;
Nop();
Scl=0;
/*發(fā)送數(shù)據(jù)子程序,Data為要求發(fā)送的數(shù)據(jù)*/
void Send(uchar Data)
uchar BitCounter=8;
uchar temp;
do
temp=Data; //將待發(fā)送數(shù)據(jù)暫存temp
Scl=0;
Nop();
if((temp&0x80)==0x80) //將讀到的數(shù)據(jù)&0x80
Sda=1;
Sda=0;
Scl=1;
temp=Data<<1; //數(shù)據(jù)左移
Data=temp; //數(shù)據(jù)左移后重新賦值Data
BitCounter--; //該變量減到0時(shí),數(shù)據(jù)也就傳送完成了
while(BitCounter); //判斷是否傳送完成
Scl=0;
/*讀一字節(jié)的數(shù)據(jù),并返回該字節(jié)值*/
uchar Read(void)
uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do
Scl=0;
Nop();
Scl=1;
Nop();
if(Sda) //數(shù)據(jù)位是否為1
temp=temp|0x01; //為1 temp的最低位為1(|0x01,就是將最低位變?yōu)?)
else //如果為0
temp=temp&0xfe; //temp最低位為0(&0xfe(11111110)最低位就是0)
if(BitCounter-1) //BitCounter減1后是否為真
temp1=temp<<1; //temp左移
temp=temp1;
BitCounter--; //BitCounter減到0時(shí),數(shù)據(jù)就接收完了
while(BitCounter); //判斷是否接收完成
return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Send(*(PData+i));
Ack();
Stop();
mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Start();
Send(0xa1);
Ack();
*(PData+i)=Read();
Scl=0;
NoAck();
Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因?yàn)長(zhǎng)CD1602字符地址首位D7恒定為1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因?yàn)榈诙械谝粋(gè)字符位置地址是0x40)
//----------------延時(shí)函數(shù),后面經(jīng)常調(diào)用----------------------
void delay(uint xms)//延時(shí)函數(shù),有參函數(shù)
uint x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
//--------------------------寫指令---------------------------
void write_1602com(uchar com)//****液晶寫入指令函數(shù)****
lcd1602_rs=0;//數(shù)據(jù)/指令選擇置為指令
lcd1602_rw=0; //讀寫選擇置為寫
P0=com;//送入數(shù)據(jù)
delay(1);
lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準(zhǔn)備
delay(1);
lcd1602_en=0;//en由高變低,產(chǎn)生下降沿,液晶執(zhí)行命令
//-------------------------寫數(shù)據(jù)-----------------------------
void write_1602dat(uchar dat)//***液晶寫入數(shù)據(jù)函數(shù)****
lcd1602_rs=1;//數(shù)據(jù)/指令選擇置為數(shù)據(jù)
P0=dat;//送入數(shù)據(jù)
delay(1);
lcd1602_en=1; //en置高電平,為制造下降沿做準(zhǔn)備
delay(1);
lcd1602_en=0; //en由高變低,產(chǎn)生下降沿,液晶執(zhí)行命令
//-------------------------初始化-------------------------
void lcd_init(void)
write_1602com(0x38);//設(shè)置液晶工作模式,意思:16*2行顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
write_1602com(0x0c);//開顯示不顯示光標(biāo)
write_1602com(0x06);//整屏不移動(dòng),光標(biāo)自動(dòng)右移
write_1602com(0x01);//清顯示
//==============將按鍵值編碼為數(shù)值=========================
unsigned char coding(unsigned char m)
unsigned char k;
switch(m)
case (0x11): k=1;break;
case (0x21): k=2;break;
case (0x41): k=3;break;
case (0x81): k='A';break;
case (0x12): k=4;break;
case (0x22): k=5;break;
case (0x42): k=6;break;
case (0x82): k='B';break;
case (0x14): k=7;break;
case (0x24): k=8;break;
case (0x44): k=9;break;
case (0x84): k='C';break;
case (0x18): k='*';break;
case (0x28): k=0;break;
case (0x48): k='#';break;
case (0x88): k='D';break;
return(k);
unsigned char cod_red(unsigned char m)
unsigned char k;
switch(m)
case (0x16): k=0;break;
case (0x0c): k=1;break;
case (0x18): k=2;break;
case (0x5e): k=3;break;
case (0x08): k=4;break;
case (0x1c): k=5;break;
case (0x5a): k=6;break;
case (0x42): k=7;break;
case (0x52): k=8;break;
case (0x4a): k=9;break;//數(shù)字鍵
case (0x40): k='*';break;//左移一位
case (0x43): k='#';break;//右移一位
case (0x46): k='M';break;//時(shí)間設(shè)置
case (0x47): k='B';break;//關(guān)掉聲音
case (0x44): k='K';break;//開鎖
case (0x07): k='E';break;//確認(rèn)
case (0x19): k='D';break;//重置密碼
case (0x45): k='A';break; //未開發(fā)鍵
case (0x15): k='V';break;
case (0x09): k='O';break;
case (0x0D): k='U';break;
IrValue[2]=0x00;
return(k);
//=====================按鍵檢測(cè)并返回按鍵值===============================
unsigned char keynum(void)
unsigned char row,col,i;
P1=0xf0;
if((P1&0xf0)!=0xf0)
Delay5Ms();
Delay5Ms();
if((P1&0xf0)!=0xf0)
row=P1^0xf0; //確定行線
i=0;
P1=a[i]; //精確定位
while(i<4)
if((P1&0xf0)!=0xf0)
col=~(P1&0xff); //確定列線
break; //已定位后提前退出
i++;
P1=a[i];
return 0;
while((P1&0xf0)!=0xf0);
return (row|col); //行線與列線組合后返回
else return 0; //無(wú)鍵按下時(shí)返回0
unsigned char red_num(void)
if((IrValue[2]==0x16)||(IrValue[2]==0x0c)||(IrValue[2]==0x18)||(IrValue[2]==0x5e)||(IrValue[2]==0x08)||(IrValue[2]==0x1c)||(IrValue[2]==0x5a)||(IrValue[2]==0x42)||(IrValue[2]==0x52)||(IrValue[2]==0x4a)||(IrValue[2]==0x40)||(IrValue[2]==0x43)||(IrValue[2]==0x19))
return IrValue[2];
//=======================一聲提示音,表示有效輸入========================
void OneAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
//========================二聲提示音,表示操作成功========================
void TwoAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//========================三聲提示音,表示錯(cuò)誤========================
void ThreeAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//=======================顯示提示輸入=========================
void DisplayChar(void)
unsigned char i;
if(pass==1)
//DisplayListChar(0,1,LockOpen);
write_1602com(er); //在二行開始顯示
for(i=0;i<16;i++)
write_1602dat(LockOpen[i]); //顯示open 開鎖成功
if(N==0)
//DisplayListChar(0,1,Error);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Error[i]); //顯示錯(cuò)誤
//DisplayListChar(0,1,start_line);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line[i]);//顯示開始輸入
//========================重置密碼==================================================
void ResetPassword(void)
unsigned char i;
unsigned char j;
if(pass==0)
pass=0;
DisplayChar(); //顯示錯(cuò)誤
ThreeAlam(); //沒(méi)開鎖時(shí)按下重置密碼報(bào)警3聲
else //開鎖狀態(tài)下才能進(jìn)行密碼重置程序
if(ReInputEn==1) //開鎖狀態(tài)下,ReInputEn置1,重置密碼允許
if(N==6) //輸入6位密碼
ReInputCont++; //密碼次數(shù)計(jì)數(shù)
if(ReInputCont==2) //輸入兩次密碼
for(i=0;i<6;)
if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對(duì)比
i++;
else //如果兩次的密碼不同
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]); //顯示錯(cuò)誤Error
ThreeAlam(); //錯(cuò)誤提示
pass=0; //關(guān)鎖
ReInputEn=0; //關(guān)閉重置功能,
ReInputCont=0;
DisplayChar();
break;
if(i==6)
//DisplayListChar(0,1,ResetOK);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(ResetOK[j]); //密碼修改成功,顯示
TwoAlam(); //操作成功提示
WrToROM(TempPassword,0,6); //將新密碼寫入24C02存儲(chǔ)
ReInputEn=0;
ReInputCont=0;
CorrectCont=0;
Delay400Ms();
lcd_init(); //LCD初始化
write_1602com(yi);//日歷顯示固定符號(hào)從第一行第0個(gè)位置之后開始顯示
for(i=0;i<16;i++)
write_1602dat(name[i]);//向液晶屏寫開機(jī)畫面
else //輸入一次密碼時(shí)
OneAlam();
//DisplayListChar(0, 1, again); //顯示再次輸入一次
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(again[j]); //顯示再輸入一次
for(i=0;i<6;i++)
TempPassword[i]=InputData[i]; //將第一次輸入的數(shù)據(jù)暫存起來(lái)
N=0; //輸入數(shù)據(jù)位數(shù)計(jì)數(shù)器清零
//=======================輸入密碼錯(cuò)誤超過(guò)三過(guò),報(bào)警并鎖死鍵盤======================
void Alam_KeyUnable(void)
P1=0x00;
ALAM=~ALAM; //蜂鳴器一直閃爍鳴響
Delay5Ms();
//=======================取消所有操作============================================
void Cancel(void)
unsigned char i;
unsigned char j;
//DisplayListChar(0, 1, start_line);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(start_line[j]); //顯示開機(jī)輸入密碼界面
TwoAlam(); //提示音
for(i=0;i<6;i++)
InputData[i]=0; //將輸入密碼清零
//關(guān)閉鎖
ALAM=1; //報(bào)警關(guān)
pass=0; //密碼正確標(biāo)志清零
ReInputEn=0; //重置輸入充許標(biāo)志清零
ErrorCont=0; //密碼錯(cuò)誤輸入次數(shù)清零
CorrectCont=0; //密碼正確輸入次數(shù)清零
ReInputCont=0; //重置密碼輸入次數(shù)清零
s3_keydown=0;
key_disable=0; //鎖定鍵盤標(biāo)志清零
N=0; //輸入位數(shù)計(jì)數(shù)器清零
void WORK()
LOC=1;
Delay400Ms();
LOC=0;
//==========================確認(rèn)鍵,并通過(guò)相應(yīng)標(biāo)志位執(zhí)行相應(yīng)功能===============================
void Ensure(void)
unsigned char i,j,m=150;
RdFromROM(CurrentPassword,0,6); //從24C02里讀出存儲(chǔ)密碼
if(N==6)
if(ReInputEn==0) //重置密碼功能未開啟
for(i=0;i<6;)
if(CurrentPassword[i]==InputData[i]) //判斷輸入密碼和24c02中的密碼是否相同
i++; //相同一位 i就+1
else //如果有密碼不同
ErrorCont++; //錯(cuò)誤次數(shù)++
if(ErrorCont==3) //錯(cuò)誤輸入計(jì)數(shù)達(dá)三次時(shí),報(bào)警并鎖定鍵盤
write_1602com(er);
for(i=0;i<16;i++)
do
Alam_KeyUnable(),Delay400Ms();
while(m--);
else //錯(cuò)誤次數(shù)小于3次時(shí),鎖死鍵盤3秒,然后重新可以輸入
TR1=1; //開啟定時(shí)
key_disable=1; //鎖定鍵盤
pass=0; //pass位清零
break; //跳出
if(i==6) //密碼輸入對(duì)時(shí)
if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
WrToROM(initpassword,0,6); //強(qiáng)制將初始密碼寫入24C02存儲(chǔ)
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(initword[j]); //顯示初始化密碼
TwoAlam(); //成功提示音
Delay400Ms(); //延時(shí)400ms
TwoAlam(); //成功提示音
CorrectCont++; //輸入正確變量++
if(CorrectCont==1) //正確輸入計(jì)數(shù),當(dāng)只有一次正確輸入時(shí),開鎖
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(LockOpen[j]); //顯示open開鎖畫面
TwoAlam(); //操作成功提示音
WORK(); //開鎖
pass=1; //置正確標(biāo)志位
TR1=1; //開啟定時(shí)
for(j=0;j<6;j++) //將輸入清除
InputData[i]=0; //開鎖后將輸入位清零
else //當(dāng)兩次正確輸入時(shí),開啟重置密碼功能
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(SetNew[j]); //顯示重置密碼界面
TwoAlam(); //操作成功提示
ReInputEn=1; //允許重置密碼輸入
CorrectCont=0; //正確計(jì)數(shù)器清零
else //=========================當(dāng)?shù)谝淮问褂没蛲浢艽a時(shí)可以用131420對(duì)其密碼初始化============
write_1602com(er);
for(j=0;j<16;j++)
TwoAlam(); //成功提示音
TwoAlam(); //成功提示音
WORK();
else //密碼輸入錯(cuò)誤
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]); //顯示錯(cuò)誤信息
ThreeAlam(); //錯(cuò)誤提示音
pass=0;
else //當(dāng)已經(jīng)開啟重置密碼功能時(shí),而按下開鎖鍵,
//DisplayListChar(0,1,Er_try);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Er_try[j]); //錯(cuò)誤,請(qǐng)重新輸入
else //密碼沒(méi)有輸入到6位時(shí),按下確認(rèn)鍵時(shí)
write_1602com(er);
for(j=0;j<16;j++)
pass=0;
N=0; //將輸入數(shù)據(jù)計(jì)數(shù)器清零,為下一次輸入作準(zhǔn)備
//==============================紅外顯示函數(shù)==============================
//==============================主函數(shù)===============================
void main(void)
unsigned char KEY,NUM,RED;
unsigned char i,j;
P1=0xFF; //P1口復(fù)位
IT0=1;//下降沿觸發(fā)
EX0=1;//打開中斷0允許
EA=1; //打開總中斷
IRIN=1;//初始化端口
TMOD=0x11; //定義工作方式
TL1=0xB0;
TH1=0x3C; //定時(shí)器賦初值
EA=1; //打開中斷總開關(guān)
ET1=1; //打開中斷允許開關(guān)
TR1=0; //打開定時(shí)器開關(guān)
Delay400Ms(); //啟動(dòng)等待,等LCM講入工作狀態(tài)
LOC=0;
for(i=0;i<16;i++)
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line[i]);//寫輸入密碼等待界面
write_1602com(er+9); //設(shè)置光標(biāo)位置
write_1602com(0x0f); //設(shè)置光標(biāo)為閃爍
Delay5Ms(); //延時(shí)片刻(可不要)
N=0; //初始化數(shù)據(jù)輸入位數(shù)
while(1) //進(jìn)入循環(huán)
if(key_disable==1) //鎖定鍵盤標(biāo)志為1時(shí)
Alam_KeyUnable(); //報(bào)警鍵盤鎖
ALAM=1; //關(guān)報(bào)警
RED=red_num();
if(RED!=0) //當(dāng)有按鍵按下時(shí)
second=0; //秒清零
else //沒(méi)有鎖定鍵盤時(shí)
NUM=cod_red(IrValue[2]); //根據(jù)按鍵的位置將其編碼,編碼值賦值給NUM
switch(NUM) //判斷按鍵值
case ('A'): ; break;
case ('B'): ; break;
case ('C'):
for(i=0;i<16;i++)
if(N>=1) N--; OneAlam(); //按鍵提示音
//DisplayOneChar(6+N,1,'*');
for(j=N;j<16;j++)
write_1602com(er+6+j);
write_1602dat(' ');
for(j=0;j<N;j++)
write_1602com(er+6+j); //顯示位數(shù)隨輸入增加而增加
write_1602dat('*'); //但不顯示實(shí)際數(shù)字,用*代替
InputData[N]=N+4;
break; //ABC是無(wú)定義按鍵
case ('D'): ResetPassword(); break; //重新設(shè)置密碼
case ('*'): Cancel(); break; //取消當(dāng)前輸入
case ('#'): Ensure(); break; //確認(rèn)鍵,
default: //如果不是功能鍵按下時(shí),就是數(shù)字鍵按下
//DisplayListChar(0,1,Input);
if(N<6) //當(dāng)輸入的密碼少于6位時(shí),接受輸入并保存,大于6位時(shí)則無(wú)效。
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Input[i]); //顯示輸入畫面
OneAlam(); //按鍵提示音
for(j=0;j<=N;j++)
InputData[N]=NUM; //將數(shù)字鍵的碼賦值給InputData[]數(shù)組暫存
N++; //密碼位數(shù)加
else //輸入數(shù)據(jù)位數(shù)大于6后,忽略輸入
N=6; //密碼輸入大于6位時(shí),不接受輸入
break;
} RED=0;
KEY=keynum(); //讀按鍵的位置碼
if(KEY!=0) //當(dāng)有按鍵按下時(shí)
second=0; //秒清零
NUM=coding(KEY); //根據(jù)按鍵的位置將其編碼,編碼值賦值給NUM
switch(NUM) //判斷按鍵值
case ('C'):
for(i=0;i<16;i++)
for(j=N;j<16;j++)
write_1602dat(' ');
for(j=0;j<N;j++)
InputData[N]=N+4;
write_1602com(er);
for(i=0;i<16;i++)
OneAlam(); //按鍵提示音
for(j=0;j<=N;j++)
N++; //密碼位數(shù)加
break;
//*********************************中斷服務(wù)函數(shù)**************************************
void time1_int(void) interrupt 3 //定時(shí)器T0
TL1=0xB0;
TH1=0x3C; //定時(shí)器重新賦初值
//TR0=1;
countt0++; //計(jì)時(shí)變量加,加1次時(shí)50ms
if(countt0==20) //加到20次就是1s
countt0=0; //變量清零
second++; //秒加
if(pass==1) //開鎖狀態(tài)時(shí)
if(second==1) //秒加到1s時(shí)
TR1=0; //關(guān)定時(shí)器
TL1=0xB0;
TH1=0x3C; //再次賦初值
second=0; //秒清零
else //不在開鎖狀態(tài)時(shí)
if(second==3) //秒加到3時(shí)
TR1=0; //關(guān)閉定時(shí)器
second=0; //秒清零
key_disable=0; //鎖定鍵盤清零
s3_keydown=0;
TL1=0xB0;
TH1=0x3C; //重新賦初值
TR1=1; //打開定時(shí)器
void ReadIr() interrupt 0
unsigned char j,k;
unsigned int err;
Time=0,LOC=0;
DelayMs(70);
if(IRIN==0) //確認(rèn)是否真的接收到正確的信號(hào)
err=1000; //1000*10us=10ms,超過(guò)說(shuō)明接收到錯(cuò)誤的信號(hào)
/*當(dāng)兩個(gè)條件都為真是循環(huán),如果有一個(gè)條件為假的時(shí)候跳出循環(huán),免得程序出錯(cuò)的時(shí)
侯,程序死在這里*/
while((IRIN==0)&&(err>0)) //等待前面9ms的低電平過(guò)去
DelayMs(1);
err--;
if(IRIN==1) //如果正確等到9ms低電平
err=500;
while((IRIN==1)&&(err>0)) //等待4.5ms的起始高電平過(guò)去
DelayMs(1);
err--;
for(k=0;k<4;k++) //共有4組數(shù)據(jù)
for(j=0;j<8;j++) //接收一組數(shù)據(jù)
err=60;
while((IRIN==0)&&(err>0))//等待信號(hào)前面的560us低電平過(guò)去
// while (!IRIN)
DelayMs(1);
err--;
err=500;
while((IRIN==1)&&(err>0)) //計(jì)算高電平的時(shí)間長(zhǎng)度。
DelayMs(1);//0.14ms
Time++;
err--;
if(Time>30)
EX0=1;
return;
IrValue[k]>>=1; //k表示第幾組數(shù)據(jù)
if(Time>=8) //如果高電平出現(xiàn)大于565us,那么是1
IrValue[k]|=0x80;
Time=0; //用完時(shí)間要重新賦值
if(IrValue[2]!=~IrValue[3])
return;
密碼鎖3-紅外+按鍵.zip
2019-7-22 20:29 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
79.43 KB, 下載次數(shù): 22, 下載積分: 黑幣 -5
