頻率分別位100hz,50,25,20,10,5,2,1 文件內含c程序和protues仿真圖
仿真截圖
- #include <reg51.h>
- #define unit unsigned int
- #define uchar unsigned char
- sbit p10=P1^0;//P1^0輸出100HZ波形
- sbit p11=P1^1;//P1^1輸出50HZ波形
- sbit p12=P1^2;//P1^2輸出25HZ波形
- sbit p13=P1^3;//P1^3輸出20HZ波形
- sbit p14=P1^4;//P1^4輸出10HZ波形
- sbit p15=P1^5;//P1^5輸出5HZ波形
- sbit p16=P1^6;//P1^6輸出2HZ波形
- sbit p17=P1^7;//P1^7輸出1HZ波形
- uchar count0;//計數
- uchar count1;
- uchar count2;
- uchar count3;
- uchar count4;
- uchar count5;
- uchar count6;
- uchar count7;
- void main()
- count0=1;
- count1=2;
- count2=4;
- count3=5;
- count4=10;
- count5=20;
- count6=50;
- count7=100;
- TMOD=0X01;//定時器0 方式1
- TH0=(65536-5000)/256;//5000個機器周期 5ms
- TL0=(65536-5000)%256;
- EA=1;
- ET0=1;
- TR0=1;
- while(1)
- if(count0==0){count0=1;p10=!p10;}
- if(count1==0){count1=2;p11=!p11;}
- if(count2==0){count2=4;p12=!p12;}
- if(count3==0){count3=5;p13=!p13;}
- if(count4==0){count4=10;p14=!p14;}
- if(count5==0){count5=20;p15=!p15;}
- if(count6==0){count6=50;p16=!p16;}
- if(count7==0){count7=100;p17=!p17;}
- void counter()interrupt 1
- TH0=(65536-4994)/256;
- TL0=(65536-4994)%256;
- count0--;
- count1--;
- count2--;
- count3--;
- count4--;
- count5--;
- count6--;
- count7--;
8路脈沖.zip
(29.54 KB, 下載次數: 34)
2019-7-21 19:04 上傳
