#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7 ;
sbit key=P3^2 ;
sbit led1= P1^0;
sbit led2= P1^1;
sbit led3= P1^2;
uchar num,num1,pp,num2 ,shi,ge;
uint i,j,k;
uchar code table[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint );
void display(uchar);
void keyscan();
void init();
init();
led1=0;
delay(15000);
led1=1;
led2=0;
delay(15000);
led2=1;
for(k=0;k<=10;k++)
led3=0;
delay(500);
led3=1;
delay(500);
display(num) ;
void delay(uint ms) //延時函數(shù)
for(i=ms;i>0;i--)
for(j=110;j>0;j--);
void display(uchar num) //動態(tài)顯示函數(shù)
shi=num/10;
ge=num%10;
dula=1 ;
P0=table[shi];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(5);
dula=1 ;
P0=table[ge];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delay(5);
void keyscan() //鍵盤檢測函數(shù)
if (key==0)
delay(10);
if(key==0)
pp=1; //判斷按鍵的開關(guān),若為1則表明開始亮燈。
void init() //初始化函數(shù)
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
void timer0()interrupt 1 //定時器0中斷
num2++;
if(num2==20)
num2=0;
num++;
if(num==15)
num=0;
