查看: 8191|回復: 10
單片機+19264液晶+5繼電器改老式滾筒洗衣機
ID:165424 發表于 2019-7-20 21:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
今天家里洗衣機壞了,花了半天時間,說做就做,改手動定時任意時長洗衣服
,附上效果圖和程序
接口說明:
  1. #include <stc15xx.h>
  2. #include <stdio.h>
  3. //#include <intrins.h>
  4. //#include <Ctype.h>
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. #define ulong unsigned long
  8. /* 按鍵*/
  9. sbit key1=P2^3;
  10. sbit key2=P2^4;
  11. sbit key3=P2^5;
  12. sbit key4=P2^6;
  13. /*繼電器*/
  14. sbit jiALL=P3^0;
  15. sbit ji1=P3^1;
  16. sbit ji2=P3^5;
  17. sbit ji3=P3^3;
  18. sbit ji4=P3^4;
  19. /*19264引腳定義*/
  20. sbit cs1=P1^1;
  21. sbit reset=P1^0;
  22. sbit rs=P1^7;
  23. sbit sclk=P1^6;
  24. sbit sid=P0^7;
  25. sbit Rom_SCK=P1^3;
  26. sbit Rom_OUT=P1^4;
  27. sbit Rom_IN=P1^5;
  28. sbit Rom_CS=P1^2;
  29. int timer;
  30. int timer_s;
  31. char startflag=0;
  32. char bbuf[100];
  33. uchar code ascii_table_5x8[95][5];
  34. uchar code ascii_table_8x16[10][16];
  35. uchar code bmp1[];
  36. uchar code bmp2[];
  37. uchar code z[];
  38. uchar code k[];
  39. uchar code y[];
  40. uchar code b[];
  41. uchar code yi[];
  42. void display_graphic_192x64(uchar *dp);
  43. void display_string_5x8(uint page,uint column,uchar reverse,uchar *text);
  44. void display_GB2312_string(uchar y,uchar x,uchar *text);
  45. void clear_screen();
  46. //19264液晶屏配置
  47. //LCD模塊   寫指令
  48. void transfer_command(int data1)
  49. {
  50.                 char i;
  51.                 cs1=0;
  52.                 rs=0;
  53.                 for(i=0;i<8;i++)
  54.                 {
  55.                         sclk=0;
  56.                         if(data1&0x80) sid=1;
  57.                         else sid=0;
  58.                         sclk=1;
  59.                         data1=data1<<=1;
  60.                 }
  61.                 cs1=1;
  62. }
  63. //寫數據到LCD模塊
  64. void transfer_data(int data1)
  65. {
  66.                 char i;
  67.                 cs1=0;
  68.                 rs=1;
  69.                 for(i=0;i<8;i++)
  70.                 {
  71.                         sclk=0;
  72.                         if(data1&0x80) sid=1;
  73.                         else sid=0;
  74.                         sclk=1;
  75.                         data1=data1<<=1;
  76.                 }
  77.                 cs1=1;
  78. }
  79. //延時
  80. void delay(int i)
  81. {
  82.                 int j,k;
  83.                 for(j=0;j<i;j++)
  84.                  for(k=0;k<110;k++);
  85. }
  86. void delay_ms(int i)
  87. {
  88.                 int j,k;
  89.                 for(j=0;j<i;j++)
  90.                  for(k=0;k<900;k++);
  91. }
  92. //LCD 初始化
  93. void initial_lcd()
  94. {
  95.                 reset=0; //地點評復位
  96.                 delay(100);
  97.                 reset=1; //復位完畢
  98.                 delay(100);
  99.                 transfer_command(0xe2); //軟復位
  100.                 delay(500);
  101.                 transfer_command(0x2f); //打開內部生壓
  102.                 delay(500);
  103.                         transfer_command(0x81); //微調對比度
  104.                 transfer_command(0x45); //對比度值0x00~0xFF
  105.                 transfer_command(0xeb); //1/9 偏壓比(bias)
  106.                 transfer_command(0xc4); //?????:???? oxc2
  107.                 transfer_command(0xa0); //?????:????
  108.                 transfer_command(0xaf); //開顯示
  109. }
  110. //19264地址
  111. void lcd_address(uchar page,uchar column)//行 列
  112. {
  113.                 column=column-1; //????????1 ?,?LCD ??IC ???0 ?????????1.
  114.                 page=page-1;
  115.                 transfer_command(0xb0+page); //?????????8 ???????64 ????8 ???????????1 ?,?LCD ??IC ???0 ?,???????1
  116.                 transfer_command(((column>>4)&0x0f)+0x10); //???????4 ?
  117.                 transfer_command(column&0x0f); //???????4 ?
  118. }
  119. //19264清屏
  120. void clear_screen()
  121. {
  122.                 unsigned char i,j;
  123.                 for(i=0;i<9;i++)
  124.                 {
  125.                         lcd_address(1+i,1);
  126.                         for(j=0;j<192;j++)
  127.                         {
  128.                           transfer_data(0x00);
  129.                         }
  130.                 }
  131. }
  132. //19264滿屏顯示圖像
  133. void display_graphic_192x64(uchar *dp)
  134. {
  135.                 uchar i,j;
  136.                 for(i=0;i<9;i++)
  137.                 {
  138.                         lcd_address(1+i,1);
  139.                         for(j=0;j<192;j++)
  140.                         {
  141.                                 transfer_data(*dp);
  142.                                 dp++;
  143.                         }
  144.                 }
  145. }
  146. //19264顯示32*32的字
  147. void display_graphic_32x32(uchar page,uchar column,uchar *dp)
  148. {
  149.                 uchar i,j;
  150.                 for(j=0;j<4;j++)
  151.                 {
  152.                         lcd_address(page+j,column);
  153.                         for (i=0;i<31;i++)
  154.                         {
  155.                                 transfer_data(*dp); //????LCD,?????8 ???????????1
  156.                                 dp++;
  157.                         }
  158.                 }
  159. }
  160. //19264顯示16*16字
  161. void display_graphic_16x16(uchar page,uchar column,uchar *dp)
  162. {
  163.                 uchar i,j;
  164.                 for(j=0;j<2;j++)
  165.                 {
  166.                         lcd_address(page+j,column);
  167.                         for (i=0;i<16;i++)
  168.                         {
  169.                                 transfer_data(*dp); //????LCD,?????8 ???????????1
  170.                                 dp++;
  171.                         }
  172.                 }
  173. }
  174. //19264顯示8*16的字
  175. void display_graphic_8x16(uchar page,uchar column,uchar *dp)
  176. {
  177.                 uchar i,j;
  178.                 for(j=0;j<2;j++)
  179.                 {
  180.                         lcd_address(page+j,column);
  181.                         for (i=0;i<8;i++)
  182.                         {
  183.                                 transfer_data(*dp); //????LCD,?????8 ???????????1
  184.                                 dp++;
  185.                         }
  186.                 }
  187. }
  188. //顯示8*16的數字數據
  189. void display_string_8x16_1(uint page,uint column,uchar text)
  190. {
  191.         uint k,j;
  192.         for(j=0;j<2;j++)
  193.                 {
  194.                           lcd_address(page+j,column);
  195.                                 if(text==0){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[0][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[0][k]);}}}
  196.                                 if(text==1){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[1][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[1][k]);}}}
  197.                                 if(text==2){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[2][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[2][k]);}}}
  198.                                 if(text==3){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[3][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[3][k]);}}}
  199.                                 if(text==4){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[4][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[4][k]);}}}
  200.                                 if(text==5){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[5][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[5][k]);}}}
  201.                                 if(text==6){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[6][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[6][k]);}}}
  202.                                 if(text==7){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[7][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[7][k]);}}}
  203.                                 if(text==8){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[8][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[8][k]);}}}
  204.                                 if(text==9){if(j==0){for(k=0;k<8;k++){transfer_data(ascii_table_8x16[9][k]);}}else{for(k=8;k<16;k++){transfer_data(ascii_table_8x16[9][k]);}}}
  205.                 }
  206. }
  207. //19264顯示5*8的字
  208. void display_string_5x8(uint page,uint column,uchar reverse,uchar *text)
  209. {
  210.                 uchar i=0,j,k,data1;
  211.                 while(text[i]>0x00)
  212.                 {
  213.                         if((text[i]>=0x20)&&(text[i]<=0x7e))
  214.                         {
  215.                                 j=text[i]-0x20;
  216.                                 lcd_address(page,column);
  217.                                 for(k=0;k<5;k++)
  218.                                 {
  219.                                         if(reverse==1) data1=~ascii_table_5x8[j][k];
  220.                                         else data1=ascii_table_5x8[j][k];
  221.                                         transfer_data(data1);
  222.                                 }
  223.                                 if(reverse==1) transfer_data(0xff);
  224.                                 else transfer_data(0x00);
  225.                                 i++;
  226.                                 column+=6;
  227.                         }
  228.                         else
  229.                         i++;
  230.                 }
  231. }
  232. //顯示動態5*8數據
  233. void display_string_5x8_1(uint page,uint column,uchar text)
  234. {
  235.         uint k;
  236.         lcd_address(page,column);
  237.         if(text==0){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[16][k]);}}
  238.         if(text==1){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[17][k]);}}
  239.   if(text==2){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[18][k]);}}
  240.         if(text==3){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[19][k]);}}
  241.         if(text==4){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[20][k]);}}
  242.         if(text==5){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[21][k]);}}
  243.         if(text==6){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[22][k]);}}
  244.         if(text==7){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[23][k]);}}
  245.         if(text==8){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[24][k]);}}
  246.         if(text==9){for(k=0;k<5;k++){transfer_data(ascii_table_5x8[25][k]);}}
  247. }
  248. //發送數據到19264rom
  249. void send_command_to_ROM( uchar datu )
  250. {
  251.                 uchar i;
  252.                 for(i=0;i<8;i++ )
  253.                 {
  254.                         if(datu&0x80)
  255.                         Rom_IN = 1;
  256.                         else
  257.                         Rom_IN = 0;
  258.                         datu = datu<<1;
  259.                         Rom_SCK=0;
  260.                         Rom_SCK=1;
  261.                 }
  262. }
  263. //從19264rom取出數據
  264. static uchar get_data_from_ROM( )
  265. {
  266.                 uchar i;
  267.                 uchar ret_data=0;
  268.                 Rom_SCK=1;
  269.                 for(i=0;i<8;i++)
  270.                 {
  271.                         Rom_OUT=1;
  272.                         Rom_SCK=0;
  273.                         ret_data=ret_data<<1;
  274.                         if( Rom_OUT )
  275.                         ret_data=ret_data+1;
  276.                         else
  277.                         ret_data=ret_data+0;
  278.                         Rom_SCK=1;
  279.                 }
  280.                 return(ret_data);
  281. }
  282. //取n字節19264rom
  283. void get_n_bytes_data_from_ROM(uchar addrHigh,uchar addrMid,uchar addrLow,uchar *pBuff,uchar DataLen )
  284. {
  285.                 uchar i;
  286.                 Rom_CS = 0;
  287.                 cs1=1;
  288.                 Rom_SCK=0;
  289.                 send_command_to_ROM(0x03);
  290.                 send_command_to_ROM(addrHigh);
  291.                 send_command_to_ROM(addrMid);
  292.                 send_command_to_ROM(addrLow);
  293.                 for(i = 0; i < DataLen; i++ )
  294.                 *(pBuff+i) =get_data_from_ROM();
  295.                 Rom_CS = 1;
  296. }
  297. /******************************************************************/
  298. ulong fontaddr=0;
  299. void display_GB2312_string(uchar y,uchar x,uchar *text)
  300. {
  301.                 uchar i= 0;
  302.                 uchar addrHigh,addrMid,addrLow ;
  303.                 uchar fontbuf[32];
  304.                 while((text[i]>0x00))
  305.                 {
  306.                         if(((text[i]>=0xb0) &&(text[i]<=0xf7))&&(text[i+1]>=0xa1))
  307.                         {
  308.                                 /*????(GB2312)?????IC ????????????:*/
  309.                                 /*Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 846)*32+ BaseAdd;BaseAdd=0*/
  310.                                 /*????8 ???????????,????????*/
  311.                                 fontaddr = (text[i]- 0xb0)*94;
  312.                                 fontaddr += (text[i+1]-0xa1)+846;
  313.                                 fontaddr = (ulong)(fontaddr*32);
  314.                                 addrHigh = (fontaddr&0xff0000)>>16; /*????8?,?24?*/
  315.                                 addrMid = (fontaddr&0xff00)>>8; /*????8?,?24?*/
  316.                                 addrLow = fontaddr&0xff; /*????8?,?24?*/
  317.                                 get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,32 );/*?32 ??????,??
  318.                                 "fontbuf[32]"*/
  319.                                 display_graphic_16x16(y,x,fontbuf);/*?????LCD?,y ????,x ????,fontbuf[]?
  320.                                 ??*/
  321.                                 i+=2;
  322.                                 x+=16;
  323.                         }
  324.                         else if((text[i]>=0x20) &&(text[i]<=0x7e))
  325.                         {
  326.                         unsigned char fontbuf[16];
  327.                         fontaddr = (text[i]- 0x20);
  328.                                 fontaddr = (unsigned long)(fontaddr*16);
  329.                         fontaddr = (unsigned long)(fontaddr+0x3b7c0);
  330.                         addrHigh = (fontaddr&0xff0000)>>16;
  331.                         addrMid = (fontaddr&0xff00)>>8;
  332.                         addrLow = fontaddr&0xff;
  333.                         get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,16 );/*?16 ??????,??
  334.                         "fontbuf[32]"*/
  335.                         display_graphic_8x16(y,x,fontbuf);/*??8x16?ASCII??LCD?,y ????,x ????,
  336.                         fontbuf[]???*/
  337.                         i+=1;
  338.                         x+=8;
  339.                         }
  340.                         else
  341.                         i++;
  342.                 }
  343. }
  344. void tim0_isr (void) interrupt 1
  345. {
  346.   TH0=(65536-50000)/256;
  347.         TL0=(65536-50000)%256;
  348.         if(startflag){
  349.                 timer++;
  350.                 if(timer>20){
  351.                         timer=0;
  352.                         timer_s--;
  353.                 }
  354.                 if(timer_s<=0){
  355.                         timer_s=0;
  356.                         startflag=0;
  357.                         jiALL=ji1=ji2=ji3=ji4=1;
  358.                         initial_lcd();//初始化lcd
  359.                         clear_screen();
  360.                         display_GB2312_string(1,1,"請設置洗滌時間:");
  361.                         sprintf(bbuf,"%d分鐘",timer_s/60);
  362.                         display_GB2312_string(5,80,bbuf);
  363.                 }
  364.         }
  365. }
  366. void TIM0init(void)//定時器0初始化
  367. {
  368.         TMOD=0x01;                 //模式設置,00000001,可見采用的是定時器0,工作與模式1(M1=0,M0=1)。
  369.         TR0=1;                         //打開定時器
  370.         TH0=(65536-50000)/256;// 由于晶振為11.0592,故所記次數應為46080,計時器每隔50000微秒發起一次中斷。
  371.         TL0=(65536-50000)%256;//46080的來歷,為50000*11.0592/12
  372.         ET0=1;                         //開定時器0中斷
  373.         EA=1;                         //開總中斷
  374. }
  375. void EX0_ISR (void) interrupt 0 //外部中斷0服務函數
  376. {
  377.                 /*startflag=0;
  378.                 jiALL=ji1=ji2=ji3=ji4=1;
  379.                 initial_lcd();//初始化lcd
  380.                 clear_screen();
  381.                 display_GB2312_string(1,1,"請設置洗滌時間:");
  382.                 sprintf(bbuf,"%d分鐘",timer_s/60);
  383.                 display_GB2312_string(5,80,bbuf);                */
  384. }
  385. void EX0init(void)
  386. {
  387. IT0 = 1;   //指定外部中斷0下降沿觸發,INT0 (P3.2)
  388. EX0 = 1;   //使能外部中斷
  389. EA = 1;    //開總中斷
  390. }
  391. void main(void)
  392. {
  393.           P0M1=0;   //設置P0全部為準雙向io
  394.     P0M0=0;
  395.           P1M1=0;   //設置P1全部為準雙向io
  396.     P1M0=0;
  397.                 P2M0=0;
  398.                 P2M1=0;
  399.     P3M1=0;   //設置P3全部為準雙向io
  400.     P3M0=0;
  401.     P4M1=0;   //設置P4全部為準雙向io
  402.     P4M0=0;
  403.                 jiALL=ji1=ji2=ji3=ji4=1;
  404.           initial_lcd();//初始化lcd
  405.                 EX0init(); //初始化外部中斷
  406.                 TIM0init();//初始化定時器
  407.                 timer=0;
  408.                 timer_s=0;
  409.                 startflag=0;
  410.                 clear_screen(); //clear all dots清屏
  411.           display_string_5x8(1,1,0,"welcome use");
  412.                 display_graphic_32x32(3,10,z);
  413.           display_graphic_32x32(3,45,k);
  414.                 display_graphic_32x32(3,80,y);
  415.                 display_graphic_32x32(3,115,b);
  416.                 display_graphic_32x32(3,150,yi);
  417.           display_string_5x8(8,157,0,"key in");
  418.                 delay_ms(1000);
  419.                 display_graphic_192x64(bmp1);
  420.                 delay_ms(1000);
  421.
  422.           clear_screen();
  423.                 timer_s=10*60;//初始化定時10分鐘
  424.                 display_GB2312_string(1,1,"請設置洗滌時間:");
  425.                 display_GB2312_string(5,80,"10分鐘");
  426.                 while(1)
  427.                 {
  428.                          if(key4==0){
  429.                                                 delay_ms(50);
  430.                                                 if(key4==0){
  431.                                                         if(startflag==0){
  432.        startflag=0;
  433.        initial_lcd();//初始化lcd
  434.        clear_screen();
  435.        timer_s+=60;
  436.        if(timer_s>=100*60)timer_s=100*60;
  437.        display_GB2312_string(1,1,"請設置洗滌時間:");
  438.        sprintf(bbuf,"%d分鐘",timer_s/60);
  439.        display_GB2312_string(5,80,bbuf);
  440.                                                         }
  441.                                                 }
  442.                                 }
  443.
  444.                                 if(key2==0){
  445.                                         delay_ms(50);
  446.                                         if(key2==0){
  447.                                                 if(startflag==0){
  448.        startflag=0;
  449.        initial_lcd();//初始化lcd
  450.        clear_screen();
  451.        timer_s-=60;
  452.        if(timer_s<=0)timer_s=0;
  453.        display_GB2312_string(1,1,"請設置洗滌時間:");
  454.        sprintf(bbuf,"%d分鐘",timer_s/60);
  455.        display_GB2312_string(5,80,bbuf);
  456.                                                 }
  457.                                         }
  458.                                 }
  459.                                 if(key3==0){
  460.                                         delay_ms(100);
  461.                                         if(key3==0){
  462.                                                 if(startflag==0){
  463.        startflag=1;
  464.        initial_lcd();//初始化lcd
  465.        clear_screen();
  466.        display_GB2312_string(1,1,"洗滌中:");
  467.        display_GB2312_string(5,1,"倒計時:");
  468.        sprintf(bbuf,"%d分鐘",timer_s/60);
  469.        display_GB2312_string(5,80,bbuf);
  470.                                                 }
  471.                                         }
  472.                                 }
  473.
  474.                                 if(startflag==1){
  475.                                         initial_lcd();//初始化lcd
  476.                                         clear_screen();
  477.
  478.                                         display_GB2312_string(1,1,"洗滌中:");
  479.                                         display_GB2312_string(5,1,"倒計時:");
  480.                                         sprintf(bbuf,"%d分鐘",timer_s/60);
  481.                                         display_GB2312_string(5,80,bbuf);
  482.
  483.                                         sprintf(bbuf,"%ds",timer_s);
  484.                                   display_GB2312_string(7,150,bbuf);
  485.
  486.                                         jiALL=0;
  487.                                         ji1=ji2=ji3=ji4=1;delay_ms(10);
  488.                                         ji1=0;delay_ms(1000);
  489.                                         ji2=0;delay_ms(5000);
  490.                                         ji1=1;delay_ms(5000);
  491.                                         ji2=1;delay_ms(1500);
  492.
  493.                                         ji3=0;delay_ms(1000);
  494.                                         ji4=0;delay_ms(5000);
  495.                                         ji3=1;delay_ms(5000);
  496.                                         ji4=1;delay_ms(1500);
  497.                                 }
  498.
  499.                                 sprintf(bbuf,"%ds",timer_s);
  500.                                 display_GB2312_string(7,150,bbuf);
  501.
  502.                 }
  503. }
  504. uchar code ascii_table_5x8[95][5]={
  505. /*??ASCII ??:5x8 ??*/
  506. 0x00,0x00,0x00,0x00,0x00,//- - //space
  507. 0x00,0x00,0x4f,0x00,0x00,//-!-
  508. 0x00,0x07,0x00,0x07,0x00,//-"-
  509. 0x14,0x7f,0x14,0x7f,0x14,//-#-
  510. ……………………
  511. …………限于本文篇幅 余下代碼請從51黑下載附件…………
19264屏幕5繼電器控制洗衣機洗滌定時.rar (870.45 KB, 下載次數: 140)
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
收藏收藏7 分享淘帖 頂 踩
ID:581386 發表于 2019-7-21 04:48 來自觸屏版 | 只看該作者
大佬是真的給力
ID:91165 發表于 2019-7-25 10:09 | 只看該作者
這個實用呀,點贊
ID:668822 發表于 2019-12-26 01:24 | 只看該作者
都是大佬!51黑友為你點贊!
ID:674237 發表于 2019-12-26 09:10 | 只看該作者
太厲害了 你們好猛
ID:325548 發表于 2019-12-29 15:10 | 只看該作者
大佬太厲害了。很實用
ID:53978 發表于 2020-1-4 11:18 | 只看該作者
這個必須贊,厲害!而且很實用。
ID:634466 發表于 2020-1-29 16:15 | 只看該作者
用19264有點浪費,就用數碼管設計和原來的功能差不多就行
ID:294296 發表于 2020-1-30 02:20 | 只看該作者
樓主好棒!要是我遇到,用可控硅和12864,嘻嘻!
ID:750368 發表于 2020-6-26 23:55 來自觸屏版 | 只看該作者
大佬小弟跟著改下試試。。
ID:473471 發表于 2020-6-30 23:03 | 只看該作者
舊電器改造,可約資源,值得推廣!
