查看: 4016|回復: 3
stm32多串口收發數據源程序
ID:189966 發表于 2019-7-19 17:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
stm32多串口收發數據
#include "user_usart.h"
#include "stm32f10x_usart.h"
#include "user_adc.h"
#include "user_74_595.h"
#include "user_74_165.h"
#include "user_gpio.h"
/*使用microLib的方法*/
int fputc(int ch, FILE *f)
        USART_SendData(USART1, (uint8_t) ch);
        while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {}
    return ch;
int GetKey (void)  {
    while (!(USART1->SR & USART_FLAG_RXNE));
    return ((int)(USART1->DR & 0x1FF));
//#if EN_USART1_RX   //如果使能了接收
//串口1中斷服務程序
//注意,讀取USARTx->SR能避免莫名其妙的錯誤
//u8 USART_RX_BUF[USART_REC_LEN];     //接收緩沖,最大USART_REC_LEN個字節.
//接收狀態
//bit15,        接收完成標志
//bit14,        接收到0x0d
//bit13~0,        接收到的有效字節數目
u16 USART_RX_STA=0;       //接收狀態標記
//串口1隊列定義
u8         UART1SendBuff[UART1BuffSize];                //發送數據
u8         UART1ReceBuff[UART1BuffSize];                //接收數據?
u16 UART1ReceIn = 0;//接收狀態標記數據位
u8  UART1ReceFullFlag = 0;//接收完數據標志位
//串口2隊列定義
u8         UART2SendBuff[UART2BuffSize];
u8         UART2ReceBuff[UART2BuffSize];
u16 UART2ReceIn = 0;
u8  UART2ReceFullFlag = 0;
//串口3隊列定義
u8         UART3SendBuff[UART3BuffSize];
u8         UART3ReceBuff[UART3BuffSize];
u16 UART3ReceIn = 0;
u8  UART3ReceFullFlag = 0;
//串口1初始化
void USART1_Configuration(u32 bound)
        NVIC_InitTypeDef NVIC_InitStructure;
        USART_InitTypeDef USART_InitStructure;;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//開啟GPIOA和USART1時鐘
        //USART1_TX   GPIOA.9
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //復用推挽輸出
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
        //USART1_RX          GPIOA.10初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空輸入
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
        //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;//搶占優先級3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                //子優先級3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根據指定的參數初始化VIC寄存器
        //USART 初始化設置
        USART_InitStructure.USART_BaudRate = bound;//串口波特率
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長為8位數據格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數據流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收發模式
    USART_Init(USART1, &USART_InitStructure); //初始化串口1
        USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);  //開啟串口接收中斷
        USART_Cmd(USART1, ENABLE);                    //使能串口1
//串口2初始化
void USART2_Configuration(u32 bound)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//開啟GPIOA和USART1時鐘
        //USART2_TX   GPIOA.2
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA.2
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.2
        //USART2_RX          GPIOA.3初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.3
        //Usart2 NVIC 配置
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
        //USART 初始化設置
    USART_Init(USART2, &USART_InitStructure); //初始化串口2
        USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);  //開啟串口接收中斷
        USART_Cmd(USART2, ENABLE);                    //使能串口2
//串口3初始化
void USART3_Configuration(u32 bound)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//開啟GPIOA和USART1時鐘
        //USART3_TX   GPIOB.10
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10
    GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOA.10
        //USART3_RX          GPIOB.3初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//PB11
    GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB.11
        //Usart3 NVIC 配置
    NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
        //USART 初始化設置
    USART_Init(USART3, &USART_InitStructure); //初始化串口3
        USART_ITConfig(USART3,USART_IT_RXNE,ENABLE);  //開啟串口接收中斷
        USART_Cmd(USART3, ENABLE);                    //使能串口3
//串口1發送一幀數據
void USART1_SendOneData(uint8_t SendOneData)
        USART_SendData(USART1, SendOneData);
//串口2發送一幀數據
void USART2_SendOneData(uint8_t SendOneData)
        USART_SendData(USART2, SendOneData);
        while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET)
//串口3發送一幀數據
void USART3_SendOneData(uint8_t SendOneData)
        USART_SendData(USART3, SendOneData);
        while (USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET)
//串口1發送一列數據
void USART1_SendUnfixedData(uint8_t *Buffer, uint8_t Length)
        uint8_t  i;
        for(i=0;i<Length;i++)
                USART1_SendOneData(*Buffer++);
//串口2發送一列數據
void USART2_SendUnfixedData(uint8_t *Buffer, uint8_t Length)
        uint8_t  i;
                USART2_SendOneData(*Buffer++);
//串口3發送一列數據
void USART3_SendUnfixedData(uint8_t *Buffer, uint8_t Length)
        uint8_t  i;
        LED_ON;
                USART3_SendOneData(*Buffer++);
        LED_OFF;
//串口1中斷服務函數
void USART1_IRQHandler(void)
        u8 Res;//數據暫存
        if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)  //接收中斷
                Res =USART_ReceiveData(USART1);        //讀取接收到的數據
                switch(UART1ReceIn)//讀取接收到的數據有幾位 每一位對應的數據協議校驗
                        case 0:
                                if(Res=='T')
                                        UART1ReceBuff[UART1ReceIn++] = Res;
                                        UART1ReceIn = 0;
                                break;
                        case 1:
                                if(Res=='M')
                                        UART1ReceIn = 0;
                                break;
                        case 2:
                                if(Res==0x0f)
                                        UART1ReceIn = 0;
                                break;
                        case 3:
                                if(Res==0x01)
                                        UART1ReceIn = 0;
                                break;
                        case 4:
                                if(Res==0x31)
                                        UART1ReceIn = 0;
                                break;
                        default:
                                break;
                if(UART1ReceIn >= 57)
                        UART1ReceFullFlag = 1;        //數據完整接受完
                USART_ClearITPendingBit(USART1, USART_IT_RXNE);//清除相對應的中斷位   清除中斷預處理位USART_ClearITPendingBit左移八位是USART_ClearFlag
        else if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)        // 發送中斷  USART_GetITStatus
                USART_ClearITPendingBit(USART1, USART_IT_TXE);                                        // clear interrupt  清除中斷預處理位
//串口2中斷服務函數
void USART2_IRQHandler(void)
        u8 Res;
#if SYSTEM_SUPPORT_OS                 //如果SYSTEM_SUPPORT_OS為真,則需要支持OS.
        OSIntEnter();
#endif
        if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)  //接收中斷(接收到的數據必須是0x0d 0x0a結尾)
                Res =USART_ReceiveData(USART2);        //讀取接收到的數據USART_ReceiveData
                if((USART_RX_STA&0x8000)==0)//接收未完成
                        if(USART_RX_STA&0x4000)//接收到了0x0d
                                if(Res!=0x0a)USART_RX_STA=0;//接收錯誤,重新開始
                                else USART_RX_STA|=0x8000;        //接收完成了
                        else //還沒收到0X0D
                                if(Res==0x0d)USART_RX_STA|=0x4000;
                                        UART2ReceBuff[USART_RX_STA&0X3FFF]=Res ;
                                        USART_RX_STA++;
                                        if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收數據錯誤,重新開始接收
        OSIntExit();
#endif
//串口3中斷服務函數
void USART3_IRQHandler(void)
        u8 Res;//數據暫存
        if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)  //接收中斷
                Res =USART_ReceiveData(USART3);        //讀取接收到的數據 USART_ReceiveData
                switch(UART3ReceIn)//讀取接收到的數據有幾位 每一位對應的數據協議校驗
                        case 0:
                                if(Res=='T')
                                        UART3ReceBuff[UART3ReceIn++] = Res;
                                        UART3ReceIn = 0;
                                break;
                        case 1:
                                if(Res=='M')
                                        UART3ReceIn = 0;
                                break;
                        case 2:
                                if(Res==0x0f)
                                        UART3ReceIn = 0;
                                break;
                        case 3:
                                if(Res==0x01)
                                        UART3ReceIn = 0;
                                break;
                        case 4:
                                if(Res==0x31)
                                        UART3ReceIn = 0;
                                break;
                        default:
                                break;
                if(UART3ReceIn >= 57)
                        UART3ReceFullFlag = 1;        //數據完整接受完
                USART_ClearITPendingBit(USART3, USART_IT_RXNE);//清除相對應的中斷位   清除中斷預處理位USART_ClearITPendingBit左移八位是USART_ClearFlag
        else if(USART_GetITStatus(USART3, USART_IT_TXE) != RESET)        // 發送中斷  USART_GetITStatus
                USART_ClearITPendingBit(USART3, USART_IT_TXE);                                        // clear interrupt  清除中斷預處理位
//發送開關量輸入數據
void SendInputData(void)
         // 組包,第一幀
        UART1SendBuff[0] = 0XAA;
        UART1SendBuff[1] = 0XBB;
        UART1SendBuff[2] = ReadInData.ByteData[0];
        UART1SendBuff[3] = ReadInData.ByteData[1];
        UART1SendBuff[4] = ReadInData.ByteData[2];
        UART1SendBuff[5] = ReadInData.ByteData[3]; //165檢測結構
        UART1SendBuff[6] = 0XCC;
        UART1SendBuff[7] = 0XDD;
        // 發送第一幀數據
        USART3_SendUnfixedData(UART1SendBuff,8);
        Delay_m(350);                // 延時,和計算機軟件時間匹配
void SendAnalogData(void)                        // 通過串口發送模擬量數據
         // 組包,第一幀
        UART1SendBuff[2] = 0X01;
        UART1SendBuff[3] = 0x10;
        UART1SendBuff[4] = (AnalogChannel[0].AveVal >> 8);
        UART1SendBuff[5] = (u8)AnalogChannel[0].AveVal;
        // 發送第一幀數據
        USART3_SendUnfixedData(UART1SendBuff, 8);
        Delay_m(300);                // 延時,和計算機軟件時間匹配
         // 組包,第二幀
        UART1SendBuff[3] = 0x20;
        UART1SendBuff[4] = (AnalogChannel[1].AveVal >> 8);
        UART1SendBuff[5] = (u8)AnalogChannel[1].AveVal;
        // 發送第二幀數據
         // 組包,第三幀
        UART1SendBuff[3] = 0x30;
        UART1SendBuff[4] = (AnalogChannel[2].AveVal >> 8);
        UART1SendBuff[5] = (u8)AnalogChannel[2].AveVal;
        // 發送第三幀數據
         // 組包,第四幀
        UART1SendBuff[1] = 0x40;
        UART1SendBuff[2] = (AnalogChannel[3].AveVal >> 8);
        UART1SendBuff[3] = (u8)AnalogChannel[3].AveVal;
        // 發送第四幀數據
        USART_SendUnfixedData(UART1SendBuff, 8);
         // 組包,第五幀
        UART1SendBuff[1] = 0x50;
        UART1SendBuff[2] = (AnalogChannel[4].AveVal >> 8);
        UART1SendBuff[3] = (u8)AnalogChannel[4].AveVal;
        // 發送第五幀數據
         // 組包,第六幀
        UART1SendBuff[1] = 0x60;
        UART1SendBuff[2] = (AnalogChannel[5].AveVal >> 8);
        UART1SendBuff[3] = (u8)AnalogChannel[5].AveVal;
        // 發送第六幀數據
         // 組包,第七幀
        UART1SendBuff[1] = 0x70;
        UART1SendBuff[2] = (AnalogChannel[6].AveVal >> 8);
        UART1SendBuff[3] = (u8)AnalogChannel[6].AveVal;
        // 發送第七幀數據
         // 組包,第八幀
        UART1SendBuff[1] = 0x80;
        UART1SendBuff[2] = (AnalogChannel[7].AveVal >> 8);
        UART1SendBuff[3] = (u8)AnalogChannel[7].AveVal;
        // 發送第八幀數據
上面這個是壓縮包里面的user_usart.c文件: STM32加232串口發多串口.7z (195.06 KB, 下載次數: 83)
收藏收藏2 分享淘帖 頂 踩
ID:535129 發表于 2019-8-13 17:20 | 只看該作者
哇,牛啊,大哥!
我最近要寫一個激光雷達和32單片機的串口通信,但是有問題,激光雷達返回的值不能被單片機調用,你能幫下忙嗎?
ID:105206 發表于 2020-4-16 23:27 | 只看該作者
學習下,感謝分享。
ID:891089 發表于 2021-4-20 20:45 | 只看該作者
樓主發的展示程序在HARDWARE\User_usart\user_usart.c里面
