查看: 6227|回復: 3
STM32小車四路pwm源程序,可尋跡,oled顯示,可pid調節
ID:586895 發表于 2019-7-19 15:11 | 顯示全部樓層 |閱讀模式
這個c8t6小車是我參加電賽的時候做的,目前具有紅外尋跡,oled實時顯示時間,藍牙通信,在手機端上顯示小車運動時間,還有加入了mpu6050模塊和pid算法,實現了小車在蹺蹺板上的平衡。小車的照片和原理圖都放在附件里了,大家可以看一看。
制作出來的實物圖如下:
電路原理圖如下:
* @par Copyright (C): 2010-2019, Shenzhen Yahboom Tech
* @file         app_motor.c
* @author       liusen
* @version      V1.0
* @brief        小車運動控制函數
* @details
* @par History  見如下說明
* version: liusen_20170717
#include "app_motor.h"
#include "sys.h"
#include "bsp_motor.h"
#define  LeftMotor_Go()   {GPIO_SetBits(Motor_Port, Left_MotoA_Pin); GPIO_ResetBits(Motor_Port, Left_MotoB_Pin);GPIO_SetBits(Motor_Port1, Left_MotoA1_Pin); GPIO_ResetBits(Motor_Port1, Left_MotoB1_Pin);}//反轉
#define  LeftMotor_Back()  {GPIO_ResetBits(Motor_Port, Left_MotoA_Pin); GPIO_SetBits(Motor_Port, Left_MotoB_Pin);GPIO_ResetBits(Motor_Port1, Left_MotoA1_Pin); GPIO_SetBits(Motor_Port1, Left_MotoB1_Pin);}//正轉
#define  LeftMotor_Stop()  {GPIO_ResetBits(Motor_Port, Left_MotoA_Pin); GPIO_ResetBits(Motor_Port, Left_MotoB_Pin);GPIO_ResetBits(Motor_Port1, Left_MotoA1_Pin); GPIO_ResetBits(Motor_Port1, Left_MotoB1_Pin);}//停止
#define  RightMotor_Go()  {GPIO_SetBits(Motor_Port, Right_MotoA_Pin); GPIO_ResetBits(Motor_Port, Right_MotoB_Pin);GPIO_SetBits(Motor_Port, Right_MotoA1_Pin); GPIO_ResetBits(Motor_Port, Right_MotoB1_Pin);}//反轉
#define  RightMotor_Back()  {GPIO_ResetBits(Motor_Port, Right_MotoA_Pin); GPIO_SetBits(Motor_Port, Right_MotoB_Pin);GPIO_ResetBits(Motor_Port, Right_MotoA1_Pin); GPIO_SetBits(Motor_Port, Right_MotoB1_Pin);}//正轉
#define  RightMotor_Stop()  {GPIO_ResetBits(Motor_Port, Right_MotoA_Pin); GPIO_ResetBits(Motor_Port, Right_MotoB_Pin);GPIO_ResetBits(Motor_Port, Right_MotoA1_Pin); GPIO_ResetBits(Motor_Port, Right_MotoB1_Pin);}//停止
#define  LeftMotorPWM(Speed) TIM_SetCompare2(TIM4, Speed);  //左前
#define  RightMotorPWM(Speed) TIM_SetCompare1(TIM4, Speed); //右前
#define  Left1MotorPWM(Speed)   TIM_SetCompare3(TIM4, Speed);   //左后
#define  Right1MotorPWM(Speed) TIM_SetCompare4(TIM4, Speed);   //右后
* Function       Car_Run
* @author        liusen
* @date          2017.07.17
* @brief         小車前進
* @param[in]     Speed  (0~7200) 速度范圍
* @param[out]    void
* @retval        void
* @par History   無
void Car_Run(int Speed)
LeftMotor_Go();
RightMotor_Go();
LeftMotorPWM(Speed);
RightMotorPWM(Speed);
Left1MotorPWM(Speed);
Right1MotorPWM(Speed);
* Function       Car_Back
* @author        liusen
* @date          2017.07.17
* @brief         小車后退
* @param[out]    void
* @retval        void
* @par History   無
void Car_Back(int Speed)
LeftMotor_Back();
RightMotor_Back();
* Function       Car_Left
* @author        liusen
* @date          2017.07.17
* @brief         小車左轉
* @param[out]    void
* @retval        void
* @par History   無
void Car_Left(int Speed)
LeftMotor_Stop();
RightMotor_Go();
LeftMotorPWM(0);
Left1MotorPWM(0);
* Function       Car_Right
* @author        liusen
* @date          2017.07.17
* @brief         小車右轉
* @param[out]    void
* @retval        void
* @par History   無
void Car_Right(int Speed)
LeftMotor_Go();
RightMotor_Stop();
RightMotorPWM(0);
Right1MotorPWM(0);
* Function       Car_Stop
* @author        liusen
* @date          2017.07.17
* @brief         小車剎車
* @param[in]     void
* @param[out]    void
* @retval        void
* @par History   無
void Car_Stop(void)
LeftMotor_Stop();
RightMotor_Stop();
LeftMotorPWM(0);
RightMotorPWM(0);
    Left1MotorPWM(0);
Right1MotorPWM(0);
void Car_Back_Left(int Speed)
LeftMotor_Stop();
RightMotor_Back();
LeftMotorPWM(0);
Left1MotorPWM(0);
void Car_Back_Right(int Speed)
LeftMotor_Back();
RightMotor_Stop();
RightMotorPWM(0);
Right1MotorPWM(0);
* Function       Car_SpinLeft
* @author        liusen
* @date          2017.07.17
* @brief         小車左旋
* @param[in]     LeftSpeed:左電機速度  RightSpeed:右電機速度 取值范圍:(0~7200)
* @param[out]    void
* @retval        void
* @par History   無
void Car_SpinLeft(int LeftSpeed, int RightSpeed)
LeftMotor_Back();
RightMotor_Go();
LeftMotorPWM(LeftSpeed);
RightMotorPWM(RightSpeed);
Left1MotorPWM(LeftSpeed);
Right1MotorPWM(RightSpeed);
* Function       Car_SpinRight
* @author        liusen
* @date          2017.07.17
* @brief         小車右旋
* @param[out]    void
* @retval        void
* @par History   無
void Car_SpinRight(int LeftSpeed, int RightSpeed)
LeftMotor_Go();
RightMotor_Back();
全部程序51hei下載地址:
c8t6小車程序.7z (321.49 KB, 下載次數: 267)
ID:1 發表于 2019-7-19 18:06 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:242804 發表于 2020-12-28 10:18 | 顯示全部樓層
我想問一下樓主大神,就APP控制的這個部分,APP的藍牙這邊廠商來給的嗎?
ID:1091382 發表于 2023-10-29 22:14 | 顯示全部樓層
請問這個引腳怎么接線的
