非常感謝 我也整段示例代碼吧 直接源碼
#include <reg51.h>
#define FOSC 11059200L
#define BAUD 9600
#define TIMER_CLOCK 921600L
sbit IN1 = P1^0; //引腳定義
sbit IN2 = P1^1;
sbit IN3 = P1^2;
sbit IN4 = P1^3;
unsigned char code PWM_HL[8] = {0x00, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x3F}; //PWM占空比
void delay_us(unsigned char i)
while(i--);
void delay_ms(unsigned char i)
unsigned char j;
while(i--)
for(j = 0; j < 110; j++);
void Timer0Init()
TMOD &= 0xF0;
TMOD |= 0x01; //16位計數器模式
TH0 = 0x3C;
TL0 = 0xB0;
ET0 = 1;
TR0 = 1;
EA = 1;
void SerialInit()
PCON = 0x00;
SCON = 0x50;
TMOD |= 0x20; //Timer1為8位自動重載定時器模式
TH1 = 256-((FOSC/12/32)/BAUD);
TL1 = TH1;
TR1 = 1;
void PWM(unsigned char speed)
unsigned char i;
if(speed > 7)
speed = 7;
for(i = 0; i < 500; i++)
if(speed > i >> 8)
IN1 = 1;
IN1 = 0;
if(speed > i >> 6)
IN2 = 1;
IN2 = 0;
if(speed > i >> 4)
IN3 = 1;
IN3 = 0;
if(speed > i >> 2)
IN4 = 1;
IN4 = 0;
delay_us(1);
SerialInit();
Timer0Init();
PWM(5);
delay_ms(2000);
PWM(2);
delay_ms(2000);
void Timer0_ISR() interrupt 1
static unsigned char count = 0;
static unsigned char speed = 0;
TH0 = 0x3C;
TL0 = 0xB0;
count ++;
if(count >= 10)
count = 0;
if(SBUF > 10)
speed = SBUF - 10;
speed = 0;
PWM(speed);
TF0 = 0;
在此示例中,我們使用了定時計數器Timer0來產生控制無刷電機(4相)的PWM信號。通過修改定時器的計數方式和TH0、TL0寄存器的值,可以實現不同的PWM頻率和占空比。具體實現步驟為:
1. 根據控制要求,定義引腳和占空比常量
2. 初始化定時器Timer0,并編寫相應的定時器中斷服務函數Timer0_ISR()
3. 初始化串口通信,并在主函數中調用PWM()函數來控制無刷電機的速度和方向 |
