查看: 11793|回復: 14
51單片機控制八個DS18B20溫度傳感器顯示 原理圖及PCB圖+仿真程序
ID:577601 發表于 2019-7-17 19:52 | 顯示全部樓層 |閱讀模式
51單片機控制八個DS18B20仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include <reg51.h>
  2. #include <Intrins.h>
  3. #define                DATA        P1      //1602驅動端口
  4. //ROM操作命令
  5. #define                 READ_ROM                       0x33                    //讀ROM
  6. #define                 SKIP_ROM                       0xCC                    //跳過ROM
  7. #define                 MATCH_ROM               0x55                    //匹配ROM
  8. #define                 SEARCH_ROM              0xF0                    //搜索ROM
  9. #define                 ALARM_SEARCH            0xEC                    //告警搜索
  10. //存儲器操作命令
  11. #define                 ANEW_MOVE                     0xB8                    //重新調出E^2數據
  12. #define                 READ_POWER              0xB4                    //讀電源
  13. #define                 TEMP_SWITCH             0x44                    //啟動溫度變換
  14. #define                 READ_MEMORY             0xBE                    //讀暫存存儲器
  15. #define                 COPY_MEMORY             0x48                    //復制暫存存儲器
  16. #define                 WRITE_MEMORY            0x4E                    //寫暫存存儲器
  17. //數據存儲結構
  18. typedef struct tagTempData
  19. {
  20.         unsigned char                                         btThird;                                                        //百位數據
  21.         unsigned char                                         btSecond;                                                        //十位數據
  22.         unsigned char                                         btFirst;                                                        //個位數據
  23.         unsigned char                                         btDecimal;                                                        //小數點后一位數據
  24.         unsigned char                                        btNegative;                                                        //是否為負數
  25. }TEMPDATA;
  26. TEMPDATA m_TempData;
  27. //引腳定義
  28. sbit                                                         DQ = P2^7;                                                        //數據線端口
  29. sbit                 RS=                P2^0;
  30. sbit                 RW=                P2^1;
  31. sbit                 E=                P2^2;
  32. //DS18B20序列號,通過調用GetROMSequence()函數在P1口讀出(讀8次)
  33. const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
  34. const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
  35. const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
  36. const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
  37. const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
  38. const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
  39. const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
  40. const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
  41. //判斷忙指令
  42. void Busy()
  43. {
  44.         DATA = 0xff;
  45.         RS = 0;
  46.         RW = 1;
  47.            while(DATA & 0x80)
  48.            {
  49.                 E = 0;
  50.                    E = 1;
  51.            }
  52.            E = 0;
  53. }
  54. //寫指令程序
  55. void WriteCommand(unsigned char btCommand)
  56. {
  57.         Busy();
  58.         RS = 0;
  59.         RW = 0;
  60.         E = 1;
  61.         DATA = btCommand;
  62.         E = 0;
  63. }
  64. //寫數據程序
  65. void WriteData(unsigned char btData)
  66. {
  67.         Busy();
  68.         RS = 1;
  69.         RW = 0;
  70.         E = 1;
  71.         DATA = btData;
  72.         E = 0;
  73. }
  74. //清屏顯示
  75. void Clear()
  76. {
  77.         WriteCommand(1);
  78. }
  79. //初始化
  80. void Init()
  81. {
  82.         WriteCommand(0x0c);        //開顯示,無光標顯示
  83.         WriteCommand(0x06);        //文字不動,光標自動右移
  84.         WriteCommand(0x38);        //設置顯示模式:8位2行5x7點陣
  85. }
  86. //顯示單個字符
  87. void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
  88. {
  89.         if (bRow)                 WriteCommand(0xc0 + btColumn);
  90.         else                      WriteCommand(0x80 + btColumn);
  91.         if (bIsNumber)         WriteData(btData + 0x30);
  92.         else                   WriteData(btData);
  93. }
  94. //顯示字符串函數
  95. void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
  96. {
  97.         while (*pData != '\0')
  98.            {
  99.                    if (bRow) WriteCommand(0xc0 + btColumn);        //顯示在第1行
  100.                    else            WriteCommand(0x80 + btColumn);        //顯示在第0行
  101.                 WriteData(*(pData++));                                                //要顯示的數據
  102.                 btColumn++;        //列數加一
  103.            }
  104. }
  105. //延時16us子函數
  106. void Delay16us()
  107. {
  108.         unsigned char a;
  109.         for (a = 0; a < 4; a++);
  110. }
  111. //延時60us子函數
  112. void Delay60us()
  113. {
  114.         unsigned char a;
  115.         for (a = 0; a < 18; a++);
  116. }
  117. //延時480us子函數
  118. void Delay480us()
  119. {
  120.         unsigned char a;
  121.         for (a = 0; a < 158; a++);
  122. }
  123. //延時240us子函數
  124. void Delay240us()
  125. {
  126.         unsigned char a;
  127.         for (a = 0; a < 78; a++);
  128. }
  129. //延時500ms子函數
  130. void Delay500ms()
  131. {
  132.         unsigned char a, b, c;
  133.         for (a = 0; a < 250; a++)
  134.         for (b = 0; b < 3; b++)
  135.         for (c = 0; c < 220; c++);
  136. }
  137. //芯片初始化
  138. void Initialization()
  139. {
  140.         while(1)
  141.         {
  142.                 DQ = 0;
  143.                 Delay480us();                         //延時480us
  144.                 DQ = 1;
  145.                 Delay60us();                        //延時60us
  146.                 if(!DQ)                                  //收到ds18b20的應答信號
  147.                 {
  148.                         DQ = 1;
  149.                         Delay240us();                //延時240us
  150.                         break;
  151.                 }
  152.         }
  153. }
  154. //寫一個字節(從低位開始寫)
  155. void WriteByte(unsigned char btData)
  156. {
  157.         unsigned char i, btBuffer;
  158.         for (i = 0; i < 8; i++)
  159.         {
  160.                 btBuffer = btData >> i;
  161.                 if (btBuffer & 1)
  162.                 {
  163.                         DQ = 0;
  164.                         _nop_();
  165.                         _nop_();
  166.                         DQ = 1;
  167.                         Delay60us();
  168.                 }
  169.                 else
  170.                 {
  171.                         DQ = 0;
  172.                         Delay60us();
  173.                         DQ = 1;
  174.                 }
  175.         }
  176. }
  177. //讀一個字節(從低位開始讀)
  178. unsigned char ReadByte()
  179. {
  180.         unsigned char i, btDest;
  181.         for (i = 0; i < 8; i++)
  182.         {
  183.                 btDest >>= 1;
  184.                 DQ = 0;
  185.                 _nop_();
  186.                 _nop_();
  187.                 DQ = 1;
  188.                 Delay16us();
  189.                 if (DQ) btDest |= 0x80;
  190.                 Delay60us();
  191.         }
  192.         return btDest;
  193. }
  194. //序列號匹配
  195. void MatchROM(const unsigned char *pMatchData)
  196. {
  197.         unsigned char i;
  198.         Initialization();
  199.         WriteByte(MATCH_ROM);
  200.         for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
  201. }
  202. //得到64位ROM序列(在P1口顯示,必須與Proteus聯調且在單步調試下才能得到)
  203. /*void GetROMSequence()
  204. {
  205.         unsigned char i;
  206.         Initialization();
  207.         WriteByte(READ_ROM);
  208.         for (i = 0; i < 8; i++)
  209.         P1 = ReadByte();
  210. }*/
  211. //讀取溫度值
  212. TEMPDATA ReadTemperature()
  213. {
  214.         TEMPDATA TempData;
  215.         unsigned int iTempDataH;
  216.         unsigned char btDot, iTempDataL;
  217.         static unsigned char i = 0;
  218.         TempData.btNegative = 0;                                                //為0溫度為正
  219.         i++;
  220.         if (i == 9) i = 1;
  221.         Initialization();
  222.         WriteByte(SKIP_ROM);                                                        //跳過ROM匹配
  223.         WriteByte(TEMP_SWITCH);                                                        //啟動轉換
  224.         Delay500ms();        //調用一次就行
  225.         Delay500ms();
  226.         Initialization();
  227.         //多個芯片的時候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
  228.         switch (i)
  229.         {
  230.                 case 1 : MatchROM(ROMData1); break;                        //匹配1
  231.                 case 2 : MatchROM(ROMData2); break;                        //匹配2
  232.                 case 3 : MatchROM(ROMData3); break;                        //匹配3
  233.                 case 4 : MatchROM(ROMData4); break;                        //匹配4
  234.                 case 5 : MatchROM(ROMData5); break;                        //匹配5
  235.                 case 6 : MatchROM(ROMData6); break;                        //匹配6
  236.                 case 7 : MatchROM(ROMData7); break;                        //匹配7
  237.                 case 8 : MatchROM(ROMData8); break;                        //匹配8
  238.         }
  239.         //WriteByte(SKIP_ROM);                                                        //跳過ROM匹配(單個芯片時用這句換掉上面的switch)
  240.         WriteByte(READ_MEMORY);                                                        //讀數據
  241.         iTempDataL = ReadByte();
  242.         iTempDataH = ReadByte();
  243.         iTempDataH <<= 8;
  244.         iTempDataH |= iTempDataL;
  245.         if (iTempDataH & 0x8000)
  246.         {
  247.                 TempData.btNegative = 1;
  248.                 iTempDataH = ~iTempDataH + 1;                                //負數求補
  249.         }
  250. ……………………
  251. …………限于本文篇幅 余下代碼請從51黑下載附件…………
8路溫度.rar (2.74 MB, 下載次數: 331)
原理圖及PCB圖在附件中
ID:471817 發表于 2019-7-18 08:40 來自觸屏版 | 顯示全部樓層
學習學習
ID:603222 發表于 2019-8-24 16:55 | 顯示全部樓層
謝謝分享
ID:501249 發表于 2020-2-1 20:35 | 顯示全部樓層
仿真沒有
ID:193421 發表于 2020-2-24 16:39 | 顯示全部樓層
學習了,很有用,謝謝大佬。
ID:721707 發表于 2020-4-16 23:21 | 顯示全部樓層
謝謝分享
ID:97678 發表于 2022-9-16 08:15 | 顯示全部樓層
好東西!!! 找了很久才看到!
ID:97678 發表于 2022-9-23 12:40 | 顯示全部樓層
謝謝分享!!! 原理圖打不開了。是不是損壞了?
ID:262 發表于 2022-9-27 01:19 | 顯示全部樓層
jovew 發表于 2022-9-23 12:40
可以打開啊
ID:1017814 發表于 2022-9-27 07:41 | 顯示全部樓層
有沒有仿真圖或實際效果圖啊,學習了。
ID:97678 發表于 2022-9-27 08:06 | 顯示全部樓層
文件打開了。 謝謝!
奇怪的錯誤。
ID:1047158 發表于 2022-10-11 19:18 來自觸屏版 | 顯示全部樓層
焊出的實物,為啥顯示屏只顯示零啊
ID:195496 發表于 2022-11-12 10:03 | 顯示全部樓層
看了文檔才明白是先一個一個讀出ROM,再按ROM調用,我以為直接實現了ROM自動搜索,看來ROM搜索是個難點
ID:399179 發表于 2022-11-12 12:01 來自觸屏版 | 顯示全部樓層
感謝樓主無私奉獻,收藏了!
ID:894868 發表于 2023-2-10 14:48 | 顯示全部樓層
謝謝分享,學習一下18B20
