查看: 3761|回復(fù): 7
我寫的這個(gè)單片機(jī)程序,為什么數(shù)碼管顯示一樣的,還是亂碼 顯示函數(shù)怎么寫?
這張是顯示的圖紙!
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. sbit led1=P3^3;
  6. sbit led=P1^5;
  7. sbit led2=P3^6;
  8. sbit fan=P1^6;
  9. sbit ptc=P3^4;
  10. sbit we1=P2^6;
  11. sbit we2=P2^7;
  12. sbit we3=P2^1;
  13. sbit we4=P2^0;
  14. sbit we5=P2^2;
  15. sbit fm=P2^5;
  16. sbit sw1=P1^0;
  17. sbit sw2=P1^4;
  18. sbit sw3=P3^5;
  19. sbit sw4=P3^7;
  20. uchar code duma[]={0x3f,0x06,0x5b,0x4f,
  21.                                    0x66,0x6d,0x7d,0x07,
  22.                                    0x7f,0x6f,0x77,0x7c,
  23.                                    0x39,0x5e,0x79,0x71
  24.                                    };
  25.
  26.
  27. uchar  counter,   time,time_counter, h;
  28.
  29.
  30.
  31. uchar i ;
  32. void delay(uint z);
  33. void delay(uint z)
  34. {
  35.   while (z--);
  36. }
  37. void display(uchar mshi,mge,sge,sshi,hge,hshi )
  38. {
  39.   mge=time_counter%10;
  40.   mshi=time_counter/10;
  41.   sge=time/10;
  42.   sshi=time%10;
  43.   hge=h/10;
  44.   hshi=h%10;
  45.    P0=0XFF;
  46.    we2=0;
  47.   P0=duma[mshi];
  48.   delay(100);
  49.    P0=0XFF;
  50.    we1=0;
  51.    P0=duma[mge];
  52.   delay(100);
  53.     P0=0XFF;
  54.            we4=0;
  55.   P0=duma[sshi];
  56.   delay(100);
  57.    P0=0XFF;
  58.    we3=0;
  59.   P0=duma[sge];
  60.   delay(100);
  61. /*  P0=0XFF;
  62. wea=0;
  63. web=0;
  64. wec=1;
  65.   P0=duma[hge];
  66.   delay(100);
  67.    P0=0XFF;
  68. wea=1;
  69. web=0;
  70. wec=1;
  71.   P0=duma[hshi];
  72.   delay(100);*/
  73. }
  74. void keypros()
  75. {
  76.         if(sw1==0)
  77.         {
  78.            delay(10);
  79.            if(sw1==0&&time!=60)
  80.            {
  81.                    time+=1;
  82.
  83.                   while(!sw1);
  84.            }
  85.         }
  86.          if(sw2==0)
  87.          {
  88.           delay(10);
  89.           if(sw2==0&&time!=0)
  90.           {
  91.                   time-=1;
  92.
  93.                    while(!sw2);
  94.           }
  95.          }
  96.          if(sw3==0)
  97.          {
  98.            delay(10);
  99.            if(sw3==0)
  100.            {
  101.                      TR1=0;
  102.                   led=1;
  103.                   time=0;
  104.                   time_counter=0;
  105.
  106.
  107.                   fan=1;
  108.                   ptc=1;
  109.                 while(!sw3);
  110.
  111.            }
  112.
  113.
  114.
  115.          }
  116.           if(sw4==0)
  117.           {
  118.            delay(10);
  119.
  120.            if(sw4==0)
  121.            {
  122.                    TR1=~TR1;
  123.                 led=~led;
  124.
  125.
  126.                 ptc=~ptc;
  127.                 fan=~fan;
  128.                 while(!sw4);
  129.            }
  130.
  131.           }
  132. }
  133. void init()
  134. {
  135.   TMOD=0x10;
  136.   TH1=0x4b;
  137.   TL1=0x00;
  138.   TR1=0;
  139. }
  140. void main()
  141. {
  142.
  143.                          init();
  144.                         led2=0;
  145.
  146.     while(1)
  147.         {
  148.         keypros();
  149.
  150.    if(TF1==1)
  151.    { TF1=0;
  152.             TH1=0x4b;
  153.      TL1=0x00;
  154.             counter++;
  155.    }
  156.          if(counter==20)
  157.         {
  158.          counter=0;
  159.          time_counter++;
  160.           led1=~led1;
  161.         }
  162.         if(time_counter==60)
  163.           {
  164.                 time--;
  165.                  time_counter=0;
  166.
  167.         }
  168.         if(time==0)
  169.            {
  170.            TR1=0;
  171.                 led=1;
  172.                    led1=1;
  173.                 ptc=1;
  174.                 fan=1;
  175.                time=60;
  176.
  177.            }
  178.                   display();
  179.      }
  180.
  181.
  182. }
ID:158886 發(fā)表于 2019-7-10 15:58 | 只看該作者
顯示亂碼我知道了,是數(shù)碼管是共陽(yáng)極的,我用的共陰極的表,才導(dǎo)致顯示亂碼,但這個(gè)顯示函數(shù)怎么寫,進(jìn)位顯示數(shù)碼管,
ID:205483 發(fā)表于 2019-7-10 23:41 | 只看該作者
RE: 我寫的這個(gè)單片機(jī)程序,為什么數(shù)碼管顯示一樣的,還是亂碼 顯示函數(shù)怎么寫?
你這個(gè)太亂了,一個(gè)注澤都沒,wea、web、wec也不知道是什么
  •    P0=0XFF;
  • wea=1;
  • web=0;
  • wec=1;
  •   P0=duma[hshi];
  •   delay(100);*/
  •    P0=0XFF;
  •    we1=1;  //位1開顯示
  •    P0=duma[mge];
  •    delay(100);
  •    we1=0;  //位1關(guān)顯示
你顯示完一個(gè)數(shù)碼管,要把位清0,不然一輪下來(lái)所有位都在顯示,會(huì)亂碼。
進(jìn)位不知道你指的什么,counter,   time,time_counter, h; 看不出來(lái)你這幾個(gè)變量的具體作用
  •    if(TF1==1)
  •        TF1=0;
  •        TH1=0x4b;
  •        TL1=0x00;
  •        counter++;
  •                   //這個(gè)計(jì)數(shù)的值太小了,8M的話才5ms,1秒得counter得加200次,
  •   if(counter==20) //0.1秒進(jìn)一次,改成counter==200,就是1S進(jìn)一次 ,如果你是設(shè)計(jì)秒表就不用改
  •        counter=0;
  •        time_counter++;
  •        led1=~led1; /
ID:462827 發(fā)表于 2019-7-11 10:11 | 只看該作者
多只數(shù)碼管的顯示,一是要?jiǎng)討B(tài)掃描,二是要消影。
ID:158886 發(fā)表于 2019-7-12 14:45 | 只看該作者
謝謝,知道了,謝謝
ID:158886 發(fā)表于 2019-7-12 14:46 | 只看該作者
hantu 發(fā)表于 2019-7-11 10:11
謝謝,上面的顯示函數(shù)寫成了靜態(tài)顯示了,改了動(dòng)態(tài)就可以了,
ID:158886 發(fā)表于 2019-7-12 14:47 | 只看該作者
素還真.____ 發(fā)表于 2019-7-10 23:41
  •    P0=0XFF;
  • wea=1;
  • WE,就是位選信號(hào)。
    ID:158886 發(fā)表于 2019-7-12 14:54 | 只看該作者
      #include<reg52.h>
    #include<intrins.h>
    sbit led1=P3^3;
    sbit led=P1^5;
    sbit led2=P3^6;
    sbit fan=P1^6;
    sbit ptc=P3^4;
    sbit we1=P2^6;
    sbit we2=P2^7;
    sbit we3=P2^1;
    sbit we4=P2^0;
    sbit we5=P2^2;
    sbit fm=P2^5;
    sbit sw1=P1^0;
    sbit sw2=P1^4;
    sbit sw3=P3^5;
    sbit sw4=P3^7;
    uchar code duma[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
    0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e
    uchar i ;
    void delay(uint z);
    void delay(uint z)
      while (z--);
    void display(uchar mshi,uchar mge,uchar sge,uchar sshi,uchar hge,uchar hshi )
      sge=time/10;
      sshi=time%10;
      hge=h/10;
      hshi=h%10;
       P0=0XFF;
       we1=0;
       we2=1;
       we3=1;
       we4=1;
        P0=duma[mge];
            delay(100);
      P0=0XFF;
      we1=1;
       we2=0;
       we3=1;
       we4=1;
       P0=duma[mshi];
       delay(100);
       P0=0XFF;
       we1=1;
       we2=1;
       we3=0;
       we4=1;
       P0=duma[sshi];
       delay(100);
      P0=0XFF;
      we1=1;
       we2=1;
       we3=1;
       we4=0;
      P0=duma[sge];
       delay(100);
    void keypros()
    if(sw1==0)
            { delay(10);
                       time+=1;
                     fm=0;
                     delay(10000);
                     fm=1;
                     delay(10000);
                      while(!sw1);
    if(sw2==0)
              delay(10);
              if(sw2==0&&time!=0)
                      time-=1;
                    fm=0;
                     delay(10000);
                     fm=1;
                     delay(10000);
                       while(!sw2);
    if(sw3==0)
               delay(10);
               if(sw3==0)
               { fm=0;
                     delay(10000);
                     fm=1;
                     delay(10000);
                         TR1=0;
                      led=1;
                      time=0;
                      time_counter=0;
                      fan=1;
                      ptc=1;
                    while(!sw3);
    if(sw4==0)
               delay(10);
               if(sw4==0)
                       TR1=~TR1;
                    led=~led;
                    fm=0;
                     delay(10000);
                     fm=1;
                     delay(10000);
             ptc=~ptc;
                    fan=~fan;
                    while(!sw4);
    void init()
      TMOD=0x10;
      TH1=0x4b;
      TL1=0x00;
      TR1=0;
                             init();
                            led2=0;
            keypros();
       if(TF1==1)
       { TF1=0;
                TH1=0x4b;
         TL1=0x00;
                counter++;
             if(counter==20)
             counter=0;
             time_counter++;
              led1=~led1;
                    time--;
                     time_counter=0;
            if(time==0)
               TR1=0;
                    led=1;
                       led1=1;
                    ptc=1;
                    fan=1;
                   time=60;
                      display();
    }        現(xiàn)
      這個(gè)是正常顯示,,這個(gè)程序是60分鐘,倒計(jì)時(shí),時(shí)間可以調(diào),時(shí)間到停止輸出
    LED1,F(xiàn)AN風(fēng)扇,PTC加熱,都停止輸出,這個(gè)程序是用在艾灸上,謝謝大家指點(diǎn)!有你們真好!
