查看: 2259|回復: 1
基于單片機的病房呼叫系統(十六個床位)
ID:580346 發表于 2019-7-8 22:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#define uchr unsigned char
sbit led0=P2^2;
sbit buzzer=P2^3;
sbit dula=P2^6;                //聲明段選線選通端
sbit wela=P2^7;                //聲明位選線選通端
sbit clear=P3^4;
uchr key,shi,ge,count;
uchr code tab[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0x76,0x79,0x38,0x3f};
/*延時子函數,xms為形參*/
void delay(uint xms)
    uint x,y;
    for(x=xms;x>0;x--)
        for(y=110;y>0;y--);
/*矩陣鍵盤掃描子程序*/
void matrixkeyscan()
    uint temp;
    P3=0xf7;                             //給P3口賦值
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)                       //檢測是否有鍵按下
        delay(6);                       //延時去抖
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)                   //再次檢測是否有鍵按下
            temp=P3;
            switch(temp)
                case 0x77:
                    key=1;
                    break;
                case 0xb7:
                    key=2;
                    break;
                case 0xd7:
                    key=3;
                    break;
                case 0xe7:
                    key=4;
                    break;              //判斷按下的是哪個鍵
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
            }                           //等待按鍵釋放
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
        delay(6);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
case 0x7b:
                    key=5;
                    break;
                case 0xbb:
                    key=6;
                    break;
                case 0xdb:
                    key=7;
                    break;
                case 0xeb:
                    key=8;
                    break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
        delay(6);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
                case 0x7d:
                    key=9;
                    break;
                case 0xbd:
                    key=10;
                    break;
               case 0xdd:
                    key=11;
                    break;
                case 0xed:
                    key=12;
                    break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
        delay(6);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
                case 0x7e:
                    key=13;
                    break;
                case 0xbe:
                    key=14;
                    break;
                case 0xde:
                    key=15;
                    break;
                case 0xee:
                    key=16;
                    break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
/*主函數*/
void alarm()
        buzzer=~buzzer;
        led0=~led0;
        delay(30);
    void display(uchr num)
                if(key!=0)             //若有鍵按下,則進入該循環進行處理
            dula=1;
            P0=tab[num/10];
            dula=0;
             P0=0x00;
            wela=1;
            P0=0xfe;
            wela=0;
            delay(100);
            dula=1;
            P0=tab[num%10];
            dula=0;
           P0=0x00;
                  wela=1;
                   P0=0xfd;
                   wela=0;
                   delay(100);
                   alarm();
        P0=0x00;
        matrixkeyscan();
        display(key);
ID:1 發表于 2019-7-10 18:19 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
