win7中的99se添加原理圖和封裝庫方法
步驟一、到C盤(系統(tǒng)盤),系統(tǒng)文件夾(c:\windows)下的ADVPCB99SE和ADVSch99SE文件先配置原理圖圖,用本文打開ADVPCB99SE文件,在[Change Library File List]下找到File0,可以發(fā)現(xiàn),等號后面的的內(nèi)容就是默認(rèn)已經(jīng)添加的庫,把這個改為我們自定義的庫(記得路徑要正確),在打開99,默認(rèn)添加的就是我們的庫了,如果要添加多個就在File0后面添File1,File2..依次類推,但注意最后修改File0上面的Count屬性,如果你添了兩個,就把它的值改為2.舉個例子:
Count=2
File0=d:\Program Files\Design Explorer 99 SE\Library\Sch\DPT8_PCBSch(2007-07-24).ddb
File1=d:\Program Files\Design Explorer 99 SE\Library\Sch\Protel DOS Schematic Libraries.ddb
步驟二、修改PCB的庫配置,同樣用文本打開ADVPCB99SE文件,在[PCB Libraries]下找到File0進(jìn)行修改或添加,舉個例子參考:
Count=5
File0=D>MSACCESS$RP>D:\Program Files\Design Explorer 99 SE\Library\Pcb\Generic Footprints$RN>Advpcb.ddb$OP>$ON>Footprints.lib$ID>-1$ATTR>0$E>$CBLIB$STF>
File1=D>MSACCESS$RP>D:\Program Files\Design Explorer 99 SE\Library\Pcb\Generic Footprints$RN>Advpcb.ddb$OP>$ON>General IC.lib$ID>-1$ATTR>0$E>$CBLIB$STF>
File2=D>MSACCESS$RP>D:\Program Files\Design Explorer 99 SE\Library\Pcb\Generic Footprints$RN>Advpcb.ddb$OP>$ON>Headers.lib$ID>-1$ATTR>0$E>$CBLIB$STF>
File3=D>MSACCESS$RP>D:\Program Files\Design Explorer 99 SE\Library\Pcb\Generic Footprints$RN>Advpcb.ddb$OP>$ON>International Rectifiers.lib$ID>-1$ATTR>0$E>$CBLIB$STF>
File4=D>MSACCESS$RP>D:\Program Files\Design Explorer 99 SE\Library\Pcb\Generic Footprints$RN>Advpcb.ddb$OP>$ON>Transistors.lib$ID>-1$ATTR>0$E>$CBLIB$STF> |
