查看: 3949|回復(fù): 0
單片機(jī)按鍵計(jì)數(shù)程序
#include<reg52.h>
#include<intrins.h>
typedef   unsigned char  uchar;
typedef   unsigned int   uint;
sbit P20=P2^0;
sbit P21=P2^1;
sbit P32=P3^2;
sbit P33=P3^3;
sbit BEEP=P1^5;
uchar code Led_Table[12]= { 0x3F,0X06,0X5B,0X4F,0X66,0X6D,0X7D,0X07,0X7F,0X6F,0x40,0x00     };
uchar cnt,n,t=1;
uint i;
//延時(shí)函數(shù)
void delay(uint i)
{ uchar j;
  for(i;i>0;i--)
     for(j=0;j<100;j++)
//蜂鳴器
  void beep()
  unsigned char i;
  for (i = 0; i < 180; i++)
   delay(10);
    BEEP = !BEEP; //BEEP取反
  BEEP = 1; //關(guān)閉蜂鳴器
  delay(10);
void  main(void)
{   BEEP=1;
        IT0=0; //實(shí)驗(yàn)箱IT位必須設(shè)置成0 才合適,但是仿真IT位是0是1都不影響
        EX0=1;
        IT1=0;
           EX1=1;
    EA=1;
        TMOD=0X01;
    TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;ET0=1;
        //TR0=0;
    n=0;
        cnt=0;
        P20=P21=1;
        P20=1;
        //數(shù)碼管刷新
     P20=0;
         P0=Led_Table[n/10];
         delay(10);
         P20 = 1;
         P21=0;
         P0=Led_Table[n%10];
         delay(10);
         P21 = 1;
         if(cnt==20)
                cnt=0;n++;
         if(t==0)
            {TR0=0;t=1;}
         if(n==60)
           {beep();n=0;}
void int0() interrupt 1
{EX0=0;
//if        (P32==0)
// for (i=0;i<5000;i++);
while(P32==0);
  TR0=1;
  cnt++;
  EX0=1;
  void int1() interrupt 2
{EX1=0;
  //if        (P33==0)
  while(P33==0);
   t=0;
   EX1=1;
