之前的上傳錯(cuò)了附件 程序在下面,可能因?yàn)橛姓{(diào)子,有點(diǎn)多,要在附件下載
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^2;//按key1可以暫停播放
- sbit key2=P3^3;//按key2可切換歌曲
- sbit fm=P3^7;//蜂鳴器連續(xù)的IO口
- uchar code shuzi0=0x3f;
- uchar code shuzi1=0x06;//數(shù)字1
- uchar code shuzi2=0x5b;//數(shù)字2
- uchar code shuzi3=0x4f;
- uchar code shuzi4=0x66;
- uchar code shuzi5=0x6d;
- uchar code shuzi6=0x7d;
- uchar code shuzi7=0x07;
- uchar code shuzi8=0x7f;
- uchar count1;//播放暫停標(biāo)志
- uchar count2;//歌曲標(biāo)志
- uchar timeh,timel,i;
- //---------------------------簡(jiǎn)譜---------------------------------------
- /*unsigned char code Music_Same[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03,
- 0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02,
- 0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02,
- 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66,
- 0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00,
- 0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03,
- 0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02,
- 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03,
- 0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03,
- 0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C,
- 0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66,
- 0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03,
- 0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01,
- 0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02,
- 0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03,
- 0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70,
- 0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66,
- 0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02,
- 0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C,
- 0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66,
- 0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00,
- 0x00,0x00 };
- //兩只蝴蝶
- unsigned char code Music_Two[] ={ 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
- 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
- 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
- 0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
- 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01,
- 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
- 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01,
- 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
- 0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03,
- 0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01,
- 0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
- 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00,
- 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
- 0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03,
- 0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03,
- 0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
- 0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
- 0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E,
- 0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E,
- 0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03,
- 0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03,
- 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03,
- 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03,
- 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
- 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01,
- 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03,
- 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
- 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
- 0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
- 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,
- 0x10,0x03, 0x15,0x00, 0x00,0x00 };
- //北京歡迎你
- unsigned char code Music_Code[]={ 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x03,
- 0x16,0x03, 0x17,0x02, 0x17,0x67, 0x16,0x03, 0x10,0x03,
- 0x15,0x03, 0x17,0x03, 0x16,0x66, 0x16,0x03, 0x15,0x03,
- 0x10,0x03, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x03,
- 0x16,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x03, 0x0F,0x03,
- 0x16,0x03, 0x15,0x66, 0x16,0x03, 0x15,0x03, 0x10,0x03,
- 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x03, 0x16,0x03,
- 0x17,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x01,
- 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x19,0x67,
- 0x1A,0x04, 0x17,0x02, 0x10,0x03, 0x17,0x03, 0x16,0x03,
- 0x16,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x03, 0x1F,0x03,
- 0x19,0x03, 0x1A,0x66, 0x19,0x03, 0x1A,0x03, 0x19,0x03,
- 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x19,0x66, 0x17,0x03,
- 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x20,0x03, 0x1F,0x03,
- 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x19,0x02, 0x17,0x03,
- 0x17,0x01, 0x17,0x03, 0x19,0x03, 0x1F,0x03, 0x19,0x03,
- 0x1A,0x66, 0x1F,0x03, 0x20,0x67, 0x1F,0x04, 0x19,0x03,
- 0x17,0x03, 0x19,0x03, 0x1F,0x03, 0x1A,0x66, 0x17,0x03,
- 0x16,0x03, 0x17,0x03, 0x1A,0x03, 0x21,0x03, 0x20,0x66,
- 0x20,0x03, 0x1F,0x01, 0x1F,0x66, 0x17,0x03, 0x19,0x03,
- 0x15,0x03, 0x19,0x03, 0x1A,0x66, 0x1F,0x03, 0x20,0x66,
- 0x1F,0x04, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x1F,0x03,
- 0x1A,0x66, 0x17,0x03, 0x16,0x03, 0x17,0x03, 0x1A,0x03,
- 0x21,0x03, 0x20,0x0B, 0x20,0x0B, 0x20,0x0B, 0x20,0x0B,
- 0x20,0x02, 0x1F,0x03, 0x1F,0x0B, 0x1F,0x0B, 0x1F,0x0B,
- 0x1F,0x0B, 0x1F,0x0B, 0x00,0x00 };
- //奧運(yùn)主題曲:我和你
- unsigned char code Music_Code1[]={ 0x17,0x02, 0x19,0x02, 0x15,0x01, 0x16,0x02, 0x17,0x02,
- 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02, 0x19,0x02,
- 0x16,0x00, 0x17,0x02, 0x19,0x02, 0x15,0x01, 0x16,0x02,
- 0x17,0x02, 0x10,0x01, 0x16,0x02, 0x0F,0x02, 0x16,0x02,
- 0x17,0x02, 0x15,0x00, 0x1A,0x01, 0x19,0x01, 0x1A,0x01,
- 0x15,0x01, 0x17,0x02, 0x10,0x02, 0x17,0x66, 0x19,0x03,
- 0x17,0x02, 0x15,0x00, 0x00,0x00 };*/
- uchar code muqin[]={ //母親
- 0x52,0x51,0x61,0x82,0x71,0x62,0x31,0x21,0x14,0x32,0x92,0x91,0x71,0x61,0x31,0x58,
- //你入學(xué)的新書包有人給你拿
- 0x52,0x51,0x61,0x82,0x71,0x62,0x51,0x61,0x34,0x62,0x61,0x51,0x51,0x31,0x28,
- //你雨中的花折傘有人給你打
- 0x32,0x31,0x21,0x52,0x51,0x31,0x22,0x31,0x21,0x12,0x21,0x32,0x51,0x71,0x61,0x52,0x68,
- //你愛吃的(那)三鮮餡有人(他)給你包
- 0x82,0x81,0x61,0x82,0x81,0x62,0x51,0x31,0x24,0x62,0x51,0x31,0x31,0x21,0x14,
- //你委屈的淚花有人給你擦
- 0x81,0x91,0xa1,0xa2,0xa1,0x92,0xa1,0x91,0x84,
- //啊,這個(gè)人就是娘
- 0x61,0x81,0x91,0x92,0xa1,0x91,0x71,0x61,0x71,0x61,0x58,
- //啊,這個(gè)人就是媽
- 0x61,0x82,0x61,0x82,0x81,0x61,0x52,0x61,0x51,0x64,
- //這個(gè)人給了我生命
- 0x62,0x81,0xa1,0x91,0x82,0x94,
- //給我一個(gè)家
- //啊,不管你走多遠(yuǎn)
- 0x61,0x81,0x92,0x71,0x61,0x71,0x61,0x58,
- //無論你在干啥
- 0x61,0x81,0x81,0x61,0x82,0x81,0x61,0x52,0x61,0x51,0x34,
- //到什么時(shí)候也離不開
- 0x62,0xa2,0x91,0x81,0x62,0x88,
- //咱的媽
- 0x62,0xa2,0x91,0x81,0x62,0x84,
- //咱的媽
- 0x81,0x91,0x62,0xf2,0x91,0x81,0x62,0x88,
- 0XFF,
- uchar code jmszl[]={ //寂寞沙洲冷
- 0x12,0x12,0x22,0x32,0x31,0x22,0x21,0x22,
- //自你走后心憔悴
- 0x21,0x31,0x51,0x52,0x31,0x52,0x61,0x15,0x14,
- //白色油桐風(fēng)中紛飛
- 0x51,0x52,0x31,0x52,0x62,0x13,0x11,0x13,0x32,0x28,0x08,0x28,
- //落花似人有情 這個(gè)季節(jié)
- 0x31,0x32,0x31,0x32,0x11,0x21,0x51,0x52,0x51,0x52,
- //河畔的風(fēng)放肆拼命地吹
- 0x51,0x51,0x31,0x32,0x31,0x32,0x81,0x72,0x63,
- //不斷撥弄離人的眼淚
- 0x62,0x71,0x81,0x72,0x61,0x61,0x52,0x31,0x21,0x32,0x51,0x54,
- //那樣濃烈的愛再也無法給
- 0x22,0x12,0x11,0x12,0x11,0x12,0x12,0x14,0x26,0x32,0x26,
- //傷感一夜一夜
- 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,
- //當(dāng)記憶的線纏繞過往支離破碎
- 0x02,0x32,0x81,0x81,0x81,0x81,0x62,0x52,0x34,
- //是慌亂占據(jù)了心扉
- 0x31,0x81,0x81,0x81,0x61,0x91,0x82,
- //有花兒伴著蝴蝶
- 0x51,0x51,0x51,0x51,0x31,0x61,0x53,
- //孤雁可以雙飛
- 0x21,0x11,0x21,0x11,0x22,0x11,0x21,0x26,
- //夜深人靜獨(dú)徘徊
- 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,0x52,
- //當(dāng)幸福戀人寄來紅色分享喜悅
- 0x31,0x31,0x81,0x81,0x81,0x61,0x91,0x81,0x61,0x31,0x56,
- //閉上雙眼難過頭也不敢回
- 0x32,0x32,0x81,0x81,0x81,0x81,0x91,0x81,0x61,0x81,0x61,0x51,0x31,0x51,0x34,
- //仍然撿盡寒枝不肯安歇微帶著后悔
- 0x21,0x31,0x51,0x31,0x21,0x11,0x61,0x21,0x16,
- //寂寞沙洲我該思念誰
- 0xff};
- uchar code mamahao[]={ //世上只有媽媽好
- //世上只有媽媽好
- 0x68,0x52,0x34,0x54,0x84,0x62,0x52,0x68,
- //世上只有媽媽好
- 0x34,0x52,0x62,0x54,0x34,0x12,0xc2,0x52,0x32,0x28,
- //有媽的孩子像個(gè)寶
- 0x24,0x32,0x54,0x52,0x62,0x34,0x24,0x18,
- //投進(jìn)了媽媽的懷抱
- 0x54,0x32,0x22,0x12,0xc2,0x12,0xb8,0x04,0xff,
- //幸福享不了
- uchar code exql[]={ //兒行千里
- // 兒行千里
- 0x62,0x61,0x61,0x61,0x72,0x51,0x68,
- //衣裳在添幾件,
- 0x62,0x61,0x61,0x61,0x71,0x51,0x38,
- //飯菜多吃幾口,
- 0x32,0x31,0x62,0x31,0x21,0x31,0x14,0x22,0x21,0x21,0x12,0x61,0x38,
- //出門在外沒有媽熬的小米粥,
- 0x62,0x62,0x61,0x72,0x51,0x68,
- //一會(huì)兒看看臉,
- 0x62,0x62,0x61,0x72,0x51,0x38,
- //一會(huì)兒摸摸手,
- 0x34,0x62,0x61,0x31,0x22,0x21,0x31,0x14,
- //一會(huì)兒又把囑咐的話,
- 0x22,0x21,0x31,0x12,0x61,0x68,
- //裝進(jìn)兒的兜;
- 0x62,0x84,0x62,0x92,0x84,0x72,0x61,0x71,0x51,0x32,0x31,0x52,0x64,
- //如今要到了,離開家的時(shí)候,
- 0x62,0x84,0x62,0x91,0xa1,0x84,0x72,0x61,0x71,0x62,0x52,0x51,0x61,0x34,
- //才理解兒行千里母擔(dān)憂,
- 0x32,0x62,0x62,0x31,0x21,0x32,0x34,0x02,0x32,0x62,0x62,0x31,0x21,0x12,0x14,0x02,
- //千里的路啊,我還一步?jīng)]走,
- 0x71,0x72,0x61,0x22,0x31,0x31,0x52,0x31,0x52,0x62,
- //就看見淚水在媽媽眼里,
- 0x82,0x81,0x71,0x61,0x62,0x28,0x62,0x61,0x71,0x52,0x31,0x68,0x68,0xff,
- //媽媽眼里流,媽媽眼里流;
- uchar code ganen[]={//感恩的心
- 0x12,0x14,0x22,0x32,0x54,
- //我來自偶然,
- 0x32,0x84,0x72,0x62,0x54,
- //像一顆塵土,
- 0x02,0x62,0x62,0x52,0x54,0x12,0x22,0x32,0x28,
- //有誰看出我的脆弱,
- //我來自何方,
- 0x32,0x84,0x92,0x82,0x54,
- //我情歸何處,
- 0x32,0x24,0x21,0x61,0x54,0x22,0x32,0x12,0x18,
- //誰在下一刻呼喚我,
- 0x22,0x24,0x12,0x24,0x11,0x21,0x34,0x32,0x21,0x31,0x34,
- //天地雖寬 這條路卻難走
- 0x12,0x22,0x22,0x22,0x11,0x21,0x22,0x64,0x52,0x52,0x32,0x38,
- //我看遍這人間坎坷辛苦
- 0x31,0x52,0x51,0x52,0x31,0x51,0x58,
- //我還有多少愛
- 0x31,0x82,0x81,0x82,0x31,0x61,0x68,
- //我還有多少淚
- 0x62,0x62,0x62,0x51,0x61,0x64,0x61,0x82,0x61,0x9c,
- //要蒼天知道 我不認(rèn)輸
- 0x52,0xa4,0x92,0xa4,0x32,0x84,0x72,0x64,
- //感恩的心 感謝有你
- 0x62,0x94,0x82,0x94,
- //伴我一生
- 0x61,0x81,0x92,0x91,0x91,0x92,0x81,0xa1,0xa2,0x92,0x94,
- //讓我有勇氣做我自己
- //感恩的心 感謝命運(yùn)
- 0x52,0x62,0x81,0x81,0x82,0x92,0xa2,0x94,0x82,0x72,0x82,0x88,
- //花開花落我一樣會(huì)珍惜
- uchar code tiger[]={//兩只老虎
- 0x14,0x24,0x34,0x14,0x14,0x24,0x34,0x14,
- //兩只老虎兩只老虎
- 0x34,0x44,0x58,0x34,0x44,0x58,
- //跑得快跑得快
- 0x52,0x61,0x52,0x41,0x34,0x14,0x52,0x61,0x52,0x41,0x34,0x14,
- //一只沒有眼睛一只沒有尾巴
- 0x14,0xb4,0x18,0x14,0xb4,0x18,0xff,
- //真奇怪真奇怪
- uchar code qizige[]={ //七子之歌
- 0x54,0x32,0x52,0x32,0x54,
- //你可知MACAU
- 0x62,0x52,0x32,0x62,0x54,
- //不是我真姓
- 0x14,0x12,0x22,0x34,0x52,0x32,
- //我離開你太久了
- 0x02,0x32,0x58,
- //母親
- 0x52,0x52,0x62,0x52,0x32,0x54,0x52,0x62,0x52,0x82,0x62,0x58,
- //但是他們擄去的是我的肉體
- 0x14,0x52,0x32,0x22,0x12,0x24,0x32,0x54,0x2,0x22,0x34,0x1f,0x18,
- //你依然保管我內(nèi)心的靈魂
- 0x04,0x54,0xa4,0x92,0x81,0x62,0x52,0x54,0x62,0x64,0x52,0x62,0x81,0xa2,0x82,0x9c,
- //那三百年來夢(mèng)寐不忘的生母啊
- 0x02,0x52,0xa4,0x92,0x81,0x62,0x52,0x54,
- //請(qǐng)叫兒的乳名:
- 0x62,0x64,0x52,0x64,0xa2,0x92,0x9f,
- //叫我一聲--澳門
- 0xa4,0x92,0x81,0x62,0x52,0x54,
- //母親!母親!
- 0x84,0x62,0x52,0x32,0x22,0x14,
- //我要回來
- 0x04,0x22,0x32,0x58,0x58,0x04,0x52,0x62,0x8f,0xff,
- //母親!母親!
- uchar code qnzl[]={ //千年之戀
- 0x12,0x22,0x34,0x84,0x74,0x54,0x38,0x42,0x32,0x22,0x42,0x34,0x84,0x72,0x82,0x94,0xA8,0x08,
- //前奏
- 0x32,0x31,0x21,0x32,0x52,0x32,0x31,0x21,0x32,0x62,
- //竹林的燈火 到過的沙漠
- 0x32,0x31,0x21,0x32,0x82,0x71,0x81,0x71,0x51,0x32,0x22,
- //七色的國(guó)度 不斷飄逸風(fēng)中
- //有一種神秘 灰色的旋渦
- 0x32,0x31,0x21,0x32,0x83,0x82,0x71,0x72,0x02,
- //將我卷入了迷霧中
- 0x63,0xA1,0xA2,0x62,0x92,0x82,0x52,
- //看不清的雙手
- 0x31,0x51,0x63,0x51,0x63,0x51,0x63,0x51,0x62,0x82,0x7C,0x02,
- //一朵花傳來誰經(jīng)過的溫柔
- 0x61,0x71,0x82,0x71,0x62,0xA2,0x71,0x76,
- //穿越千年的傷痛
- 0x61,0x71,0x82,0x71,0x62,0x52,0x31,0x36,
- //只為求一個(gè)結(jié)果
- 0x61,0x71,0x82,0x71,0x62,0xA3,0x73,0x62,0x53,
- //你留下的輪廓 指引我
- 0x42,0x63,0x83,0x83,0x91,0x91,
- //黑夜中不寂寞
- 0x61,0x71,0x82,0x71,0x62,0x0A2,0x71,0x76,
- //穿越千年的哀愁
- //是你在盡頭等我
- //最美麗的感動(dòng) 會(huì)值得
- 0x42,0x82,0x88,0x02,0x74,0x93,0x89,0xff//結(jié)束標(biāo)志
- //用一生守候
- //----------------------------簡(jiǎn)譜音調(diào)對(duì)應(yīng)的定時(shí)器初值---------------------------
- //適合11.0592M的晶振
- uchar code cuzhi[]={
- 0xff,0xff,//占位
- 0xFC,0x8E,//中央C調(diào)1-7
- 0xFC,0xED,
- 0xFD,0x43,
- 0xFD,0x6A,
- 0xFD,0xB3,
- 0xFD,0xF3,
- 0xFE,0x2D,
- 0xFE,0x47, //高八度1-7
- 0xFE,0x76,
- 0xFE,0xA1,
- 0xFE,0xC7,
- 0xFE,0xD9,
- 0xFE,0xF9,
- 0xFF,0x16
- uchar yinyue[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0x0,0x0};//將節(jié)拍轉(zhuǎn)換成燈亮的節(jié)奏
- void delay1(uint z); //延時(shí)1MS
- void delay(uint z); //延時(shí)165MS,即十六分音符
- void song();
- void beep();//蜂鳴器叫一聲
- main()
- P1=shuzi0;
- EA=1;//開總中斷
- EX0=1;//開外部中斷0
- IT0=1;//外部中斷0下降沿觸發(fā)方式
- EX1=1;//開外部中斷1
- IT1=1;//外部中斷1下降沿觸發(fā)方式
- TMOD=0x01;//定時(shí)器0工作在方式1
- TH0=0;
- TL0=0;
- ET0=1;
- while(1)
- if(count2!=0)
- switch(count2)
- case 1:
- song();
- break;
- break;
- else
- /*void key1() interrupt3
- EA=1;
- EX0=1;
- IT0=0;
- void int1() interrupt 2 //用于按鍵key2引起的中斷
- EA=0;//關(guān)總中斷
- delay1(1);//去抖
- if(key2==0)
- TR0=1;
- i=0;//從頭開始唱
- count2++;
- if(count2==9)
- count2=1;
- EA=1;//開總中斷
- void timer0() interrupt 1 //用于產(chǎn)生各種音調(diào)
- TH0=timeh;
- TL0=timel;
- fm=~fm;
- void song()
- uint temp;
- uchar jp;//jp是簡(jiǎn)譜
- int i=0;
- while(1)
- if(count2==1) //選曲
- { P1=shuzi1;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- temp=muqin[i];}
- if(count2==2)
- {P1=shuzi2;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- }temp=jmszl[i];}
- if(count2==3)
- {P1=shuzi3;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- }temp=mamahao[i];}
- if(count2==4)
- {P1=shuzi4;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- }temp=exql[i];}
- if(count2==5)
- { P1=shuzi5; if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- }temp=ganen[i];}
- if(count2==6)
- { P1=shuzi6;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- }temp=tiger[i];}
- if(count2==7)
- {P1=shuzi7;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- }temp=qizige[i];}
- if(count2==8)
- {P1=shuzi8;
- if(key1==0)
- while(1)
- fm=0;
- if(key1==1)
- break;
- } temp=qnzl[i];}
- if(temp==0xff)
- break;
- jp=temp/16; //取數(shù)的高4位
- P0=yinyue[jp];
- if(jp!=0)
- timeh=cuzhi[jp*2];
- timel=cuzhi[jp*2+1];
- else
- TR0=0;
- fm=1;//關(guān)蜂鳴器
- delay(temp%16); //取數(shù)的低4位
- TR0=0; //唱完一個(gè)音停10MS
- fm=1;
- delay1(10);
- TR0=1;
- i++;
- TR0=0;
- fm=1;
- void delay(uint z) //延時(shí)165MS,即十六分音符
- { uint x,y;
- for(x=z;x>0;x--)
- for(y=19000;y>0;y--);
- void delay1(uint z) //延時(shí)1MS
- { uint x,y;
- for(x=z;x>0;x--)
- for(y=112;y>0;y--);
- void beep() //蜂鳴器叫一聲
- { uchar i;
- for(i=0;i<50;i++)
- { fm=~fm;
- delay1(1);
- fm=1;
復(fù)制代碼 全部資料51hei下載地址:
音樂盒帶數(shù)碼管.rar
(32.91 KB, 下載次數(shù): 160)
2019-7-2 18:20 上傳
點(diǎn)擊文件名下載附件
