基于at89c51單片機的波形發(fā)生器
2019-7-1 16:23 上傳
代碼如下:
- #include<reg51.h>
- sbit wr=P3^6;
- sbit rd=P3^2;
- sbit key0=P1^0;
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit key4=P1^4;
- unsigned char flag;
- unsigned char const code
- SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,
- 0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,0xda,
- 0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,0xf6,0xf7,0xf8,
- 0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,
- 0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,
- 0xbf,0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,0x8c,
- 0x89,0x86,0x83,0x80,0x7d,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,
- 0x4f,0x4c,0x49,0x46,0x43,0x41,0x3e,0x3b,0x39,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,
- 0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,
- 0x3,0x2,0x1,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,
- 0x7,0x8,0x9,0xa,0xc,0xd,0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,0x25,0x27,
- 0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,0x57,
- 0x50,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c};
- unsigned char keyscan()
- unsigned char keyscan_num,temp;
- P1=0xff;
- temp=P1;
- if(~(temp&0xff))
- if(key0==0)
- keyscan_num=1;
- else if(key1==0)
- keyscan_num=2;
- else if(key2==0)
- keyscan_num=3;
- else if(key3==0)
- keyscan_num=4;
- else if(key4==0)
- keyscan_num=5;
- else
- keyscan_num=0;
- return keyscan_num;
- void init_DA0832()
- rd=0;
- wr=0;
- void SIN()
- unsigned int i;
- do{
- P2=SIN_code[i];
- i=i+1;
- }while(i<256);
- void Square()
- EA=1;
- ET0=1;
- TMOD=1;
- TH0=0xff;
- TL0=0x83;
- TR0=1;
- void Triangle()
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- P2=0xff;
- do{
- P2=P2-1;
- }while(P2>0x00);
- P2=0x00;
- void Sawtooth()
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- void Trapezoidal()
- unsigned char i;
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- P2=0xff;
- for(i=255;i>0;i--)
- P2=0xff;
- do{
- P2=P2-1;
- }while(P2>0x00);
- P2=0x00;
- void main()
- init_DA0832();
- do{
- flag=keyscan();
- }while(!flag);
- while(1)
- switch(flag)
- case 1:
- do{
- flag=keyscan();
- SIN();
- }while(flag==1);
- break;
- case 2:
- Square ();
- do{
- flag=keyscan();
- }while(flag==2);
- TR0=0;
- break;
- case 3:
- do{
- flag=keyscan();
- Triangle ();
- }while(flag==3);
- break;
- case 4:
- do{
- flag=keyscan();
- Trapezoidal ();
- }while(flag==5);
- break;
- default:
- flag=keyscan();
- break;
- void timer0(void) interrupt 1
- P2=~P2;
- TH0=0xff;
- TL0=0x83;
- TR0=1;
全部資料51hei下載地址:
波形發(fā)生器.zip
(66.95 KB, 下載次數(shù): 54)
2019-7-1 11:50 上傳
下載積分: 黑幣 -5
