查看: 11263|回復: 10
晶聯訊JLX12864G液晶屏 STM32F103T6驅動程序(ST7567)
晶聯訊JLX12864G液晶屏(COG封裝) STM32F103T6驅動(ST7567/ST7565R),從官方規格書C51單片機代碼移植,!
  1. #include "stm32f10x.h"
  2. #include "key.h"
  3. #include "lcd.h"
  4. unsigned char cheng1[];
  5. unsigned char gong1[];
  6. unsigned char zhuang1[];
  7. unsigned char tai1[];
  8. unsigned char shi1[];
  9. unsigned char yong1[];
  10. unsigned char bmp_12864_1[];
  11. unsigned char bmp_12864_2[];
  12. unsigned char bmp_12864_3[];
  13. unsigned char bmp_12864_4[];
  14. unsigned char bmp_12864_5[];
  15. unsigned char bmp_12864_6[];
  16. unsigned char Bmp_Tou[];
  17. int main(void)
  18. {
  19.         LCD_GPIO_Config();
  20.         KEY_GPIO_Config();
  21.
  22.         while(1)
  23.         {
  24.                 initial_lcd();
  25.
  26.                 clear_screen();        //clear all dots
  27.                 test_display(0x55,0xff);                                        //全顯示
  28.                 waitkey();
  29.     //delay(3000);
  30.                 test_display(0x55,0xaa);                                        //雪花1
  31.                 waitkey();
  32.     //delay(3000);
  33.                 test_display(0xaa,0x55);                                        //雪花2
  34.                 waitkey();
  35.     //delay(3000);
  36.                 clear_screen();        //clear all dots
  37.                 display_graphic_128x64(1,1,bmp_12864_1);         //顯示12864點陣圖片 回字型圖案
  38.                 waitkey();
  39.     //delay(3000);
  40.                 clear_screen();        //clear all dots
  41.                 display_graphic_128x64(1,1,bmp_12864_2);
  42.                 waitkey();
  43.                 //delay(3000);
  44.                 clear_screen();        //clear all dots
  45.                 display_graphic_128x64(1,1,bmp_12864_3);
  46.                 waitkey();
  47.                 //delay(3000);
  48.                 clear_screen();        //clear all dots
  49.                 display_graphic_128x64(1,1,bmp_12864_4);
  50.                 waitkey();
  51.     //delay(3000);
  52.
  53.
  54.                 clear_screen();        //clear all dots
  55.                 display_graphic_128x64(1,1,bmp_12864_5);
  56.                 waitkey();
  57.     //delay(3000);
  58.     clear_screen();        //clear all dots
  59.                 display_graphic_128x64(1,1,bmp_12864_6);
  60.                 waitkey();
  61.     //delay(3000);
  62.
  63.                 clear_screen();        //clear all dots
  64.                 display_graphic_32x32(1,(1+32*1),cheng1);         /*在第1頁,第49列顯示單個漢字"成"*/
  65.                 display_graphic_32x32(1,(1+32*2),gong1);         /*在第1頁,第49列顯示單個漢字"功"*/
  66.                 display_graphic_16x16_2(0,6,1,zhuang1);                 /*在第5頁,第1列顯示單個漢字"狀"*/
  67.                 display_graphic_16x16_2(0,6,(1+16),tai1);                 /*在第5頁,第17列顯示單個漢字"態"*/
  68.                 display_string_8x16(6,(1+16+16),":");                 /*在第5頁,第25列顯示單個字符":"*/
  69.                 display_graphic_16x16(6,(1+16*2+8),shi1);         /*在第5頁,第41列顯示單個漢字"使"*/
  70.                 display_graphic_16x16(6,(1+16*3+8),yong1);        /*在第5頁,第49列顯示單個漢字"用"*/
  71.                 display_string_8x16(6,89,"12:45");                         /*在第5頁,第89列顯示單個數字"0"*/
  72.                 waitkey();
  73.                 //delay(3000);
  74.                 clear_screen();                                                            //clear all dots
  75.                 display_string_8x16(1,1,"0123456789abcdef");/*在第1頁,第1列顯示字符串*/
  76.                 display_string_8x16(3,1,"~`!@#$%^&*()_-+=");/*在第*頁,第*列顯示字符串*/
  77.                 display_string_5x8(5,1," ! #$%&'()*+,-./01234");
  78.                 display_string_5x8(6,1,"56789:;<=>?@ABCDEFGHI");
  79.                 display_string_5x8(7,1,"JKLMNOPQRSTUVWXYZ[\\]^");
  80.                 display_string_5x8(8,1,"_`abcdefghijklmnopqrs");
  81.                 waitkey();
  82.                 //delay(3000);
  83.         }
  84. }
  85. unsigned char Bmp_Tou[]={0x00,0x10,0x10,0x10,0xFE,0x90,0x10,0xC0,0xBC,0x84,0x84,0xBE,0xC4,0x40,0x40,0x00,
  86. 0x00,0x02,0x22,0x41,0x3F,0x00,0x40,0x40,0x23,0x14,0x08,0x16,0x21,0x60,0x20,0x00};//投,16*16
  87. unsigned char cheng1[]={
  88. /*--  文字:  成  --*/
  89. /*--  宋體23;  此字體下對應的點陣為:寬x高=31x31   --*/
  90. /*--  高度不是8的倍數,現調整為:寬度x高度=32x32  --*/
  91. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,
  92. 0xFC,0xFC,0x88,0x00,0x00,0x1C,0x78,0xF0,0xE0,0x00,0x80,0x80,0x00,0x00,0x00,0x00,
  93. 0x00,0x00,0x00,0x00,0xFF,0xFF,0x83,0x83,0x83,0x83,0x83,0x83,0xC3,0xC3,0x03,0x1F,
  94. 0xFF,0xFF,0x83,0x03,0x03,0x03,0xC3,0xF3,0xF3,0x63,0x03,0x03,0x00,0x00,0x00,0x00,
  95. 0x00,0x00,0xFC,0xFF,0x3F,0x00,0x80,0x00,0x00,0x80,0xFF,0xFF,0x03,0x00,0x00,0x03,
  96. 0x9F,0xFF,0xF8,0xF8,0xBE,0x1F,0x07,0x01,0x00,0x00,0xE0,0x20,0x00,0x00,0x20,0x38,
  97. 0x1F,0x07,0x01,0x00,0x00,0x01,0x01,0x07,0x07,0x23,0x31,0x18,0x0C,0x0E,0x07,0x03,
  98. 0x01,0x01,0x01,0x03,0x07,0x0F,0x0E,0x1C,0x1F,0x3F,0x30,0x00,0x00,0x00,0x00,0x00};
  99. unsigned char gong1[]={
  100. /*--  文字:  功  --*/
  101. /*--  宋體23;  此字體下對應的點陣為:寬x高=31x31   --*/
  102. /*--  高度不是8的倍數,現調整為:寬度x高度=32x32  --*/
  103. 0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0xC0,0xC0,0x00,
  104. 0x00,0x00,0x00,0xFE,0xFC,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  105. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x0C,0x04,0x04,
  106. 0x04,0x84,0xFF,0xFF,0x04,0x04,0x04,0x04,0x04,0xFE,0xFE,0x04,0x00,0x00,0x00,0x00,
  107. 0xC0,0xC0,0xC0,0xC0,0xE0,0x60,0x7F,0x3F,0x30,0x30,0x10,0x18,0x18,0x88,0xC0,0xF8,
  108. 0x7F,0x1F,0x01,0x00,0x00,0x00,0x00,0xF8,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x01,
  109. 0x01,0x00,0x00,0x00,0x00,0x20,0x20,0x30,0x18,0x0C,0x0C,0x07,0x03,0x01,0x00,0x04,
  110. 0x04,0x0C,0x0C,0x1C,0x38,0x3C,0x1F,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  111. unsigned char zhuang1[]={
  112. /*--  文字:  狀  --*/
  113. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  114. 0x08,0x30,0x00,0xFF,0x20,0x20,0x20,0x20,0xFF,0x20,0xE1,0x26,0x2C,0x20,0x20,0x00,
  115. 0x04,0x02,0x01,0xFF,0x40,0x20,0x18,0x07,0x00,0x00,0x03,0x0C,0x30,0x60,0x20,0x00};
  116. unsigned char tai1[]={
  117. /*--  文字:  態  --*/
  118. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  119. 0x00,0x04,0x04,0x04,0x84,0x44,0x34,0x4F,0x94,0x24,0x44,0x84,0x84,0x04,0x00,0x00,
  120. 0x00,0x60,0x39,0x01,0x00,0x3C,0x40,0x42,0x4C,0x40,0x40,0x70,0x04,0x09,0x31,0x00};
  121. unsigned char shi1[]={
  122. /*--  文字:  使  --*/
  123. /*--  宋體12;  此字體下對應的點陣為:寬x高=1
  124. ……………………
  125. …………限于本文篇幅 余下代碼請從51黑下載附件…………
JHDLCDSTM32.7z (667.43 KB, 下載次數: 460)
收藏收藏8 分享淘帖 頂 踩
ID:267330 發表于 2019-9-27 16:39 | 只看該作者
正要用謝謝
ID:338858 發表于 2019-11-18 15:35 | 只看該作者
感謝大佬
ID:195403 發表于 2019-12-14 15:06 | 只看該作者
請問可以實現反白嗎?(菜單選擇的時候)
ID:58583 發表于 2019-12-26 09:57 | 只看該作者
感謝樓主  參考學習51移植
ID:723882 發表于 2020-4-21 19:39 | 只看該作者
謝謝樓主分享,感謝感謝
ID:235223 發表于 2020-11-17 10:40 | 只看該作者
正要用謝謝
ID:119108 發表于 2021-9-29 20:43 | 只看該作者
感謝樓主  參考學習51移植
ID:368583 發表于 2021-12-6 13:46 | 只看該作者
謝謝樓主分享,感謝感謝
ID:607710 發表于 2023-2-4 17:42 來自觸屏版 | 只看該作者
問一下,SPI的四種模式是根據規格書的那里說明配置的呢?一直沒搞清楚!!
ID:580286 發表于 2025-2-27 19:24 | 只看該作者
前來學習,正好用感謝而分享
