查看: 2150|回復: 2
51單片機proteus仿真電子琴生日快樂
ID:550077 發表于 2019-6-27 20:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
原C程序代碼如下:僅供學習之用!!!
#include<reg52.h>
#include<intrins.h>
sbit SPK = P2^7;
uchar tone_h;                //高音
uchar tone_l;                //低音
uint note = 1;                //音符
uchar beat;                        //節拍
uchar code chuzhi[3][16]={  //音調對應的計數初值
         0xff,0xff,//占0位
         0xf8,0x8c,//低1
         0xf9,0x5b,//  2
         0xfa,0x15,//  3
         0xfa,0x67,//  4
         0xfb,0x04,//  5
         0xfb,0x90,//  6
         0xfc,0x0c,//低7
         0xff,0xff,//占0位
         0xfc,0x44,//中1
         0xfc,0xac,//  2
         0xfd,0x09,//  3
         0xfd,0x34,//  4
         0xfd,0x82,//  5
         0xfd,0xc8,//  6
         0xfe,0x06,//中7
         0xff,0xff,//占0位
         0xfe,0x22,//高1
         0xfe,0x56,//        2
         0xfe,0x85,//        3
         0xfe,0x9a,//        4
         0xfe,0xc1,//        5
         0xfe,0xe4,//        6
         0xff,0x03 //高7
//****** 測試曲譜 ****** 個位:音調 ,十位:低中高音 對應 0 1 2,千百位:節拍 1~16
uint code test2[] = {        120, //曲速 暫時未用到
        401,402,403,404,405,406,407,
        611,612,613,614,615,616,617,
        821,822,823,824,825,826,827,
        0xffff        //0xffff表示結尾
//****** 生日快樂 ******
uint code test[] = { 120,
        205,205,406,405,411,807,
        205,205,406,405,412,811,
        205,205,415,413,411,407,406,
        314,114,413,411,413,812,
        305,105,406,405,411,807,
        305,105,406,405,412,811,
        305,105,415,413,411,
        407,406,314,114,413,411,412,811,410,
        0xffff
void delayms(uint ms)          /*ms 等于1時,延時1ms 等于2時,延時2ms,以此類推*/
        uchar a,b,c;                                   //+3
        while(ms--)
         for(c=1;c>0;c--)                        //         1+2 = 3
        for(b=142;b>0;b--)                  //        1*( 1+142*2)) = 285
            for(a=2;a>0;a--);        //         142*(1+2*2) = 710
void delay125ms(uint pai)  //延時 ?*125ms 即?個節拍
    uchar a,b,c;
        while(pai--)
        for(c=239;c>0;c--)
                for(b=104;b>0;b--)
                        for(a=1;a>0;a--);
void timer0() interrupt 1
        TH0 = tone_h;
        TL0 = tone_l;
        SPK = ~SPK;
void timer_init()
        EA = 1;
        ET0 = 1;
        PT0 = 1;
        TMOD = 0x11;
        TH0 = 255;
        TL0 = 255;
        timer_init();
        note = 1;
                if(test[note] == 0xffff)
                        note = 1;
                if(test[note]%10 != 0)        //音調不為0 【音調為0時表示不發聲,但有節拍】
                        tone_h = TH0 = chuzhi[test[note]%100/10][(test[note]%10)*2 ];                //音調高位
                        tone_l = TL0 = chuzhi[test[note]%100/10][(test[note]%10)*2 + 1];        //音調低位
                        TR0 = 1;
                delay125ms(test[note]/100);        //節拍
                TR0 = 0;
                delayms(30);
                note++;                        //下一個音符
生日快樂歌proteus仿真.rar
40.6 KB, 下載次數: 37, 下載積分: 黑幣 -5
51單片機仿真實例
ID:582362 發表于 2019-7-11 15:53 | 只看該作者
謝謝樓主
ID:399007 發表于 2019-8-6 22:06 | 只看該作者
你的樂譜初值是什么軟件得到的?
