stc15w4k58s4看門狗復(fù)位測試程序
單片機(jī)源程序如下:
- /************* 本程序功能說明 **************
- 用STC的MCU的IO方式控制74HC595驅(qū)動(dòng)8位數(shù)碼管。
- 用戶可以修改宏來選擇時(shí)鐘頻率.
- 顯示效果為: 顯示秒計(jì)數(shù), 5秒后不喂狗, 等復(fù)位.
- #define MAIN_Fosc 22118400L //定義主時(shí)鐘
- #include "STC15Fxxxx.H"
- #define DIS_DOT 0x20
- #define DIS_BLACK 0x10
- #define DIS_ 0x11
- /****************************** 用戶定義宏 ***********************************/
- #define Timer0_Reload (65536UL -(MAIN_Fosc / 1000)) //Timer 0 中斷頻率, 1000次/秒
- /************* 本地常量聲明 **************/
- u8 code t_display[]={ //標(biāo)準(zhǔn)字庫
- // 0 1 2 3 4 5 6 7 8 9 A B C D E F
- 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
- //black - H J K L N o P U t G Q r M y
- 0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
- 0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46}; //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
- u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //位碼
- /************* IO口定義 **************/
- sbit P_HC595_SER = P4^0; //pin 14 SER data input
- sbit P_HC595_RCLK = P5^4; //pin 12 RCLk store (latch) clock
- sbit P_HC595_SRCLK = P4^3; //pin 11 SRCLK Shift data clock
- /************* 本地變量聲明 **************/
- u8 LED8[8]; //顯示緩沖
- u8 display_index; //顯示位索引
- u16 ms_cnt;
- u8 tes_cnt; //測試用的計(jì)數(shù)變量
- void delay_ms(u8 ms);
- void DisplayScan(void);
- /********************** 主函數(shù) ************************/
- void main(void)
- u8 i;
- P0M1 = 0; P0M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P1M1 = 0; P1M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P2M1 = 0; P2M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P3M1 = 0; P3M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P4M1 = 0; P4M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P5M1 = 0; P5M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P6M1 = 0; P6M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P7M1 = 0; P7M0 = 0; //設(shè)置為準(zhǔn)雙向口
- display_index = 0;
- for(i=0; i<8; i++) LED8[i] = DIS_BLACK; //全部消隱
- tes_cnt = 0;
- ms_cnt = 0;
- LED8[7] = ms_cnt;
- while(1)
- delay_ms(1); //延時(shí)1ms
- DisplayScan();
- if(tes_cnt <= 5) //5秒后不喂狗, 將復(fù)位,
- WDT_CONTR = (D_EN_WDT + D_CLR_WDT + D_WDT_SCALE_16); // 喂狗
- if(++ms_cnt >= 1000)
- ms_cnt = 0;
- tes_cnt++;
- LED8[7] = tes_cnt;
- // 函數(shù): void delay_ms(unsigned char ms)
- // 描述: 延時(shí)函數(shù)。
- // 參數(shù): ms,要延時(shí)的ms數(shù), 這里只支持1~255ms. 自動(dòng)適應(yīng)主時(shí)鐘.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2013-4-1
- // 備注:
- u16 i;
- do{
- i = MAIN_Fosc / 13000;
- while(--i) ; //14T per loop
- }while(--ms);
- /**************** 向HC595發(fā)送一個(gè)字節(jié)函數(shù) ******************/
- void Send_595(u8 dat)
- u8 i;
- dat <<= 1;
- P_HC595_SER = CY;
- P_HC595_SRCLK = 1;
- P_HC595_SRCLK = 0;
- /********************** 顯示掃描函數(shù) ************************/
- Send_595(~T_COM[display_index]); //輸出位碼
- Send_595(t_display[LED8[display_index]]); //輸出段碼
- P_HC595_RCLK = 1;
- P_HC595_RCLK = 0; //鎖存輸出數(shù)據(jù)
- if(++display_index >= 8) display_index = 0; //8位結(jié)束回0
07-看門狗復(fù)位測試程序.zip
(29.11 KB, 下載次數(shù): 18)
2019-6-25 15:41 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
