只需一步,快速開(kāi)始
查看: 3291|回復(fù): 1
51單片機(jī)按鍵選播電子音樂(lè)或者音樂(lè)盒程序
電子音樂(lè)盒的設(shè)計(jì)
設(shè)計(jì)任務(wù):1. 查閱資料,了解單片機(jī)控制單音喇叭發(fā)聲原理;
                2. 設(shè)計(jì)基于單片機(jī)的電子音樂(lè)盒;
                      3.通過(guò)按鈕可選擇不同的音樂(lè),切換3首音樂(lè)
單片機(jī)源程序如下:
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit BEEP = P3^7;
  5. uint code Tone_Delay_Table[] =
  6. {64021,64103,64260,64400,64524,64580,64684,64777,64820,64898,64968,65030,65058,65110,65157,65178};
  7. uchar code Song1_Tone [] =
  8. {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0xFF};
  9. uchar code Song1_Time [] =
  10. {1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0xFF};
  11. uchar code Song2_Tone [] =
  12. {3,5,5,3,3,2,1,2,3,5,3,2,3,5,3,2,1,2,3,2,1,1,0xFF};
  13. uchar code Song2_Time [] =
  14. {2,1,1,2,1,1,1,2,1,1,1,2,1,1,2,1,1,1,2,1,1,1,0xFF};
  15. uchar code Song3_Tone [] =
  16. {1,3,3,3,3,5,4,2,5,3,7,6,5,5,7,4,4,3,6,7,2,1,0xFF};
  17. uchar code Song3_Time [] =
  18. {2,1,1,2,1,1,1,2,1,1,3,2,1,1,2,4,1,1,2,1,1,1,0xFF};
  19. uchar Song_Index = 0,Tone_Index = 0;
  20. uchar*Song_Tone_Pointer,*Song_Time_Pointer;
  21. uchar i = 0;
  22. void DelayMS(uint ms)
  23. {
  24.    uchar t;
  25.    while(ms--) for (t = 0; t < 120; t++);
  26. }
  27. void Key_Press() interrupt 0
  28. {
  29.   TR0 = 0;
  30.   Song_Index = ( Song_Index + 1 ) % 3;
  31.   switch (Song_Index)
  32. {
  33.   case 0: Song_Tone_Pointer = Song1_Tone;
  34.           Song_Time_Pointer = Song1_Time;
  35.           break;
  36.   case 1: Song_Tone_Pointer = Song2_Tone;
  37.           Song_Time_Pointer = Song2_Time;
  38.           break;
  39.   case 2: Song_Tone_Pointer = Song3_Tone;
  40.           Song_Time_Pointer = Song3_Time;
  41.           break;
  42. }
  43. i = 0;
  44. TR0 = 1;
  45. }
  46. //----------------------------------------------------------------------------
  47. void Timer0_Play_Music() interrupt 1
  48. {
  49. TH0 = Tone_Delay_Table[ Tone_Index ] / 256;
  50. TL0 = Tone_Delay_Table[ Tone_Index ] % 256;
  51. BEEP =~BEEP;
  52. }
  53. //-------------------------------------------------------------------------------
  54. void main()
  55. {
  56. TMOD = 0x01;
  57. IP   =0x01;
  58. IE   =0x83;
  59. TR0  =0;
  60. Song_Tone_Pointer =Song1_Tone;
  61. Song_Tone_Pointer =Song1_Time;
  62. while (1)
  63. {
  64.    Tone_Index = Song_Tone_Pointer[i];
  65.    if (Tone_Index==0xFF)
  66. {
  67.   i=0;
  68.   DelayMS(2000);
  69.   continue;
  70. }
  71. TR0 = 1;
  72. DelayMS(Song_Time_Pointer[Tone_Index]*240);
  73. TR0 = 0;
  74. i++;
  75. }
  76. }
代碼.docx (15.87 KB, 下載次數(shù): 19)
ID:579910 發(fā)表于 2019-7-8 17:49 來(lái)自觸屏版 | 只看該作者
能在程序后面加一下注釋嗎,樓主
