查看: 3259|回復: 0
51單片機模擬電梯電路原理圖+代碼
程序如下
#include <reg51.h>
#include <stdio.h>
sbit fmq=P1^7;
sbit  led1=P2^7;
sbit  led2=P2^6;
sbit  led3=P2^5;
sbit  led4=P2^4;
sbit  led5=P2^3;
sbit  led6=P2^2;
sbit le1=P2^0;
sbit le2=P2^1;
sbit k1=P3^0;
sbit k2=P3^1;
sbit k3=P3^2;
sbit k4=P3^3;
sbit k5=P3^4;
sbit k6=P3^5;
uchar code a[]={
/*--  文字:  9  --*/
/*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
0x00,0x00,0x00,0x7E,0x42,0x42,0x42,0x42,0x7E,0x40,0x40,0x40,0x40,0x40,0x40,0x7E,
/*--  文字:  8  --*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3C,0x00,0x00,
/*--  文字:  7  --*/
0x00,0x00,0x00,0x7E,0x42,0x20,0x20,0x10,0x10,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
/*--  文字:  6  --*/
0x00,0x00,0x00,0x18,0x24,0x02,0x02,0x3A,0x46,0x42,0x42,0x42,0x44,0x38,0x00,0x00,
/*--  文字:  5  --*/
0x00,0x00,0x00,0x7E,0x02,0x02,0x02,0x1E,0x22,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
/*--  文字:  4  --*/
0x00,0x00,0x00,0x20,0x30,0x30,0x28,0x24,0x24,0x22,0xFE,0x20,0x20,0xF8,0x00,0x00,
/*--  文字:  3  --*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x40,0x20,0x18,0x20,0x40,0x42,0x42,0x3C,0x00,0x00,
/*--  文字:  2  --*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x40,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,
/*--  文字:  1  --*/
0x00,0x00,0x00,0x10,0x1C,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7C,0x00,0x00,
uchar code shang[]={
        0x00,0x00,0x00,0x08,0x1C,0x2A,0x49,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
uchar code xia[]={
        0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x49,0x2A,0x1C,0x08,0x00,
uchar code hz[]={
/*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  中  --*/
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,
0x84,0x10,0x84,0x10,0xFC,0x1F,0x84,0x10,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
/*--  文字:  北  --*/
0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x22,0x20,0x12,0x3E,0x0A,0x20,0x06,0x20,0x02,
0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x42,0x38,0x42,0x27,0x42,0x22,0x7C,0x20,0x00,
/*--  文字:  大  --*/
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFF,0x7F,0x80,0x00,0x80,0x00,
0x40,0x01,0x40,0x01,0x20,0x02,0x20,0x02,0x10,0x04,0x08,0x08,0x04,0x10,0x03,0x60,
/*--  文字:  學  --*/
0x44,0x10,0x88,0x10,0x88,0x08,0x00,0x04,0xFE,0x7F,0x02,0x40,0x01,0x20,0xF8,0x07,
0x00,0x02,0x80,0x01,0xFF,0x7F,0x80,0x00,0x80,0x00,0x80,0x00,0xA0,0x00,0x40,0x00,
/*--  文字:  歡  --*/
0x00,0x01,0x00,0x01,0x3F,0x01,0x20,0x3F,0xA0,0x20,0x92,0x10,0x54,0x02,0x28,0x02,
0x08,0x02,0x14,0x05,0x24,0x05,0xA2,0x08,0x81,0x08,0x40,0x10,0x20,0x20,0x10,0x40,
/*--  文字:  迎  --*/
0x00,0x00,0x04,0x01,0xC8,0x3C,0x48,0x24,0x40,0x24,0x40,0x24,0x4F,0x24,0x48,0x24,
0x48,0x24,0x48,0x2D,0xC8,0x14,0x48,0x04,0x08,0x04,0x14,0x04,0xE2,0x7F,0x00,0x00,
/*--  文字:  您  --*/
0x90,0x00,0x90,0x00,0x88,0x3F,0x4C,0x20,0x2A,0x12,0x99,0x0A,0x88,0x12,0x48,0x22,
0x28,0x22,0x88,0x02,0x08,0x01,0x40,0x00,0x8A,0x20,0x8A,0x48,0x09,0x48,0xF0,0x0F,
uchar s,s1,s2,s3,s4,s5,s6,fla,num,fla1,fla2,fla3,s88;
uchar l1,l2,l3,l4,l5,l6;
  uchar j,k;
void delay(uint x)
   uchar i,k;
    for(i=0;i<110;i++)
      for(k=0;k<x;k++);
void initt0()
        EA=1;
        ET0=1;
        TMOD=0x01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        TR0=1;
uchar key(void)
        uchar k;
        if(k1==0)
                delay(2);
                if(k1==0)
                        k=1;
                        while(k1==0);
        if(k2==0)
                delay(2);
                if(k2==0)
                        k=2;
                        while(k2==0);
if(k3==0)
                delay(2);
                if(k3==0)
                        k=3;
                        while(k3==0);
        if(k4==0)
                delay(2);
                if(k4==0)
                        k=4;
                        while(k4==0);
if(k5==0)
                delay(2);
                if(k5==0)
                        k=5;
                        while(k5==0);
        if(k6==0)
                delay(2);
                if(k6==0)
                        k=6;
                        while(k6==0);
return k;
void main(void)
   uchar t,b;
        initt0();
        s1=128;
        num=128;
        s2=48;
     while (1)
                b=key();
                        switch(b)
                                case 1: num=128; break;//1
                                case 2: num=112; break;//2上
                                case 3: num=96;  break;//3上
                                case 4: num=80; break;//4上
                                case 5: num=64; break;//5上
                                case 6: num=48; break;//6
                        switch(s1)
                                case 128 :led1=0;led2=1;led3=1;led4=1;led5=1;led6=1; s88=8; break;
                                case 112:  led1=1;led2=0;led3=1;led4=1;led5=1;led6=1;s88=7;  break;
                                case 96:  led1=1;led2=1;led3=0;led4=1;led5=1;led6=1;s88=6; break;
                                case 80:  led1=1;led2=1;led3=1;led4=0;led5=1;led6=1;s88=5; break;
                                case 64: led1=1;led2=1;led3=1;led4=1;led5=0;led6=1;s88=4; break;
                                case 48:  led1=1;led2=1;led3=1;led4=1;led5=1;led6=0;s88=3; break;
                if(fla2==0)
             for(t=0;t<16;t++)
                        P0=a[t+s88*16];
                        le2=1;
                        le2=0;
                if(fla==1)
                P0=shang[t+s2];
                le1=1;
                le1=0;
                if(fla==2)
                P0=xia[t+s2];
                le1=1;
                le1=0;
                P1=t;
                delay(1);
                P0=0x00;
                le2=1;
            le1=1;
                le2=0;
            le1=0;
                else if(fla2==1)
                 for(t=0;t<16;t++)
                        P0=hz[t*2+s6*2];
                        le1=1;
                        le1=0;
                        P0=hz[t*2+1+s6*2];
                        le2=1;
                        le2=0;
                        P1=t;
                        delay(1);
                        P0=0x00;
                        le2=1;
                        le1=1;
                        le2=0;
                        le1=0;
void t0() interrupt 1
        s++;
        if(fla3==1)
                k=0;
        if(num==s1&&num!=128)
                s3++;
                if(s3==200)
                        fla3=1;
                s3=0;
                fla3=0;
        if(s1==128)
                s4++;
                if(s4==30)
                        fla2=1;
                s4=0;
                fla2=0;
        if(fla2==1)
                s5++;
                if(s5==1)
                        s5=0;
                        s6++;
                        if(s6==128)
                        s6=0;
        s6=0;
        if(s==2)
                 s=0;
                 fla=0;
                if(s1<num)
                        fla=2;
                        s1++;
                        s2--;
                if(s1>num)
                        fla=1;
                        s1--;
                        s2++;
全部資料51hei下載地址:
模擬電梯原理圖.7z (29.02 KB, 下載次數: 28)
