單片機(jī)源程序如下:
- #include <iom16v.h>
- #include <macros.h>
- #include "1602.h"
- #define uint unsigned int
- #define uchar unsigned char
- #define Set_Bit(val, bitn) (val |=(1<<(bitn)))
- #define Clr_Bit(val, bitn) (val&=~(1<<(bitn)))
- #define Get_Bit(val, bitn) (val &(1<<(bitn)) )
- #define Cpl_Bit(val, bitn) (val^=(1<<(bitn)) )
- uchar adc_0[]={"IRCodeADD:"};
- uchar adc_1[]={"IRCodeDAT:"};
- //*****************************************0
- //函數(shù)聲明
- void ICEInit(void);
- uchar bitcnt;
- uint newFall;
- uint oldFall;
- uint data0;
- uint data1;
- void ICEInit(void) //T/C1初始化
- TIMSK=0X20; //使能捕獲中斷
- TCCR1A=0X00;//T/C1時(shí)鐘與系統(tǒng)相同,本文使用系統(tǒng)AVR內(nèi)部自帶8MHz振蕩源.T/C1時(shí)鐘周期為1μs
- TCCR1B=0X82; //使能噪音抑制,下降沿觸發(fā)中斷
- void main(void)
- DDRA = 0xff;
- PORTA = 0x00;
- DDRB = 0xFF;
- PORTB = 0xFF;
- ICEInit();
- LcdInit();
- WriteChar(1,0,10,adc_0);
- WriteChar(2,0,10,adc_1);
- SEI();
- while(1);
- #pragma interrupt_handler CAPT_ISR:iv_TIMER1_CAPT
- void CAPT_ISR(void)
- uchar a;
- uint temp;
- newFall=ICR1;
- temp=newFall-oldFall; //計(jì)算脈沖加間隔的時(shí)間
- oldFall=newFall;
- if(temp>1024 && temp<1225) // "0"信號(hào)
- temp=0;
- else if(temp>2145 && temp<2345) //“1”信號(hào)
- temp=1;
- else if(temp>13400 && temp<13600) //header信號(hào)
- bitcnt=0;
- data0=0;
- data1=0;
- return; //返回,等待下次開(kāi)始接收
- else ///干擾信號(hào)
- return;
- bitcnt++;
- if(bitcnt<16) //開(kāi)始接收前16位
- data0=data0|(uint)temp;
- data0=data0<<1;
- else if(bitcnt==16)
- else if(bitcnt<32) //開(kāi)始接收后16位
- data1=data1|(uint)temp;
- data1=data1<<1;
- else if(bitcnt==32) //接收完最后一位
- WriteNum(1,10,ASCII[(uchar)(data0>>8)/16]);
- WriteNum(1,11,ASCII[(uchar)(data0>>8)%16]);
- WriteNum(1,12,ASCII[(uchar)data0/16]);
- WriteNum(1,13,ASCII[(uchar)data0%16]);
- WriteNum(2,10,ASCII[(uchar)(data1>>8)/16]);
- WriteNum(2,11,ASCII[(uchar)(data1>>8)%16]);
- WriteNum(2,12,ASCII[(uchar)data1/16]);
- WriteNum(2,13,ASCII[(uchar)data1%16]);
紅外解碼程序 1602顯示結(jié)果.rar
(38.35 KB, 下載次數(shù): 10)
2019-6-18 10:25 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
