查看: 3900|回復: 3
89c52.51單片機蜂鳴器程序 -- 極樂凈土 功能可以實現親測
ID:396815 發表于 2019-6-17 09:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
下面是例子,試過可以使用
#include <REG52.H>
#include <INTRINS.H>
#include "reg52.h"
typedef unsigned int u16;          //對數據類型進行聲明定義
typedef unsigned char u8;
sbit k1=P3^1;         //定義P31口是k1
sbit Beep =  P1^5;
unsigned char n=0;
unsigned char code music_tab[] ={ 0xff,
         0x1c,0x10,0x1c,0x20,0x20,0x10,
0x1c,0x20,0x18,0x20,
0x1c,0x20,0x18,0x20,0x15,0x20,0x13,0x20,
0x2b,0x10,0x26,0x10,
0x39,0x08,0x40,0x08,0x39,0x08,0x40,0x08,
0x30,0x10,0x33,0x10,0x39,0x10,0x40,0x10,
0x2b,0x10,0x26,0x10,0x20,0x10,0x18,0x10,
0x19,0x08,0x18,0x08,0x19,0x08,0x1c,0x08,
0x20,0x10,0x26,0x10,
  0x39,0x10,
  0x40,0x08,0x39,0x08,0x30,0x10,
  0x39,0x08,0x30,0x08,0x2b,0x10,
  0x2b,0x08,0x26,0x08,0x20,0x08,
  0x18,0x08,0x26,0x08,0x20,0x08,
  0x18,0x10,0x19,0x08,0x18,0x08,
  0x19,0x08,0x1c,0x10,0x20,0x10,
  0x1c,0x10,0x20,0x10,0x1c,0x10,
                                          0xff,0xff,0xff,0xff ,
                                         0x00
unsigned char code music_tab1 [] = { 0xff,    0x18,0x08,0x15,0x10,0x13,0x10,
0x1c,0x08,0x20,0x08,0x1c,0x08,0x20,0x08,
  0x18,0x10,0x19,0x10,0x1c,0x10,0x20,0x10,
0x15,0x10,0x13,0x10,0x10,0x10,0x0c,0x10,
0x0d,0x08,0x0c,0x08,0x0d,0x08,0x0e,0x08,
0x10,0x10,0x13,0x10,
1 (極樂凈土).zip
13.72 KB, 下載次數: 57, 下載積分: 黑幣 -5
只是一部分,全部還在文件里面
ID:558859 發表于 2019-6-22 21:54 | 只看該作者
沒有下載就扣除黑幣了
ID:396815 發表于 2019-12-10 14:26 | 只看該作者
qysj22 發表于 2019-6-22 21:54
沒有下載就扣除黑幣了
有的,沒有的話點擊鏈接就可以了
