要求:
2019-6-16 20:36 上傳
2019-6-16 20:37 上傳
仿真電路圖:
2019-6-16 20:38 上傳
單片機(jī)KEIL程序及仿真圖:
- #include <reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit set=P1^0;
- sbit save=P1^5;
- sbit rselect=P1^1;
- sbit lselect=P1^2;
- sbit add=P1^3;
- sbit reduce=P1^4;
- uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uchar disp_buf[6];
- uchar disp_bit=0;
- uint hour,min,sec;
- uint select_num=0;
- uint hour_adj,min_adj,sec_adj;
- uchar count;
- uchar key_num=0;
- void key_scan()
- if(!set)
- hour_adj=hour;
- min_adj=min;
- sec_adj=sec;
- key_num++;
- while(!set);
- if(key_num%2==1)
- if(rselect==0)
- select_num++;
- if(select_num==4)
- select_num=1;
- while(!rselect);
- if(lselect==0)
- select_num--;
- if(select_num<=0)
- select_num=3;
- while(!lselect);
- if(!add&&(key_num%2))
- switch(select_num)
- case 1 :
- hour_adj++;
- if(hour_adj==24)
- hour_adj=0;
- break;
- case 2 :
- min_adj++;
- if(min_adj==60)
- min_adj=0;
- break;
- case 3 :
- sec_adj++;
- if(sec_adj==60)
- sec_adj=0;
- break;
- default:break;
- while(!add);
- if(!reduce&&(key_num%2))
- case 1 :
- hour_adj--;
- if(hour_adj<=0)
- hour_adj=23;
- break;
- case 2 :
- min_adj--;
- if(min_adj<=0)
- min_adj=59;
- break;
- case 3 :
- sec_adj--;
- if(sec_adj<=0)
- sec_adj=59;
- break;
- default:break;
- while(!reduce);
- if(!save&&(key_num%2))
- select_num=0;
- hour=hour_adj;
- min=min_adj;
- sec=sec_adj;
- while(!save);
- /*主函數(shù)*/
- void main()
- TMOD=0x11;
- TH0=0xf7;
- TL0=0x00;
- TH1=0x4c;
- TH0=0x00;
- ET0=1;
- ET1=1;
- EA=1;
- TR0=1;
- TR1=1;
- PT1=1;
- hour=23;
- min=58;
- sec=49;
- count=0;
- while(1)
- key_scan();
- if(key_num%2)
- case 1 :
- if(count<=10)
- disp_buf[0]=hour_adj/10;
- disp_buf[1]=hour_adj%10;
- else
- disp_buf[0]=0x40;
- disp_buf[1]=0x40;
- disp_buf[2]=min_adj/10;
- disp_buf[3]=min_adj%10;
- disp_buf[4]=sec_adj/10;
- disp_buf[5]=sec_adj%10;
- break;
- case 2 :
- if(count<=10)
- else
- disp_buf[2]=0x40;
- disp_buf[3]=0x40;
- break;
- case 3 :
- if(count<=10)
- else
- disp_buf[4]=0x40;
- disp_buf[5]=0x40;
- break;
- default : break;
- if(key_num%2==0)
- disp_buf[0]=hour/10;
- disp_buf[1]=hour%10;
- disp_buf[2]=min/10;
- disp_buf[3]=min%10;
- disp_buf[4]=sec/10;
- disp_buf[5]=sec%10;
- void timer0() interrupt 1
- TH0=0xf7;
- TL0=0x00;
- P2=~(0x01<<disp_bit);
- P0=tab[disp_buf[disp_bit]];
- disp_bit++;
- if(disp_bit==6) disp_bit=0;
- void timer1() interrupt 3
- TH1=0x4c;
- TL1=0x00;
- if(++count==20)
- count=0;
- if(++sec==60)
- sec=0;
- if(++min==60)
- min=0;
- if(++hour==24)
- hour=0;
2019-6-17 00:33 上傳
全部資料51hei下載地址:
keshe2.7z
(31.66 KB, 下載次數(shù): 93)
2019-6-16 20:40 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
