查看: 2430|回復: 0
esp8266無線通信
ID:394949 發表于 2019-6-16 20:07 | 顯示全部樓層 |閱讀模式
源代碼:
#include<reg52.h>
#include<stdio.h>
#include<string.h>
sbit led=P1^0;
sbit led1=P2^0;
sbit led2=P2^1;
sbit key=P2^2;
uchar Rxbuff[40],Rxnum=0,Recive_state=0;
void Init()//110592MH
    TMOD=0x20;
    TH1=0xfD;
    TL1=0xfD;
    TR1=1;
    REN=1;
    SM0=0;
    SM1=1;
    EA=1;
    ES=1;
void delay(uchar t)
    uchar i,j;
    for(i=t;i>0;i--)
        for(j=135;j>0;j--);
//UART 發送一字節
void UART_send_byte(char dat)
    ES=0;
    SBUF = dat;                    //發送
    while (TI == 0);            //等待發送完畢
    TI = 0;                        //清發送完畢中斷請求標志位
    ES=1;
/// UART 發送字符串
void Send_Str(unsigned char *buf)
    while (*buf != '\0')
        UART_send_byte(*buf++);
void TCP_Send(uchar *dat,uchar *p)
        Send_Str(dat);
        delay(1000);
        delay(1000);
        delay(1000);
        if(Recive_state == 1)
            if(strstr(Rxbuff,p))
                memset(Rxbuff,'\0',40);//清空數組
                Recive_state=0;
                break;
void LED()
    led=0;
    delay(1000);
    delay(1000);
    led=1;
    delay(1000);
    delay(1000);
void wifi_init()
    TCP_Send("AT\r\n","OK");
    delay(1000);
    LED();
    TCP_Send("AT+CWMODE=1\r\n","OK");
    delay(1000);
    LED();
    Send_Str("AT+RST");
    LED();
    TCP_Send("AT+CWJAP=\"001\",\"1234567890\"\r\n","OK");
    delay(1000);
    delay(1000);
    delay(1000);
    delay(1000);
    LED();
    TCP_Send("AT+CIPSTART=\"TCP\",\"192.168.4.3\",8080\r\n","OK");
    delay(1000);
    delay(1000);
    LED();
    led1=1;
    led2=1;
    Init();//串口初始化
    delay(1000);
    wifi_init();//wifi初始化
    delay(1000);
        if(key==0)
            delay(1000);
            if(key==0)
                //ES=0;
                led1=0;
                Send_Str("AT+CIPSEND=3\r\n");
                delay(100) ;
                Send_Str("123\n");
                delay(100) ;
                led1=1;
                //ES=1;
            ES=0;  //清空接收標志位
            //led1=~led1;
            //led2=~led2;
            if((Rxbuff[0]=='+')&&(Rxbuff[1]=='I')&&(Rxbuff[2]=='P'))//接收到的字符串形式為+IPD,x:y
               if((Rxbuff[3]=='D')&&(Rxbuff[4]==','))
                  if(Rxbuff[7]=='0')
                     led2 = 0;
                  if(Rxbuff[7]=='1')
                     led2 = 1;
            Recive_state = 0;
            ES=1;  //打開接收標志位
//*****************串口接收中斷函數,接收數據*********************
void UARTInterrupt(void) interrupt 4
    if(RI==1)
        ES = 0;
        RI=0;
        Rxbuff[Rxnum]=SBUF;
        Rxnum++;
        if((Rxbuff[Rxnum-1] == '\n'))
            Rxbuff[Rxnum]='\0';
            Rxnum=0;
            Recive_state = 1;
        else if(Rxnum>40)
            Rxnum=0;
        ES = 1;
客戶端(完成).rar
29.39 KB, 下載次數: 10, 下載積分: 黑幣 -5
項目源代碼—客戶端
