查看: 7339|回復(fù): 1
ESP32鏈接阿里云物聯(lián)網(wǎng)平臺(tái) 源程序分享
ID:562529 發(fā)表于 2019-6-16 15:53 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
# ESP32DevkitC + LED + 阿里云物聯(lián)網(wǎng)平臺(tái)
這個(gè)Demo通過一個(gè)云端可控制的LED燈程序和采集單片機(jī)的溫度濕度等信息,向您展示了如何快速開發(fā)LED和采集單片機(jī)的溫度濕度上云程序。
開發(fā)運(yùn)行本Demo請使用ESP32DevkitC開發(fā)板和阿里云IoT推出的在線設(shè)備開發(fā)Web IDE [Hacklab](https://hacklab.aliyun.com).
#include <Arduino.h>
#include <ArduinoJson.h>
#include <aliyun_mqtt.h>
#include <WiFi.h>
#include "user_dht.h"
#include <lcd.h>
started-with-wifi/
//#define WIFI_SSID "WIFI_SSID"
//#define WIFI_PASSWD "WIFI_PASSWD"
DHT11 dht11(21);
LCD lcd;
uint16_t
temperature=0,humidity=10,speed0=20,other=30;
#define  dustPin  35  //定義風(fēng)速傳感器----adc采集引腳
#define PRODUCT_KEY "XXXXXXX"
#define DEVICE_NAME "XXXXXXX"
#define DEVICE_SECRET   "XXXXXXXXXXXXXX"
#define ALINK_BODY_FORMAT "{\"id\":\"%u\",\"version\":\"1.0\",\"method\":\"%s\",\"params\":%s}"
#define ALINK_TOPIC_PROP_POST "/sys/" PRODUCT_KEY "/" DEVICE_NAME
"/thing/event/property/post"
#define ALINK_TOPIC_PROP_SET "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/service/property/set"
#define ALINK_METHOD_PROP_POST "thing.event.property.post"
#define
LED 2
#define LED_OFF 0
#define LED_ON 1
int ledState = LED_OFF;
bool needReportStatus = true;
int ledStateMapOutput[2] = {HIGH, LOW}; // ESP32Devkitc built-in LED output flip
// int
ledStateMapOutput[2] = {LOW, HIGH}; // FireBeetle built-in LED output flip
unsigned long lastMqttConnectMs = 0;
unsigned int postMsgId = 0;
unsigned int airTemp=10,Humidity=20,WindSpeed=30;
WiFiClient espClient;
PubSubClient mqttClient(espClient);
String translateEncryptionType(wifi_auth_mode_t encryptionType) {
  switch (encryptionType) {
    case (WIFI_AUTH_OPEN):
      return
"Open";
    case (WIFI_AUTH_WEP):
      return "WEP";
    case (WIFI_AUTH_WPA_PSK):
      return "WPA_PSK";
    case (WIFI_AUTH_WPA2_PSK):
      return "WPA2_PSK";
    case
(WIFI_AUTH_WPA_WPA2_PSK):
      return "WPA_WPA2_PSK";
    case (WIFI_AUTH_WPA2_ENTERPRISE):
      return "WPA2_ENTERPRISE";
void scanNetworks() {
  int numberOfNetworks = WiFi.scanNetworks
  Serial.print("Number of networks found: ");
  Serial.println(numberOfNetworks);
  for (int i = 0; i < numberOfNetworks; i++) {
    Serial.print("Network name: ");
    Serial.println
(WiFi.SSID(i));
    Serial.print("Signal strength: ");
    Serial.println(WiFi.RSSI(i));
    Serial.print("MAC address: ");
    Serial.println(WiFi.BSSIDstr(i));
    Serial.print("Encryption
type: ");
    String encryptionTypeDescription = translateEncryptionType(WiFi.encryptionType(i));
    Serial.println(encryptionTypeDescription);
    Serial.println("-----------------------");
void connectToNetwork() {
  WiFi.begin(WIFI_SSID, WIFI_PASSWD);
  while (WiFi.status() != WL_CONNECTED) {
    delay(1000);
    Serial.println("Establishing connection to WiFi..");
Serial.println("Connected to network.");
void mqttCheckConnect()
  bool connected = connectAliyunMQTT(mqttClient, PRODUCT_KEY, DEVICE_NAME, DEVICE_SECRET);
  if (connected) {
Serial.println("MQTT connect succeed!");
    if (mqttClient.subscribe(ALINK_TOPIC_PROP_SET)) {
      Serial.println("subscribe done.");
    } else {
      Serial.println("subscribe failed!");
void mqttPublish()
  char param[70];
  char jsonBuf[180];
  airTemp++;
  Humidity++;
  WindSpeed++;
  sprintf(param, "{\"LightSwitch\":%d,\"airTemp\":%d,\"Humidity\":%d,\"WindSpeed\":%d}",
ledState,airTemp,Humidity,WindSpeed);
  //sprintf(param, "{\"LightSwitch\":%d}", ledState);
  //sprintf(param, "{\"airTemp\":%d}", ledState);
ledState);
  postMsgId += 1;
  sprintf(jsonBuf, ALINK_BODY_FORMAT, postMsgId, ALINK_METHOD_PROP_POST, param);
  if (mqttClient.publish(ALINK_TOPIC_PROP_POST, jsonBuf)) {
     Serial.print("Post
message to cloud: ");
     Serial.println(jsonBuf);
  } else {
    Serial.println("Publish message to cloud failed!");
void mqttPublish_data1()
  char param[70];
  char jsonBuf[180];
sprintf(param, "{\"LightSwitch\":%d,\"airTemp\":%d,\"Humidity\":%d,\"WindSpeed\":%d}", ledState,temperature,humidity,speed0);
  postMsgId += 1;
     Serial.print("Post message to cloud: ");
  } else {
void callback(char* topic, byte* payload, unsigned int length)
  if (strstr
(topic, ALINK_TOPIC_PROP_SET))
    Serial.print("Set message arrived [");
    Serial.print(topic);
    Serial.print("] ");
    payload[length] = '\0';
    Serial.println((char *)payload);
// Deserialization break change from 5.x to 6.x of ArduinoJson
    DynamicJsonDocument doc(100);
    DeserializationError error = deserializeJson(doc, payload);
    if (error)
Serial.println("parse json failed");
      return;
    // {"method":"thing.service.property.set","id":"282860794","params":{"LightSwitch":1},"version":"1.0.0"}
    JsonObject
setAlinkMsgObj = doc.as<JsonObject>();
    // LightSwitch
    int desiredLedState = setAlinkMsgObj["params"]["LightSwitch"];
    if (desiredLedState == LED_ON || desiredLedState == LED_OFF) {
      ledState = desiredLedState;
      const char* cmdStr = desiredLedState == LED_ON ? "on" : "off";
      Serial.print("Cloud command: Turn ");
Serial.print(cmdStr);
      Serial.println(" the light.");
void setup()
    lcd.LCD_GPIOInit();
    lcd.LCD_Init();
    lcd.LCD_Clear(WHITE);
    lcd.Show_Str(3,
0,BLACK,WHITE,"wendu:",12,1);///顯示英文字符串
    lcd.Show_Str(3,20,BLACK,WHITE,"shidu:",12,1);///顯示英文字符串
    lcd.Show_Str(3,40,BLACK,WHITE,"fengsu:",12,1);///顯示英文字符串
lcd.Show_Str(3,60,BLACK,WHITE,"other:",12,1);///顯示英文字符串
   adcAttachPin(dustPin);////風(fēng)速傳感器----adc采集管腳初始化
   adcStart(dustPin);////風(fēng)速傳感器----adc采集開始
Serial.begin(115200);
    pinMode(LED, OUTPUT);
    scanNetworks();
    connectToNetwork();
    Serial.println(WiFi.macAddress());
    Serial.println(WiFi.localIP());
    // WiFi.disconnect
(true);
    // Serial.println(WiFi.localIP());
    mqttClient.setCallback(callback);
    lastMqttConnectMs = millis();
    mqttCheckConnect();
void loop()
        unsigned int
temp=1111,dustVal;
        temp=dht11.Get_DHT11_Value_ok();      ///溫濕度采集
        temperature=temp/256;//溫度
        //humidity=temp%256;//濕度
        dustVal=analogRead(dustPin);  ///風(fēng)
速采集
        speed0=dustVal;
        other++;
        humidity++;
        if (humidity>99) humidity=0;
        lcd.LCD_ShowNum(45,0,temperature,3,12);///顯示數(shù)字
lcd.LCD_ShowNum(45,20,humidity,3,12);///顯示數(shù)字
        lcd.LCD_ShowNum(45,40,speed0,3,12);///顯示數(shù)字
        lcd.LCD_ShowNum(45,60,other,3,12);///顯示數(shù)字
        mqttPublish_data1();////發(fā)
送數(shù)據(jù)
    if (millis() - lastMqttConnectMs >= 5000) {
      mqttCheckConnect();
    if (!
mqttClient.loop()) {
      Serial.println("The MQTT client is disconnected!");
    digitalWrite(LED, ledStateMapOutput[ledState]);
    if (needReportStatus) {
      mqttPublish();
needReportStatus = false;
全部資料51hei下載地址:
esp32_0001.7z (2.18 MB, 下載次數(shù): 90)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏8 分享淘帖 頂1 踩
ID:440075 發(fā)表于 2019-10-7 21:19 | 只看該作者
請問,怎么使用呢
