上一帖:
http://www.raoushi.com/bbs/dpj-162303-1.html
2019-6-14 22:53 上傳
2019-6-14 22:54 上傳
- #include <EEPROM.h>
- #include <LiquidCrystal.h>
- #include <DS1302.h>
- LiquidCrystal lcd(2,3,4,5,6,7); //LCD定義
- DS1302 rtc(A3,A2,A1); //DS1302定義
- typedef unsigned char uchar;
- //數據存儲位置
- #define switch_on_hour 0x00
- #define switch_on_min 0x01
- #define switch_off_hour 0x02
- #define switch_off_min 0x03
- //按鍵
- #define t_set 8
- #define io_set 9
- #define up 10
- #define down 11
- uchar switch_on_hour_tmp,switch_on_min_tmp,
- switch_off_hour_tmp,switch_off_min_tmp;Time t; //定義數據存儲位置臨時區
- #define relay A0
- //開/關字符
- const uchar switch_on_char[]={
- B01000,
- B01100,
- B01000,
- B01000,
- B01000,
- B01000,
- B01000,
- B00000
- const uchar switch_off_char[]={
- B01000,
- B01000,
- B00100,
- B00010,
- B00000,
- B01000,
- B01000,
- B00000
- void timeset()
- uchar hour_tmp,min_tmp,sec_tmp;
- t=rtc.getTime();
- hour_tmp=t.hour;
- min_tmp=t.min;
- sec_tmp=t.sec;
- lcd.clear();
- while(1){
- lcd.setCursor(0,0);
- lcd.print("Time Hour");
- lcd.setCursor(0,1);
- lcd.print(hour_tmp%100/10,DEC);
- lcd.print(hour_tmp%10,DEC);
- if(digitalRead(up)==0){
- delayMicroseconds(10); //消抖
- while(!digitalRead(up));
- ++hour_tmp;
- if(digitalRead(down)==0){
- while(!digitalRead(down));
- --hour_tmp;
- if(hour_tmp==255)hour_tmp=23;
- if(hour_tmp==24)hour_tmp=0;
- if(digitalRead(t_set)==0){
- while(!digitalRead(t_set));
- while(1){
- lcd.print("Time Minute");
- lcd.print(min_tmp%100/10,DEC);
- lcd.print(min_tmp%10,DEC);
- ++min_tmp;
- --min_tmp;
- if(min_tmp==255)min_tmp=59;
- if(min_tmp==60)min_tmp=0;
- while(1){
- lcd.print("Time Second");
- lcd.print(sec_tmp%100/10,DEC);
- lcd.print(sec_tmp%10,DEC);
- ++sec_tmp;
- --sec_tmp;
- if(sec_tmp==255)sec_tmp=59;
- if(sec_tmp==60)sec_tmp=0;
- rtc.setTime(hour_tmp,min_tmp,sec_tmp);
- lcd.clear();
- return;
- void ioset()
- onset();
- offset();
- void onset()
- uchar hour_tmp,min_tmp;
- hour_tmp=EEPROM.read(switch_on_hour);
- min_tmp=EEPROM.read(switch_on_min);
- lcd.clear();
- while(1){
- lcd.print("SwitchOn Hour");
- ++hour_tmp;
- --hour_tmp;
- if(digitalRead(io_set)==0){
- while(!digitalRead(io_set));
- while(1){
- lcd.print("SwitchOn Minute");
- ++min_tmp;
- --min_tmp;
- EEPROM.write(switch_on_hour,hour_tmp);
- EEPROM.write(switch_on_min,min_tmp);
- lcd.clear();
- return;
- void offset()
- hour_tmp=EEPROM.read(switch_off_hour);
- min_tmp=EEPROM.read(switch_off_min);
- lcd.clear();
- while(1){
- lcd.print("SwitchOff Hour");
- ++hour_tmp;
- --hour_tmp;
- while(1){
- lcd.print("SwitchOff Minute");
- ++min_tmp;
- --min_tmp;
- EEPROM.write(switch_off_hour,hour_tmp);
- EEPROM.write(switch_off_min,min_tmp);
- lcd.clear();
- return;
- void setup() //初始化并顯示字符
- rtc.halt(false);
- rtc.writeProtect(false);
- lcd.begin(16,2);
- lcd.createChar(0,switch_on_char);
- lcd.createChar(1,switch_off_char);
- pinMode(t_set,INPUT_PULLUP);
- pinMode(io_set,INPUT_PULLUP);
- pinMode(up,INPUT_PULLUP);
- pinMode(down,INPUT_PULLUP);
- pinMode(relay,OUTPUT);
- digitalWrite(relay,HIGH);
- lcd.print("The With");
- lcd.print("Commands");
- delay(2000);
- lcd.clear();
- lcd.print("Enjoy");
- lcd.print("Program Life");
- delay(2000);
- lcd.clear();
- void loop()
- t=rtc.getTime();
- lcd.setCursor(4,0);
- lcd.print(rtc.getTimeStr());
- switch_on_hour_tmp=EEPROM.read(switch_on_hour);
- switch_on_min_tmp=EEPROM.read(switch_on_min);
- switch_off_hour_tmp=EEPROM.read(switch_off_hour);
- switch_off_min_tmp=EEPROM.read(switch_off_min);
- lcd.setCursor(1,1);
- lcd.write((uchar)0);
- lcd.print(":");
- lcd.print(switch_on_hour_tmp%100/10,DEC);
- lcd.print(switch_on_hour_tmp%10,DEC);
- lcd.print(":");
- lcd.print(switch_on_min_tmp%100/10,DEC);
- lcd.print(switch_on_min_tmp%10,DEC);
- lcd.write((uchar)1);
- lcd.print(":");
- lcd.print(switch_off_hour_tmp%100/10,DEC);
- lcd.print(switch_off_hour_tmp%10,DEC);
- lcd.print(":");
- lcd.print(switch_off_min_tmp%100/10,DEC);
- lcd.print(switch_off_min_tmp%10,DEC);
- timeset();
- ioset();
- if(t.hour==switch_on_hour_tmp){
- if(t.min==switch_on_min_tmp){
- digitalWrite(relay,LOW);
- if(t.hour==switch_off_hour_tmp){
- if(t.min==switch_off_min_tmp){
TimeSwitch.zip
(64.44 KB, 下載次數: 28)
2019-6-14 20:18 上傳
程序文件 下載積分: 黑幣 -5
