用STM32F103C8T6驅動0.96寸OLED顯示屏顯示折線圖,可以用于顯示溫讀,濕度等數據,讓數據的變化更直觀,界面更炫酷
制作出來的實物圖如下:
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "usart.h"
- #include "usmart.h"
- #include "OLED_I2C.h"
- extern unsigned char BMP1[];
- unsigned char BMP2[8192];
- //將128*8的數組轉為128*64
- void Change_to_12864(unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y,n,BMP3[1024];
- for(y=0;y<64;y=y+8)
- for(x=0;x<128;x++)
- BMP3[j]=BMP[j];
- for(n=0;n<8;n++)
- if(BMP3[j]&0x01)
- BMP2[x+(y+n)*128]=1;
- BMP3[j]=BMP3[j]>>1;
- j++;
- //將128*64的數組轉為128*8
- void Change_to_1288(unsigned char BMP4[])
- unsigned int j=0;
- unsigned char x,y,n,temp;
- for(n=0;n<8;n++)
- temp|=BMP4[x+(y+n)*128]<<7;
- if(n<7)
- temp=temp>>1;
- BMP1[j]=temp;
- temp=0;
- j++;
- //畫線
- //x1,y1:起點坐標
- //x2,y2:終點坐標
- void LCD_DrawLine(u16 x1, u16 y1, u16 x2, u16 y2)
- u16 t;
- int xerr=0,yerr=0,delta_x,delta_y,distance;
- int incx,incy,uRow,uCol;
- delta_x=x2-x1; //計算坐標增量
- delta_y=y2-y1;
- uRow=x1;
- uCol=y1;
- if(delta_x>0)incx=1; //設置單步方向
- else if(delta_x==0)incx=0;//垂直線
- else {incx=-1;delta_x=-delta_x;}
- if(delta_y>0)incy=1;
- else if(delta_y==0)incy=0;//水平線
- else{incy=-1;delta_y=-delta_y;}
- if( delta_x>delta_y)distance=delta_x; //選取基本增量坐標軸
- else distance=delta_y;
- for(t=0;t<=distance+1;t++ )//畫線輸出
- BMP2[uRow+uCol*128]=1;//畫點
- xerr+=delta_x ;
- yerr+=delta_y ;
- if(xerr>distance)
- xerr-=distance;
- uRow+=incx;
- if(yerr>distance)
- yerr-=distance;
- uCol+=incy;
- //顯示全屏
- void OLED_Fast(unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y;
- for(y=0;y<8;y++)
- OLED_SetPos(0,y);
- WriteDat(BMP[j]);
- j++;
- //顯示折線圖
- void ZXT(unsigned char num)
- static unsigned char num2=0;
- LCD_DrawLine(122,63-num2,126,63-num);//畫線
- num2=num;
- Change_to_1288((unsigned char *)BMP2);
- for(x=0;x<124;x++)//畫橫軸和橫軸刻度
- if(x%8==0&&x!=0)
- BMP1[x+7*128]|=0xC0;
- else
- BMP1[x+7*128]|=0x80;
- for(y=0;y<8;y++)//畫縱軸
- BMP1[y*128]|=0xFF;
- for(y=0;y<8;y++)//畫縱軸刻度
- BMP1[1+y*128]|=0x80;
- for(y=0;y<64;y++)//圖像左移4個像素
- BMP2[x+y*128]=BMP2[x+y*128+4];
- for(y=0;y<64;y++)//清除最右邊的一條畫線
- for(x=124;x<128;x++)
- BMP2[x+y*128]=0;
- //LED狀態設置函數
- void led_set(u8 sta)
- LED1=sta;
- //函數參數調用測試函數
- void test_fun()
- OLED_DrawBMP(0,0,128,8,(unsigned char *)BMP1);
- int main(void)
- u8 y;
- u8 s[17]={44,48,55,50,53,31,40,49,48,42,38,38,25,29,46,39,47};
- delay_init(); //延時函數初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
- uart_init(115200); //串口初始化為115200
- LED_Init(); //LED端口初始化
- I2C_Configuration();
- OLED_Init();
- usmart_dev.init(SystemCoreClock/1000000); //初始化USMART
- OLED_CLS();
- while(1)
- ZXT(s[y]);//輸入0到63的數
- OLED_Fast((unsigned char *)BMP1);
- y++;
- if(y==17)y=0;
- delay_ms(100);
OLED-顯示折線圖.7z
(209.24 KB, 下載次數: 119)
2019-6-12 17:36 上傳
