仿真圖
文檔
- #include<reg52.h>
- #include<lcd.h>
- #include<1302.h>
- #include<music_code.h>
- #include<SoundPlay.h>
- #include<dds.h>
- uchar code time[]={'0','1','2','3','4','5','6','7','8','9'};
- uchar code get_up[]="Time to Get up!";
- uchar code str[]="Never frown,even when you are sad,because you never know who is falling in love with your smile! To the world you may be one person,but to one person you may be the world ";
- uchar code menu[4][10]={{"Time Set"},{"Music"},{"Books"},{"Ring Set"}};
- void main()
- ini();
- open();
- delay(255);
- delay(255);
- delay(255);
- delay(255);
- write_order(0x01);
- init_ds1302();
- set_ds1302(time_add,initial_time);
- while(1)
- read_ring();
- if(ring_time[0]==now_time[0]&&ring_time[1]==now_time[1]&&ring_time[2]==now_time[2])
- timeup();
- detect();
- write_order(0x80+0x04);
- for(i=0;menu[key][i]!=0;i++)
- write_date(menu[key][i]);
- get_ds1302();
- write_order(0x80+0x40);
- write_date(time[now_time[4]>>4]);
- write_date(time[now_time[4]&0x0f]);
- write_date(0x01);
- write_date(time[now_time[3]>>4]);
- write_date(time[now_time[3]&0x0f]);
- write_date(0x00);
- write_date(' ');
- write_date(' ');
- write_date(time[now_time[2]>>4]);
- write_date(time[now_time[2]&0x0f]);
- write_date(':');
- write_date(time[now_time[1]>>4]);
- write_date(time[now_time[1]&0x0f]);
- write_date(':');
- write_date(time[now_time[0]>>4]);
- write_date(time[now_time[0]&0x0f]);
- if(key==2)
- sum=0;
- book();
- if(key==1)
- music();
- if(key==3)
- alamn();
- if(key==0)
- time_set();
- void detect()
- uchar temp;
- temp=P1;
- temp=temp&0x0f;
- if(temp!=0x0f)
- switch(temp)
- case 0x0e:
- while(temp!=0x0f)
- temp=P1;
- temp=temp&0x0f;
- if(key==0)
- key=4;
- key--;
- flag=1;
- break;
- case 0x0d:
- while(temp!=0x0f)
- temp=P1;
- temp=temp&0x0f;
- key++;
- flag=2;
- if(key==4)
- key=0;
- break;
- case 0x0b:
- while(temp!=0x0f)
- temp=P1;
- temp=temp&0x0f;
- flag=3;
- break;
- case 0x07:
- while(temp!=0x0f)
- temp=P1;
- temp=temp&0x0f;
- flag=4;
- break;
- void page(uchar k)
- write_order(0x80);
- for(i=k*32;i<k*32+16&&str[i]!='\0';i++)
- write_date(str[i]);
- for(i=k*32+16;i<k*32+32&&str[i]!='\0';i++)
- void book()
- flag=0;
- detect();
- if(flag==3)
- flag=0;
- page(sum);
- while(flag!=4)
- detect();
- if(flag==1)
- flag=0;
- if(sum!=0)
- sum--;
- page(sum);
- if(flag==2)
- flag=0;
- if(sum<5)
- sum++;
- page(sum);
- key=2;
- void alamn()
- flag=0;
- detect();
- if(flag==3)
- flag=0;
- while(flag!=4)
- write_order(0x80+0x02);
多功能音樂播放器仿真程序.7z
(46.71 KB, 下載次數(shù): 157)
2021-5-19 02:59 上傳
網(wǎng)上找的文檔資料.7z
(441.5 KB, 下載次數(shù): 5)
2021-5-19 02:58 上傳
