單片機(jī)源程序如下:
- #include "main.h"
- #include "LCD1602.h"
- #include "DS1302.h"
- #include "DS18B20.h"
- //定義變量
- unsigned int Temp_Buffer = 0;
- unsigned char KEY_NUM = 0;
- bit Flag_KEY_Set = 0;
- unsigned char KEY2_Count = 0;
- //主函數(shù)
- void main()
- LCD1602_Init(); //初始化LCD1602
- DS1302_Init(); //初始化DS1302 時(shí)鐘芯片
- LCD1602_write_com(0x80); // 初始位置?
- LCD1602_write_word("Welcome to use!"); // 字幕
- Temp_Buffer = Get_temp(); //讀取DS18B20的值
- Delay_ms(1000); //延遲
- LCD1602_write_com(0x01); //清屏
- while(1)
- DS1302_GetTime(&DS1302Buffer); //獲取當(dāng)前RTCC值 rtcc是日日歷
- if(Flag_Time_Refresh == 1 && Flag_KEY_Set == 0) //數(shù)據(jù)更新時(shí)才刷新LCD
- Flag_Time_Refresh = 0;
- Display_RTCC(); //顯示實(shí)時(shí)時(shí)鐘
- Display_Temp(); //獲取并顯示溫度值
- Scan_Key(); //按鍵掃描
- switch( KEY_NUM )
- case 1: //按鍵1執(zhí)行程序
- KEY_NUM = 0; //清空按鍵標(biāo)志
- Flag_KEY_Set = ~Flag_KEY_Set; //設(shè)置按鍵標(biāo)志位翻轉(zhuǎn)
- if(Flag_KEY_Set)
- LCD1602_write_com(0x0d); //LCD1602指針閃爍開
- LCD1602_write_com(0x80+ 3); //指針設(shè)置到第一行第4列
- KEY2_Count = 0; //按鍵S2計(jì)數(shù)清零
- else
- LCD1602_write_com(0x0c); //LCD1602指針閃爍關(guān)
- break;
- case 2: //按鍵2執(zhí)行程序
- if(Flag_KEY_Set) //在設(shè)置狀態(tài)時(shí)運(yùn)行
- KEY2_Count++;
- if(KEY2_Count == 7)
- KEY2_Count = 0;
- switch(KEY2_Count)
- case 0:
- LCD1602_write_com(0x80+ 3); //指針指向年,閃爍
- break;
- case 1:
- LCD1602_write_com(0x80+ 6); //指針指向月,閃爍
- break;
- case 2:
- LCD1602_write_com(0x80+ 9); //指針指向日,閃爍
- break;
- case 3:
- LCD1602_write_com(0x80+ 15); //指針指向星期,閃爍
- break;
- case 4:
- LCD1602_write_com(0x80+ 0x40 + 1); //指針指向小時(shí),閃爍
- break;
- case 5:
- LCD1602_write_com(0x80+ 0x40 + 4); //指針指向分鐘,閃爍
- break;
- case 6:
- LCD1602_write_com(0x80+ 0x40 + 7); //指針指向秒鐘,閃爍
- break;
- default : break;
- break;
- case 3: //按鍵3執(zhí)行程序
- case 0:
- DS1302Buffer.Year++;
- if(DS1302Buffer.Year >= 100)
- DS1302Buffer.Year = 0;
- DS1302_SetTime( DS1302_YEAR , DS1302Buffer.Year );
- Display_RTCC();
- break;
- case 1:
- DS1302Buffer.Month++;
- if(DS1302Buffer.Month >= 13)
- DS1302Buffer.Month = 1;
- DS1302_SetTime( DS1302_MONTH , DS1302Buffer.Month );
- Display_RTCC();
- break;
- case 2:
- DS1302Buffer.Day++;
- if(DS1302Buffer.Day >= 32)
- DS1302Buffer.Day = 1;
- DS1302_SetTime( DS1302_DAY , DS1302Buffer.Day );
- Display_RTCC();
- break;
- case 3:
- DS1302Buffer.Week++;
- if(DS1302Buffer.Week >= 8)
- DS1302Buffer.Week = 1;
- DS1302_SetTime( DS1302_WEEK , DS1302Buffer.Week );
- Display_RTCC();
- break;
- case 4:
- DS1302Buffer.Hour++;
- if(DS1302Buffer.Hour >= 24)
- DS1302Buffer.Hour = 0;
- DS1302_SetTime( DS1302_HOUR , DS1302Buffer.Hour );
- Display_RTCC();
- break;
- case 5:
- DS1302Buffer.Minute++;
- if(DS1302Buffer.Minute >= 60)
- DS1302Buffer.Minute = 0;
- DS1302_SetTime( DS1302_MINUTE , DS1302Buffer.Minute );
- Display_RTCC();
- break;
- case 6:
- DS1302Buffer.Second++;
- if(DS1302Buffer.Second >= 60)
- DS1302Buffer.Second = 0;
- DS1302_SetTime( DS1302_SECOND , DS1302Buffer.Second);
- Display_RTCC();
- break;
- default : break;
- break;
- case 4: //按鍵4執(zhí)行程序
- case 0:
- DS1302Buffer.Year--;
- if(DS1302Buffer.Year == 255)
- DS1302Buffer.Year = 99;
- Display_RTCC();
- break;
- case 1:
- DS1302Buffer.Month--;
- if(DS1302Buffer.Month == 0)
- DS1302Buffer.Month = 12;
- Display_RTCC();
- break;
- case 2:
- DS1302Buffer.Day--;
- if(DS1302Buffer.Day == 0)
- DS1302Buffer.Day = 31;
- Display_RTCC();
- break;
- case 3:
- DS1302Buffer.Week--;
- if(DS1302Buffer.Week == 0)
- DS1302Buffer.Week = 7;
- Display_RTCC();
- break;
- case 4:
- DS1302Buffer.Hour--;
- if(DS1302Buffer.Hour == 255)
- DS1302Buffer.Hour = 23;
- Display_RTCC();
- break;
- case 5:
- DS1302Buffer.Minute--;
- if(DS1302Buffer.Minute == 255)
- DS1302Buffer.Minute = 59;
- Display_RTCC();
- break;
- case 6:
- DS1302Buffer.Second--;
- if(DS1302Buffer.Second == 255)
- DS1302Buffer.Second = 59;
- Display_RTCC();
- break;
- default : break;
- break;
- default : break;
- //顯示溫度
- void Display_Temp()
- LCD1602_write_com(0x80+0x40+10); //設(shè)置LCD1602指針到第二行第11列
- if(flag_temper == 1) //根據(jù)溫度標(biāo)志位顯示溫度正負(fù)
- LCD1602_write_data('-');
- if( Temp_Buffer/1000 != 0 ) //如果第一位為0,忽略顯示
- LCD1602_write_data(Temp_Buffer/1000+0X30); //顯示溫度百位值
- LCD1602_write_data(Temp_Buffer%1000/100+0X30); //顯示溫度十位值
- LCD1602_write_data(Temp_Buffer%100/10+0X30); //顯示溫度個(gè)位值
- LCD1602_write_data('.'); //顯示小數(shù)點(diǎn)
- LCD1602_write_data(Temp_Buffer%10+0X30); //顯示溫度十分位值
- LCD1602_write_data('C'); //顯示字符C
- //顯示實(shí)時(shí)時(shí)鐘
- void Display_RTCC()
- LCD1602_write_com(0x80); //指針設(shè)置到第一行第1列
- LCD1602_write_word("20");
- LCD1602_write_data(DS1302Buffer.Year/10 + 0x30); //顯示Year高位
- LCD1602_write_data(DS1302Buffer.Year%10 + 0x30); //顯示Year低位
- LCD1602_write_data(DS1302Buffer.Month/10 + 0x30); //顯示Month高位
- LCD1602_write_data(DS1302Buffer.Month%10 + 0x30); //顯示Month低位
- LCD1602_write_data(DS1302Buffer.Day/10 + 0x30); //顯示Day高位
- LCD1602_write_data(DS1302Buffer.Day%10 + 0x30); //顯示Day低位
- LCD1602_write_com(0x80+13); //指針設(shè)置到第一行第14列
- switch(DS1302Buffer.Week)
- case 1:
- LCD1602_write_word("Mon"); //顯示星期一
- break;
- case 2:
- LCD1602_write_word("Tue"); //顯示星期二
- break;
- case 3:
- LCD1602_write_word("Wed"); //顯示星期三
- break;
- case 4:
- LCD1602_write_word("Thu"); //顯示星期四
- break;
- case 5:
- LCD1602_write_word("Fri"); //顯示星期五
- break;
- case 6:
- LCD1602_write_word("Sat"); //顯示星期六
- break;
- case 7:
- LCD1602_write_word("Sun"); //顯示星期日
- break;
- default : break;
- LCD1602_write_com(0x80 + 0x40); //指針設(shè)置到第二行第1列
- LCD1602_write_data(DS1302Buffer.Hour/10 + 0x30); //顯示Hour高位
- LCD1602_write_data(DS1302Buffer.Hour%10 + 0x30); //顯示Hour低位
- LCD1602_write_data(':');
- LCD1602_write_data(DS1302Buffer.Minute/10 + 0x30); //顯示Minute高位
- LCD1602_write_data(DS1302Buffer.Minute%10 + 0x30); //顯示Minute低位
- LCD1602_write_data(DS1302Buffer.Second/10 + 0x30); //顯示Second高位
- LCD1602_write_data(DS1302Buffer.Second%10 + 0x30); //顯示Second低位
- //蜂鳴器程序
- void Buzzer_Di()
- Buzzer = 0;
- Delay_ms(3);
- Buzzer = 1;
- Delay_ms(3);
- //按鍵掃描程序
- void Scan_Key()
- if( KEY1 == 0 ) //按鍵1掃描
- Delay_ms(10); //延時(shí)去抖
- if( KEY1 == 0 )
- Buzzer_Di();
- while(KEY1 == 0); //等待松手
- KEY_NUM = 1;
- if( KEY2 == 0 ) //按鍵2掃描
- if( KEY2 == 0 )
- Buzzer_Di();
- while(KEY2 == 0); //等待松手
- KEY_NUM = 2;
- if( KEY3 == 0 ) //按鍵2掃描
- if( KEY3 == 0 )
- Buzzer_Di();
- while(KEY3 == 0); //等待松手
- KEY_NUM = 3;
- if( KEY4 == 0 ) //按鍵2掃描
- if( KEY4 == 0 )
- Buzzer_Di();
- while(KEY4 == 0); //等待松手
- KEY_NUM = 4;
- //MS延時(shí)函數(shù)(12M晶振下測(cè)試)
- void Delay_ms(unsigned int n)
- unsigned int i,j;
- for(i=0;i<n;i++)
- for(j=0;j<123;j++);
3.LCD1602時(shí)鐘+溫度.zip
(74.41 KB, 下載次數(shù): 15)
2019-6-8 09:59 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
