查看: 9987|回復: 39
51單片機流水燈,逐個點亮,我不能全部都逐個點亮
ID:555516 發(fā)表于 2019-6-7 13:21 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
可以實現閃爍、輪流點亮和逐個點亮,但暫停不行(實物不能暫停,仿真可以),求大佬改一下。
  1. #include<reg52.h>
  3. #define unit unsigned int
  4. void delay_ms(unsigned int);
  5. sbit LED1=P0^0;
  6. sbit LED2=P0^1;
  7. sbit LED3=P0^2;
  8. sbit LED4=P0^3;
  9. sbit LED5=P0^4;
  10. sbit LED6=P0^5;
  11. sbit LED7=P0^6;
  12. sbit LED8=P0^7;
  13. sbit LED9=P2^0;
  14. sbit LED10=P2^1;
  15. sbit LED11=P2^2;
  16. sbit LED12=P2^3;
  17. sbit LED13=P2^4;
  18. sbit LED14=P2^5;
  19. sbit LED15=P2^6;
  20. sbit LED16=P2^7;
  21. sbit  K=P3^4;
  22. sbit T=P1^0;
  23. sbit K1=P3^5;
  24. uchar num,num1;
  25. uchar loopled=0xfe;
  26. uchar flag=0;
  27. uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  28. uchar code table1[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  29. void  init        (){
  30. TMOD = 0x00;   //定時器T0工作方式1
  31. TH0=(65536-50000)/256;   //TH0=(65536-50000)/256;
  32. TL0=(65536-50000)%256;   //TL0=(65536-50000)%256;
  33. EA=1;
  34. ET0=1;
  35. // TR0=1;
  36. }
  37. void  init1(){
  38. TMOD = 0x10;   //定時器T0工作方式1
  39. TH0=(65536-50000)/256;   //TH0=(65536-50000)/256;
  40. TL0=(65536-50000)%256;   //TL0=(65536-50000)%256;
  41. EA=1;
  42. ET1=1;
  43. //TR1=1;
  44. }
  45. void main(void){
  46.   int i;
  47.   IT0 = 1;  //設外部中斷0為邊緣觸發(fā)
  48. EX0 = 1;  //開外部中斷0
  49. EA = 1;   //開總中斷
  50.   IT1=1;        //開外部中斷INT1
  51.   EX1=1;        //開外部中斷
  52.           init1();
  53.   init();
  54.             while(1){
  55.     if(K==0){//控制輪流點亮的開啟
  56.            TR0=1;
  57. }
  58.     if(K1==0){//控制閃爍的開啟
  59.            TR1=1;
  60. }
  61.
  62.
  63.           if(num==20){//輪流點亮程序
  64.           num=0; //num清零
  65.         for(i=0;i<8;i++){
  66.           P0=table0[i];        //
  67.           delay_ms(100);
  68.           P0=0XFF;        //關閉最后一盞燈
  69.            }
  70.         for(i=0;i<8;i++){
  71.           P2=table0[i];
  72.           delay_ms(100);
  73.           P2=0XFF; //關閉最后一盞燈
  74.            }
  75.         }
  76.                  if(num1==20){//閃爍程序
  77.           num1=0; //num1清零
  78.
  79.             LED1=~LED1; //將全部端口取反,實現閃爍功能
  80.          LED2=~LED2;
  81.    LED3=~LED3;
  82.    LED4=~LED4;
  83.    LED5=~LED5;
  84.    LED6=~LED6;
  85.    LED7=~LED7;
  86.    LED8=~LED8;
  87.    LED9=~LED9;
  88.    LED10=~LED10;
  89.    LED11=~LED11;
  90.    LED12=~LED12;
  91.    LED13=~LED13;
  92.    LED14=~LED14;
  93.    LED15=~LED15;
  94.    LED16=~LED16;
  95.
  96.           }
  97.   }
  98. while(1);
  99. }
  100.   int0() interrupt 0 { //暫停
  101.             delay_ms(200);
  102.                 ET0=~ET0;        //將開啟中斷的端口取反
  103.                  ET1=~ET1;
  104.                  EX1=~EX1;
  105.         }
  106.
  107.     int1() interrupt 2                 //逐個點亮
  108. {
  109.                            P0=loopled;//點亮P0組第一個燈
  110.         P2=0xFF; //關閉P2組
  111.                  loopled=loopled<<1;  //循環(huán)左移
  112.         loopled=loopled|1; // 最右補1,防止點亮最后一個LED
  113.   if (loopled==0xff) {
  114.                 flag++;// 一路循環(huán)完成場合,指向下一組
  115.                  loopled=0xFE; // 下一組最后一個LED點亮
  116.     if (flag==2) {        // 兩組組循環(huán)完成了,重新指向第一組
  117.                         flag=0;
  118.                 }
  119.         }
  120.         switch(flag) {            // 根據FLAG的情況開啟/關閉P0/P2組
  121.                 case 0:// P0組
  122.                         P2=0xFF;  // 關閉P2組
  123.                         P0=loopled;
  124.                         break;
  125.                 case 1:// P2組
  126.                         P0=0xFF;  // 關閉P0組
  127.                         P2=loopled;
  128.                         break;
  129.         }
  130.                          }
  131.
  132. time0() interrupt 3{//設定初值
  133.          TH0=(65536-50000)/256;
  134.           TL0=(65536-50000)%256;
  135.          num1++;
  136.
  137.
  138. }
  139. time1() interrupt 1{
  140.          TH0=(65536-50000)/256;         //設定初值
  141.           TL0=(65536-50000)%256;
  142.          num++;
  143.
  144.
  145. }
  146.         void delay_ms(unsigned int dt)//延時函數
  147. {
  148. register unsigned char bt,ct;
  149. for (;dt;dt--)
  150.    for (ct=2;ct;ct--)
  151.        for (bt=250;--bt;);
  152. }
附上完整代碼
ID:386367 發(fā)表于 2019-6-8 19:58 | 只看該作者
逐個點亮的部份,其實不用寫得那麼難看懂,你寫得簡單一點,方便自己,也方便他人。
建議先檢查,測試一下硬件連接有沒問題,然後拆分逐個點亮的代碼部份,逐一調試。
ID:555516 發(fā)表于 2019-6-9 19:55 | 只看該作者
tt123 發(fā)表于 2019-6-8 19:58
建議先檢查,測試一下 ...
呃,, 左移的代碼是跟老師學的,,,我要做的效果是 按一下按鈕就中斷去點亮下一個燈,  你能幫我改一下嗎
ID:517466 發(fā)表于 2019-6-10 00:18 | 只看該作者
/** 流水燈*/
#include<reg52.h>
sbit button=P1^0;
/* 函數申明 -----------------------------------------------*/
void delay(uint z);
void led(void);
** 函數名稱 : main(void)
** 函數功能 : 主函數
uchar loopled=0xfe;
uchar flag=0;
void main() {
        P0=loopled;
        P2=0xFF;
        P3=0xFF;
        while(1) {
                // 按鈕按下了?
                if (button==0) {
                          delay(200);
                          // 等待按鈕松開
                                while(button==0);
                                if (button==1) {
                                        // 按鈕按下又抬起
                                        led();
// 流水燈
void led(void) {
        // 循環(huán)左移
        loopled=loopled<<1;
        // 最右補1,防止點亮最后一個LED
        loopled=loopled|1;
                flag++;
                // 下一組最后一個LED點亮
                loopled=0xFE;
                // 三組循環(huán)完成了,重新指向第一組
    if (flag==3) {
                        flag=0;
        // 將循環(huán)數據送給當前組
        switch(flag) {
                case 0:// P0組
                        P2=0xFF;  // 關閉P2組
                        P3=0xFF;  // 關閉P3組
                        P0=loopled;
                        break;
                case 1:// P2組
                        P0=0xFF;  // 關閉P0組
                        P3=0xFF;  // 關閉P3組
                        P2=loopled;
                        break;
                case 2:// P3組
                        P0=0xFF;  // 關閉P0組
                        P2=0xFF;  // 關閉P2組
                        P3=loopled;
                        break;
** 函數名稱 : delay(uint z)
** 函數功能 : 延時函數
void delay(uint z)
    uchar j;
    for(z;z>0;z--)
        for(j=100;j>0;j--);
流水燈·.zip
9.1 KB, 下載次數: 10
ID:517466 發(fā)表于 2019-6-10 00:21 | 只看該作者
我發(fā)給你的,沒有接入LED。你只需要仿真,看到P0,P2,P3口隨著按鈕每按一次,只有一個口線輸出0(視為點亮LED),并一直保持循環(huán)即可。
ID:517466 發(fā)表于 2019-6-10 00:27 | 只看該作者
我的程序中沒有使用中斷。改成中斷的話,需要調整按鈕連接的口線,連接到P3口的外部中斷管腳上(INT0或者INT1),同時把程序中P3組的循環(huán)改成P1。51的外部中斷的設置,參照的例子很多,也很簡單。
設置中斷處理后,當按鈕按下時,會自動產生中斷。在中斷處理中執(zhí)行l(wèi)ed()函數就可以的。
ID:558594 發(fā)表于 2019-6-10 01:38 來自觸屏版 | 只看該作者
逐個點亮不是可以用,循環(huán)左移_crol(0,1),我感覺可以用
ID:555516 發(fā)表于 2019-6-10 20:25 | 只看該作者
很強,,,我代碼寫得有點差 ,,大佬你的代碼很強,謝謝
ID:555516 發(fā)表于 2019-6-10 21:53 | 只看該作者
文二 發(fā)表于 2019-6-10 01:38
我需要逐個點亮16個LED燈 所以要2個端口  ,直接用循環(huán)左移只能點亮一半或者2個端口一起逐個點亮
ID:554109 發(fā)表于 2019-6-11 08:26 | 只看該作者
感覺你的代碼也有一定的問題,while(1)中無論有沒有語句好像都需要{}這個吧,即使是空循壞也是需要這個的
ID:555516 發(fā)表于 2019-6-11 20:41 | 只看該作者
冰麒麟 發(fā)表于 2019-6-11 08:26
呃,,,這個我解釋不了,這個代碼是我老師說的  我并不理解,但他說沒錯的
ID:517466 發(fā)表于 2019-6-11 22:09 | 只看該作者
while語句有沒有{}無所謂的。有,表示條件為真時執(zhí)行一段代碼塊,因為執(zhí)行語句多,所以用{}包起來。沒有{}的話,條件為真時,執(zhí)行緊鄰其后的一個有效語句,哪怕是一個“;”,表示空語句,什么也不做。樓主的代碼中,所有處理都放在中斷處理中執(zhí)行,所以主處理中什么都不做,僅僅是一個死循環(huán)罷了。
ID:557774 發(fā)表于 2019-6-12 00:03 來自觸屏版 | 只看該作者
比我寫的好多了,我還是個初學者
ID:216226 發(fā)表于 2019-6-12 08:48 | 只看該作者
4樓的寫的還可以了
ID:560560 發(fā)表于 2019-6-12 09:14 | 只看該作者
#include<reg52.h>
#include<intrins.h>
#define led_8 P1
uchar m;
void ys (uint x)
{ uchar i;
while(x--)
for(i=0;i<120;i++);
uchar j,k;
for(j=0;j<3;j++)
m=0x7f;
k=0;
while(k!=8)
m=_crol_(m,1);
led_8=m;
ys(500);
k++;
led_8=0xff;
ys(500);
for(j=0;j<3;j++)
led_8=0x55;
ys(500);
led_8=0xaa;
ys(500);
led_8=0xff;
ys(500);
k=0;
while(k!=8)
led_8<<=1;
ys(500);
k++;
ID:560560 發(fā)表于 2019-6-12 09:16 | 只看該作者
如果不能的話,我建議你改一下圖
ID:559917 發(fā)表于 2019-6-12 09:26 | 只看該作者
我印象中我有做過流水燈
ID:555516 發(fā)表于 2019-6-12 19:15 | 只看該作者
suncat0504 發(fā)表于 2019-6-11 22:09
while語句有沒有{}無所謂的。有,表示條件為真時執(zhí)行一段代碼塊,因為執(zhí)行語句多,所以用{}包起來。沒有{} ...
那我想問大佬個問題,我想要實現用中斷去控制其他中斷的暫停和開始該怎么做?
ID:555516 發(fā)表于 2019-6-12 19:17 | 只看該作者
數據集 發(fā)表于 2019-6-12 09:14
#include
#include
謝謝了,樓上的大佬已經幫我搞定了,,,謝謝
ID:517466 發(fā)表于 2019-6-12 20:46 | 只看該作者
czd175711 發(fā)表于 2019-6-12 19:15
利用中斷控制位啊。建議你看看單片機原理。每個中斷都有自己的控制位,比如51單片機中的ET0,ET1,ES等。通?刂莆=0,就表示禁止那個中斷的響應處理?刂莆=1,表示允許那個中斷來的時候,調用對應的中斷處理。
ID:517466 發(fā)表于 2019-6-12 20:54 | 只看該作者
中斷處理中控制其它中斷,還需要考慮優(yōu)先級的問題。比如在低級中斷中控制高級中斷,會出現這樣的情況:低級的在執(zhí)行高級中斷禁止的時候,還沒來得及執(zhí)行禁止語句的時候,高級中斷發(fā)生了。也就是說,有時候,你覺得你已經禁止某個中斷了,結果實際運行中,還是出現了那個被禁止的中斷被執(zhí)行過。這就是優(yōu)先級有高低而產生的問題,在實際應用中要加以注意。
不忙的時候,多看看原理方面的書,對工作會有很大幫助的。
ID:517466 發(fā)表于 2019-6-12 20:58 | 只看該作者
初學編程的人,給你們提一個建議:一點更要養(yǎng)成良好的編程習慣。比如加注釋,變量、函數命名方式,對其縮進等等,開始可能覺得很煩,習慣了就好了。這樣自己做的東西,別人也容易理解。自己以后修改或者代碼重用,也不會出現摸不到頭腦的情況。
ID:555516 發(fā)表于 2019-6-13 11:01 來自觸屏版 | 只看該作者
suncat0504 發(fā)表于 2019-6-12 20:46
利用中斷控制位啊。建議你看看單片機原理。每個中斷都有自己的控制位,比如51單片機中的ET0,ET1,ES等。 ...
這個我知道,我試過用中斷,但是中斷里面的代碼應該是什么?把總中斷EA取反嗎?
ID:561674 發(fā)表于 2019-6-13 12:07 | 只看該作者
應該會出錯吧
ID:517466 發(fā)表于 2019-6-13 12:50 | 只看該作者
czd175711 發(fā)表于 2019-6-13 11:01
盡量不要用取反,使用明確的賦值。比如在串口中斷中,禁止使用計時器0 的中斷時,
                     串口中斷程序
void com_intr (void) interrupt 4 //串行中斷服務程序
    unsigned char Temp;    //定義臨時變量
    uchar i=0;
    ET=0;                  // 臨時禁止Timer0的中斷
    if(RI) {               //判斷是接收中斷產生
              RI=0;              //標志位清零
              Temp=SBUF;         //讀入緩沖區(qū)的值
        SBUF=Temp;         //把接收到的值再發(fā)回電腦端
   if(TI) {                //如果是發(fā)送標志位,清零
                 comio=~comio;
     TI=0;
   ET0=1;                  // 允許Timer0的中斷
ID:561732 發(fā)表于 2019-6-13 13:48 | 只看該作者
我也在做這個
ID:560178 發(fā)表于 2019-6-13 17:13 | 只看該作者
可以先一個一個點亮試試,再整合代碼逐個點亮,加油!
ID:555516 發(fā)表于 2019-6-17 14:00 | 只看該作者
有段代碼不怎么理解 ,想問一下什么意思
// 循環(huán)左移
        loopled=loopled<<1;
        // 最右補1,防止點亮最后一個LED
        loopled=loopled|1;
loopled<<1// 循環(huán)左移 到最后loopled應該等于0X7F
那么最右補1 怎么能做到防止點亮最后一個LED
[// 最右補1,防止點亮最后一個LED
        loopled=loopled|1;】這個代碼是怎么理解的
ID:555516 發(fā)表于 2019-6-17 14:19 | 只看該作者
suncat0504 發(fā)表于 2019-6-13 12:50
有個問題想問,,,,為什么要用串口來實現中斷?INT0的優(yōu)先級是最高的,,那用INT0會不會更好,而且我小白,,,這個代碼有點看不懂。   我用INT0中斷去將EX1  ET0  ET1 取反  在仿真上可以實現暫停,但我將代碼燒錄進實物  卻實現不了,想問下為什么
ID:555516 發(fā)表于 2019-6-17 15:29 來自觸屏版 | 只看該作者
suncat0504 發(fā)表于 2019-6-10 00:18
/** 流水燈*/
#include
哦,,,我好像理解了,|表示的應該是或的意思吧,
ID:517466 發(fā)表于 2019-6-17 16:36 | 只看該作者
czd175711 發(fā)表于 2019-6-17 14:00
有段代碼不怎么理解 ,想問一下什么意思
// 循環(huán)左移
        loopled=loopled
循環(huán)左移場合,字節(jié)的Bit0會自動補入0,不或上‘1’的話,會導致bit0對應的LED也被點亮。
對于數據FF,不斷左移后的變化是:FE,FC, F8, F0, E0,C0,80, 00
ID:517466 發(fā)表于 2019-6-17 16:41 | 只看該作者
czd175711 發(fā)表于 2019-6-17 14:19
有個問題想問,,,,為什么要用串口來實現中斷?INT0的優(yōu)先級是最高的,,那用INT0會不會更好,而且我小 ...
我是給你舉個在中斷中禁止其他中斷的例子。你的程序仿真沒有問題,寫入芯片后不執(zhí)行,需要調試。通過管腳輸出數據或者通過串口向PC發(fā)數據,來觀察中間的處理過程。沒有你的程序,我也只能告訴你這么做。
ID:564818 發(fā)表于 2019-6-17 17:28 | 只看該作者
用匯編比較簡單 左移右移
ID:555516 發(fā)表于 2019-6-17 21:37 | 只看該作者
suncat0504 發(fā)表于 2019-6-17 16:41
我是給你舉個在中斷中禁止其他中斷的例子。你的程序仿真沒有問題,寫入芯片后不執(zhí)行,需要調試。通過管腳 ...
我現在附上完整代碼了   可以幫我看看,,謝謝
ID:555516 發(fā)表于 2019-6-17 21:42 | 只看該作者
suncat0504 發(fā)表于 2019-6-17 16:36
對于數據FF, ...
但是loopled=0xfe   循環(huán)左移 不應該是 0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f 這樣嗎?
ID:555516 發(fā)表于 2019-6-17 21:45 | 只看該作者
1441 發(fā)表于 2019-6-17 17:28
用匯編比較簡單 左移右移
匯編,,,我不怎么會匯編,,,而且匯編的可看性不好,,我一個小白還是先用C語言來學比較好
ID:564631 發(fā)表于 2019-6-18 16:29 | 只看該作者
你暫停了之后沒有保存當前的值,當開啟之后丟失了當前值,還有一個就是你暫定后,只是中斷停止了,但是外面的while循環(huán)還在執(zhí)行LED
ID:517466 發(fā)表于 2019-6-18 21:49 | 只看該作者
czd175711 發(fā)表于 2019-6-17 21:42
在我印象中,匯編語言的左移有兩種,一種是含進位的,RLC A;一種是不含進位C的左移 RL A,都是循環(huán)模式。對于循環(huán)左移一次,Bit7變成Bit0;其他的,順序左移。
但是在C語言中,只有<<左移,>>右移,是不具有循環(huán)方式的(抱歉沒有說清楚),也就是說,在C語言中,使用<<一次后,最右側Bit0補零;使用>>移位一次后,最左側Bit7補零。
ID:517466 發(fā)表于 2019-6-18 21:52 | 只看該作者
czd175711 發(fā)表于 2019-6-17 21:37
在你的代碼中,我沒有看到中斷處理中,對其他中斷做禁止和許可的操作啊
