查看: 2444|回復: 0
用3位數碼管顯示計數器T1對外部計數的計數值,計滿50后顯示輸出FULL。
ID:554134 發表于 2019-6-3 20:55 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
unsigned char Tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char x;
sbit P34=P3^4;
void delaylms(uint i)
uchar j;
while(i--)
for(j=0;j<115;j++);
void Display(unsigned int x)
        P2=0x20;
        P0=Tab[x/100];
        delaylms(1);
        P2=0x40;
        P0=Tab[x%100/10];
        delaylms(1);
        P2=0x80;
        P0=Tab[x%10];
        delaylms(1);
void main(void)
    TMOD=0x06;
          EA=1;
          ET0=1;
          EX0=1;
          IT0=1;
     TH0=TL0=256-1;
      TR0=1;
                                Display(x);
void Time0(void) interrupt 1
  x=0;
void Time1(void) interrupt 2
        x=(x+1)%1000;
        if(x==50)
                x=0;
