查看: 3052|回復(fù): 1
4個(gè)74HC595+單片機(jī)的點(diǎn)陣顯示Proteus仿真圖和程序
單片機(jī)源程序如下:
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit SH_CP=P1^0;
  5. sbit DS=P1^1;
  6. sbit ST_CP=P1^2;
  7. uchar code tab[]=
  8. {
  9. /*--  文字:  東  --*/
  10. /*--  楷體_GB231212;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  11. 0x02,0x00,0x02,0x00,0x02,0x00,0x7F,0xFC,0x04,0x00,0x09,0x00,0x11,0x00,0x21,0x00,
  12. 0x3F,0xF8,0x01,0x00,0x09,0x20,0x11,0x10,0x21,0x08,0x41,0x04,0x05,0x00,0x02,0x00,
  13. /*--  文字:  方  --*/
  14. /*--  楷體_GB231212;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  15. 0x02,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x04,0x00,0x04,0x00,0x04,0x00,0x07,0xF0,
  16. 0x04,0x10,0x04,0x10,0x04,0x10,0x08,0x10,0x08,0x10,0x10,0x10,0x20,0xA0,0x40,0x40,
  17. /*--  文字:  紅  --*/
  18. /*--  楷體_GB231212;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  19. 0x10,0x00,0x10,0x00,0x21,0xFC,0x24,0x20,0x44,0x20,0xF8,0x20,0x10,0x20,0x20,0x20,
  20. 0x40,0x20,0xFC,0x20,0x40,0x20,0x00,0x20,0x1C,0x20,0xE0,0x20,0x43,0xFE,0x00,0x00,
  21. /*--  文字:  太  --*/
  22. /*--  楷體_GB231212;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  23. 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,
  24. 0x02,0x80,0x02,0x80,0x04,0x40,0x04,0x40,0x0A,0x20,0x11,0x10,0x21,0x08,0xC0,0x06,
  25. /*--  文字:  陽  --*/
  26. /*--  楷體_GB231212;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  27. 0x00,0x00,0x7C,0x00,0x45,0xFC,0x49,0x04,0x49,0x04,0x51,0x04,0x49,0x04,0x49,0x04,
  28. 0x45,0xFC,0x45,0x04,0x45,0x04,0x69,0x04,0x51,0x04,0x41,0x04,0x41,0xFC,0x41,0x04,
  29. /*--  文字:  升  --*/
  30. /*--  楷體_GB231212;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  31. 0x01,0x20,0x07,0xA0,0x3C,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0xFF,0xFE,
  32. 0x04,0x20,0x04,0x20,0x04,0x20,0x08,0x20,0x08,0x20,0x10,0x20,0x20,0x20,0x40,0x20,
  33. };
  34. uchar a[]={0x7f,0xff,0xbf,0xff,0xdf,0xff,0xef,0xff,0xf7,0xff,0xfb,0xff,0xfd,0xff,0xfe,0xff,
  35.                0xff,0x7f,0xff,0xbf,0xff,0xdf,0xff,0xef,0xff,0xf7,0xff,0xfb,0xff,0xfd,0xff,0xfe};
  36. void delayms(unsigned int ms)
  37. {
  38.         uchar j;
  39.         while(ms--)
  40.         for(j=0;j<123;j++);
  41. }
  42. void writbyte(uchar dat)
  43. {
  44. uchar k;
  45.         for(k=0;k<8;k++)
  46.         {
  47.          dat=dat<<1;
  48.                 DS=CY;
  49.                 SH_CP=0;
  50.                 SH_CP=1;
  51.         }
  52. }
  53. void main()
  54. {
  55.         uchar num,temp,n,m,count;
  56.         while(1)
  57.         {
  58.    // for(n=0;n<6;n++)
  59.                   for(m=0;m<20;m++)//m移動(dòng)速度
  60.                   {
  61.                          temp=0;
  62.                                  for(num=0;num<16;num++)
  63.                                  {
  64.                                          writbyte(tab[2*(num+count)+1]);//行顯示數(shù)據(jù)高8位
  65.                                          writbyte(tab[2*(num+count)+0]);//低8位
  66.                                          writbyte(a[2*temp+1]);//選擇行高8位
  67.                                          writbyte(a[2*temp]);//選擇
  68.                                          temp++;
  69.                                          if(temp==16)
  70.                                          {temp=0;}
  71.                                          ST_CP=0;
  72.                                          ST_CP=1;
  73.                                          delayms(1);
  74.                                  }
  75.                   }
  76.       count++;
  77.      if(count==80)
  78.                  {
  79.                          count=0;
  80.                  }
  81.         }
  82.
  83. }
新建文件夾.rar (15.84 KB, 下載次數(shù): 91)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏2 分享淘帖 頂 踩
ID:559254 發(fā)表于 2019-6-10 19:15 | 只看該作者
很不錯(cuò),學(xué)習(xí)一下
