我也是萌新,有興趣的小伙伴,一起交流一下
- #include <reg52.h>
- #include <intrins.h>
- #define uint unsigned
- #define uchar unsigned
- uchar led;
- sbit key_s2=P3^0;
- sbit beep=P2^3;
- sbit WE=P2^7;
- sbit DU=P2^6;
- uchar code tabel[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uchar num;
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=114;y>0;y--);
- void main()
- led=0x7f;
- WE=1;
- P0=0XFE;
- WE=0;
- while(1)
- if(key_s2==0)
- delay(20);
- if(key_s2==0)
- led=_crol_(led,1);
- P1=led;
- beep=~beep;
- num++;
- if(num==10) //這里是關鍵
- num=0;
- DU=1;
- P0=tabel[num];
- DU=0;
- while(!key_s2);
- beep=~beep;
- DU=1;
- P0=tabel[num];
- DU=0;
led燈、蜂鳴器、數碼管與按鍵的控制(自己設計).zip
(19.76 KB, 下載次數: 9)
2019-6-3 11:49 上傳
