#include <iom8515v.h>
#include <LCD1602.h>
#include <timer.h>
#include <key.h>
volatile unsigned int time_10ms_ok = 0;
void LED1ON(void)
PORTD |= BIT(0);
void NullSubs(void) //空函數
struct MenuItem MainMenu[6] = //結構體主菜單
{6,"1.fingerprint",&LED1ON,fingerprint,&Null},
{6,"2.password set",&NullSubs,password,&Null},
{6,"3.IC card set",&NullSubs,fingerprint,&Null},
{6,"4.telecontrol",&NullSubs,fingerprint,&Null},
{6,"5.system set",&NullSubs,fingerprint,&Null},
{6,"6.rec inquire",&NullSubs,fingerprint,&Null},
struct MenuItem fingerprint[4] = //子菜單
{4,"1.add fp",&NullSubs,&Null,MainMenu},
{4,"2.del fp",&NullSubs,&Null,MainMenu},
struct MenuItem password[4] = //子菜單
{4,"1.add password",&NullSubs,&Null,MainMenu},
{4,"2.del password",&NullSubs,&Null,MainMenu},
struct MenuItem (*MenuPoint) = MainMenu;
void ShowMenu(void)
unsigned char i = 0;
MaxItems = MenuPoint[0].MenuCount; //獲取當前菜單的條目數
DisplayPoint = DisplayStart; //顯示菜單的編號
if( MaxItems > LCD1602_Max_Display_Line ) //如果大于能顯示的菜單數做處理
for ( i = 0;i < LCD1602_Max_Display_Line;i++ )
LCD_puts(1,i,MenuPoint[DisplayPoint].DisplayString);//2行分別顯示兩個菜單
if ((DisplayPoint) == (UserChoose))
LCD_putc(0,0,0x7e); //寫小箭頭
LCD_putc(0,i,' '); //寫空格
DisplayPoint += 1; //字符串偏移量+1
if ((DisplayPoint) == (MaxItems))
DisplayPoint = 0;
void ExcuteMenu(void)
unsigned char GetKeyNum;
if (time_10ms_ok)
{ //確定有功能按鍵被按下的情況下才執(zhí)行其功能
time_10ms_ok = 0;
GetKeyNum = key_driver();
if((GetKeyNum == 1)||(GetKeyNum == 2))
switch (GetKeyNum)
case S_key://短按鍵
UserChoose++;
if (UserChoose == MaxItems)
UserChoose = 0;//當用戶的選擇數大于最大菜單數量,則選定的清零到第一個
GetKeyNum=0;
break;
case L_key: //長按鍵
if (MenuPoint[UserChoose].ChildrenMenus != &Null)
MenuPoint=MenuPoint[UserChoose].ChildrenMenus; //指向子菜單
SavePoint=UserChoose; //顯示菜單的編號
UserChoose=0;
DisplayStart=0;
else if (MenuPoint[UserChoose].ParentMenus != &Null)
MenuPoint= MenuPoint[UserChoose].ParentMenus; //指向父菜單
UserChoose= 0;
DisplayStart= SavePoint-1;
UserChoose= SavePoint; //恢復先前的菜單
if ((MenuPoint[UserChoose].Subs)!= NullSubs)
(*MenuPoint[UserChoose].Subs)();
GetKeyNum=0;
break;
default: break;
//*菜單循環(huán)處理
if ((UserChoose < DisplayStart) || (UserChoose >= (DisplayStart + 1 )))
DisplayStart = UserChoose;
write_com(0x01);
delay_nms(3);
ShowMenu();
void main(void)
DDRB=0xff; //B口為輸出
DDRD=0x7f;
PORTD=0x80;
TCNT1H=0xD8;
TCNT1L=0xF0;
TCCR1B=0x02;
TIMSK=0x80; // 允許中斷
SEI();
init_LCD();
ShowMenu();
ExcuteMenu();
#pragma interrupt_handler timer1:7
void timer1(void)
time_10ms_ok=1;
TCNT1H=0xD8;
TCNT1L=0xF0;
TIMSK=0x80;
