#include<reg52.h>
#include<stdio.h>
#include "18b20.h"
#include "1602.h"
#include "delay.h"sbit key0=P1^4;
sbit key1=P1^5;
sbit key4=P1^6;
sbit led0=P1^1;
sbit led1=P1^2;
sbit led2=P1^3;
sbit motor=P2^2;
sbit motor1=P2^3;
void scankey();
bit ReadFlag; //定義讀時(shí)間標(biāo)志
char an=0;
unsigned char jiemian=0;
void Init_Timer0(void); //定時(shí)器初始化
int temp,tempH=60,tempL=30;
void UART_Init(void) //串口中斷
SCON = 0x50; // SCON: 模式 1, 8-bit UART, 使能接收
TMOD |= 0x20; // TMOD: timer 1, mode 2, 8-bit 重裝
TH1 = 0xFD; // TH1: 重裝值 9600 波特率 晶振 11.0592MHz
TR1 = 1; // TR1: timer 1 打開(kāi)
//EA = 1; //打開(kāi)總中斷
//ES = 1; //打開(kāi)串口中斷
TI=1;
void main (void)
float wen;
char displaywen[16];//定義顯示區(qū)域臨時(shí)存儲(chǔ)數(shù)組
unsigned char flag=0; //正常溫度的顯示
LCD_Init(); //初始化液晶
DelayMs(200); //延時(shí)有助于穩(wěn)定
LCD_Clear(); //清屏
Init_Timer0();
UART_Init();
Lcd_User_Chr(); //寫(xiě)入自定義字符
wendu();
wendu();
wendu();
while (1)
scankey();
if(ReadFlag==1)
ReadFlag=0;
temp=wendu();
wen=(float)temp*0.0625; //讀取溫度
temp>>=4; //確保切換高、低溫時(shí)準(zhǔn)確
sprintf(displaywen,"Temp % 7.3f",wen);
LCD_Write_String(0,0,displaywen); //顯示第二行
LCD_Write_Char(13,0,0x01); //寫(xiě)入溫度右上角點(diǎn)
LCD_Write_Char(14,0,'C'); //寫(xiě)入字符C
if(temp>=tempL&&temp<=tempH)
{flag=0;led0=0;led2=1;led1=1;motor=1;motor1=1;}
else if(temp>=tempH)
{flag=1;led1=0;led0=1;led2=1;motor1=0;motor=1;}
else if(temp<=tempL)
{flag=2;led2=0;led0=1;led1=1;motor=0;motor1=1;}
switch(jiemian)
case 0:switch(flag)
{ case 0:sprintf(displaywen,"H.%3d L.%3d ",tempH, tempL); //正常顯示狀態(tài)
LCD_Write_String(0,1,displaywen);
break;
case 1:LCD_Write_String(0,1," shangxian tempH ");
break; //高于高溫狀態(tài)
case 2:LCD_Write_String(0,1," xiaxian tempL ");
break; //低于低溫狀態(tài) } break;
case 1:sprintf(displaywen,"+h.%3d l.%3d ",tempH,tempL);
LCD_Write_String(0,1,displaywen);break;
case 2:sprintf(displaywen,"h.%3d +l.%3d ",tempH,tempL);
case 3:sprintf(displaywen,"-h.%3d l.%3d ",tempH,tempL);
case 4:sprintf(displaywen,"h.%3d -l.%3d ",tempH,tempL);
void Init_Timer0(void) //定時(shí)器
TMOD |= 0x01; //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
//TH0=0x00; //給定初值
//TL0=0x00;
EA=1; //總中斷打開(kāi)
ET0=1; //定時(shí)器中斷打開(kāi)
TR0=1; //定時(shí)器開(kāi)關(guān)打開(kāi)
void Timer0_isr(void) interrupt 1
static unsigned int num;
TH0=(65536-2000)/256; //重新賦值 2ms
TL0=(65536-2000)%256;
num++;
if(num==1000)
num=0;
ReadFlag=1; //讀標(biāo)志位置1
}void scankey() //按鍵控制區(qū)域
if(key0==0)
DelayMs(10);
if(key0==0)
if(jiemian==1)tempH+=10; //上限溫度的加的標(biāo)志位
else if(jiemian==2)tempL+=10;
while(!key0);
else if(key1==0)
DelayMs(10);
if(key1==0)
if(jiemian==3)tempH-=10; //下限溫度的加的標(biāo)志位
else if(jiemian==4)tempL-=10;
while(!key1);
else if(key4==0) //切換界面
DelayMs(10);
if(key4==0)
if(jiemian==0)jiemian=1;
else if(jiemian==1)jiemian=2;
else if(jiemian==2)jiemian=3;
else if(jiemian==3)jiemian=4;
else if(jiemian==4)jiemian=0;
while(!key4);
